  2. Announcements
  3. 💬 Dimmable LED Actuator
59 Posts 27 Posters 32.4k Views 27 Watching
  • WieselW
    WieselW
    Wiesel
    I'm new in MySensors and build this Dimmer - LED with and without the rotary encoder which works fine.
    Now I would like to decouple the rotary encoder as a battery powered "standalone" sensor which is (in best case) connected directly to the LED-Dimmer. Furthermore the decoupled rotary encoder should be always in sleep mode until the rotary encoder awake the arduino.
    Is that possible ? I'm just stuck to seperate the code for the rotary encoder from the led-dimmer code.
    Thank you in advance.
    • J
      J
      joschre
      hi, i used the example sketch. i also changed from "delay" to "wait" in fade section. The problem: i can change the percentage for example 8 times and then the gateway crashes and reboots. In a other case it works 12 times and then the gateway crashes. All other nodes (Temp, Hum) works fine all the time.
      • J
        J
        joschre
        oh, i use mysensors serial gateway connected to a raspberry with fhem running.
        • J joschre
          @joschre could you post the debug output from the node?
          • J
            J
            joschre
            Problem solved! The 3.3v Form arduino nano was too Bad for the nrf24l01j pa lna with PA_LEVEL MAX. NOW i usw an external regulator an everything is fine :-) sorry for this newbie fault :-D
            • J joschre
              @joschre great that you found a solution. Thank for reporting back.
              • U
                U
                user2684
                Hi, I've noticed the V_DIMMER of the example is not (anymore?) available in https://www.mysensors.org/download/serial_api_20, am I wrong? Thanks
                • U user2684
                  #37
                  @user2684 you're right. I think it is supposed to be S_DIMMER (S_ is used for presentation)
                  • LacesL
                    LacesL
                    Laces
                    Dear Guys,
                    How can I control an RGB ledstrip with this config may I add more MOSFAT or how ?
                    Thank you very much.
                    L
                    korttomaK 1 Reply Last reply
                    • LacesL Laces
                      Dear Guys,
                      L
                      korttomaK
                      korttomaK
                      korttoma
                      @Laces yes you can. The principal is the same, just one mosfet per channel.
                      Search the forum for RGB or RGBW and you sould be able to find some examples.
                      • Tomas
                      • PlantexP
                        PlantexP
                        Plantex
                        • J jeti
                          so this works now like a charm:
                          #define MY_NODE_ID 153
                          #define SN "MultiDimmableLED"
                          #define SV "1.1"
                          #define noLEDs 3
                          const int LED_Pin[] = {3, 5, 6};
                          #define FADE_DELAY 25  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                          static int currentLevel = 0;  // Current dim level...
                          MyMessage dimmerMsg(noLEDs, V_DIMMER);
                          MyMessage lightMsg(noLEDs, V_LIGHT);
                           * Dimmable LED initialization method
                            // not sure this works
                            // Pull the gateway's current dim level - restore light level upon sendor node power-up
                          for (int sensor=1; sensor<=noLEDs; sensor++){
                            request( sensor, V_DIMMER );
                            // Register the LED Dimmable Light with the gateway
                           present(sensor, S_DIMMER);
                           wait(2);
                            sendSketchInfo(SN, SV);
                           *  Dimmable LED main processing loop
                            if (message.type == V_LIGHT || message.type == V_DIMMER) {
                              Serial.print( "Changing LED " );
                              Serial.print(", PIN " );
                              Serial.print( LED_Pin[message.sensor] );
                              Serial.print(" level to " );
                              Serial.print( ", from " );
                              Serial.println( currentLevel );
                              fadeToLevel( requestedLevel, message.sensor );
                              send(lightMsg.set(currentLevel > 0 ? 1 : 0));
                              // hek comment: Is this really nessesary?
                              send( dimmerMsg.set(currentLevel) );
                           *  This method provides a graceful fade up/down effect
                          void fadeToLevel( int toLevel, int ledid ) {
                            int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
                            while ( currentLevel != toLevel ) {
                              currentLevel += delta;
                              analogWrite(LED_Pin[ledid-1], (int)(currentLevel / 100. * 255) );
                              wait( FADE_DELAY );
                          thank you :thumbsup:
                          PlantexP
                          PlantexP
                          Plantex
                          wrote on last edited by Plantex
                          #41
                          • I
                            I
                            itbeyond
                            Ah I have just built a test bed with this setup however it appears the circuit diagram in the Fritizing is actually not 100% correct. The red wire from the protoboard is connected to the GND of the Pro Mini - this confused me as I was using the GND/RAW pins to identify the cable color. If you flip the red/blue connections on the Pro Mini it will be right. Small issue I know but I had to reference another image to get the circuit to work.
                            • K
                              K
                              KoenP
                              Hi Folks,
                              I have build this in combination with a ethernet gateway. Works perfect, however, when for whatever reason the network fails, I cannot control my lights anymore.
                              Is there a possibilty toi have it working also "stand alone" when the network fails?
                              Grtz.
                              KoenP
                              • vladimirV
                                vladimirV
                                vladimir
                                Hi all!
                                I'm using OpenHAB 2, and I have some problems with the sketch code "DimmableLightWithRotaryEncoderButton".
                                1. When the encoder button is pressed, the switch in OpenHAB does not respond.
                                2. When you turn the encoder knob one step, the value changes in two steps.
                                Maybe you have encountered such a problem? Or maybe you can share a more modern sketch?
                                • vladimirV vladimir
                                  Hi all!
                                  In case anyone can help @vladimir, please post in https://forum.mysensors.org/post/93111 so we keep the discussion focused in one place.
                                  • vladimirV
                                    vladimirV
                                    vladimir
                                    Does anyone use this sketch "DimmableLightWithRotaryEncoderButton"? I take it from the site (https://www.mysensors.org/build/dimmer) and it does not work with OpenHAB 2.
                                      mateos78
                                      does anyone have working sketch -> DimmableLightWithRotaryEncoderButton.ino with Mysensor USB under DOMOTICZ + Arduino ? unfortunatelly phisical button dosn't work (no switch on / off) and there is no feedbeck from domoticz to Arduino to set level of dim. I have been straggling with the sketch for weeks, but haven't figured out , how to fix it. Mybe something has changed since lat update od sketch... and sorry for my english I'm not a native speaker:)
                                      H 1 Reply Last reply
                                      • M mateos78
                                        H
                                        H
                                        hard-shovel
                                        @mateos78 See https://forum.mysensors.org/topic/9670/problem-with-dimmable-led-actuator-with-encoder/11
                                          mateos78
                                          @hard-shovel I've already used this sketch, but still no feedback from domoticz to arduino (it does not dim) and the physical button doesn't work :( ehh...
