  3. Conversion from 1.5.4 to 2.1.1.
10 Posts 3 Posters 2.7k Views 3 Watching
  • DickD
    DickD
    Dick
    I am converting all my nodes to 2.1.1 because they are not visible in the Domoticz so I think I have re adjust them all. Is there a central place where the conversion is explained? I found already a lot of info on this forum. Now I have a questions what can I do with the row:
    I changed it already in
    begin(recieve,AUTO, true);
    But get an erro "begin was not declared in the scope.
    What must I do?
      Not easy to say without your sketch..
      But I think that you may miss the "s" in
      For more infos, you can take a look here:
      • https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
      • MySensors examples
      DickD 1 Reply Last reply
      • scalzS scalz
        DickD
        DickD
        Dick
        @scalz thanks for the link, that was the one I used also. Perhaps you can do something with the whole script in the part void presentation (3rd row)
        // 2x binary switch + dallas temp example
        // digitial I/O pin 4,5 (BUTTON_PIN_4/BUTTON_PIN_5 below) and GND.
        // Connect dallas temp sensor to digital pin 3
        #include <OneWire.h>
        #define DIGITAL_MOTION_SENSOR 2
        #define CHILD_ID_MOTION 6
        #define RELAY_ON 1                      // switch around for realy HIGH/LOW state
        #define RELAY_OFF 0
        Bounce motionsDebouncer = Bounce();
        int lastMOTION;
        unsigned long SLEEP_TIME = 420000;
        //unsigned long SLEEP_TIME = 3000;
        unsigned long blockMotionTimer = 0;
        //#define noRelays 3
        //const int relayPin[] = {A1, A4, A5}; //  switch around pins to your desire
        //const int buttonPin[] = {6, 7, 8}; //  switch around pins to your desire
        #define noRelays 1
        const int relayPin[] = {A1}; //  switch around pins to your desire
        const int buttonPin[] = {6}; //  switch around pins to your desire
        class Relay             // relay class, store all relevant data (equivalent to struct)
        public:
          int buttonPin;                    // physical pin number of button
            int relayPin;                     // physical pin number of relay
          byte oldValue;                    // last Values for key (debounce)
          boolean relayState;               // relay status (also stored in EEPROM)
        Relay Relays[noRelays];
        Bounce debouncerRELAY[noRelays];
        MyMessage msgRELAY[noRelays];
        int numSensors=0;
        boolean receivedConfig = false;
        boolean metric = true;
        MyMessage msg(0,V_TEMP);
        MyMessage msgMOTION(CHILD_ID_MOTION, V_TRIPPED);
          sensors.begin();
          begin(receive, AUTO, true);
          sendSketchInfo("Motion/Temp/relay", "1.0");
          for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++)
            present(i, S_TEMP);
        pinMode(DIGITAL_MOTION_SENSOR, INPUT_PULLUP);      // sets the motion sensor digital pin as input
          motionsDebouncer.attach(DIGITAL_MOTION_SENSOR);
          motionsDebouncer.interval(400);
          present(CHILD_ID_MOTION, S_MOTION, "Motion needs presentation", true);
           for (int i = 0; i < noRelays; i++)
            Relays[i].buttonPin = buttonPin[i];              // assign physical pins
            msgRELAY[i].sensor = i;                                   // initialize messages
            msgRELAY[i].type = V_LIGHT;
            debouncerRELAY[i] = Bounce();                        // initialize debouncer
            debouncerRELAY[i].attach(buttonPin[i]);
            debouncerRELAY[i].interval(5);
            Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
            digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
            send(msgRELAY[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
            present(i, S_LIGHT);                               // present sensor to gateway
            delay(250);
        //process();
        for (byte i = 0; i < noRelays; i++)
            debouncerRELAY[i].update();
            byte value = debouncerRELAY[i].read();
            if (value != Relays[i].oldValue && value == 0)
              saveState( i, Relays[i].relayState );
            }                 // save sensor state in EEPROM (location == sensor number)
            Relays[i].oldValue = value;
          if (blockMotionTimer == 0) {
            if (motionsDebouncer.update()) {
                int value = motionsDebouncer.read();
                Serial.println( "PIR " + (String)value );
                send( msgMOTION.set( value ), true ); // Also it might need inverted value
                blockMotionTimer = (millis() + SLEEP_TIME);
                motionsDebouncer.update(); // dummy update to prevent false trigger after timer expires
                if (blockMotionTimer < millis()) {
          updateTemperature(30);// update time in seconds
        void updateTemperature(int frequency)
          if (millis() - lastUpdateTime >= frequency * 1000UL)
            for (int i=0; i<numSensors && i< MAX_ATTACHED_DS18B20; i++)
              float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
              if (lastTemperature[i] != temperature && temperature != -127.00)
            lastUpdateTime += frequency * 1000UL;
        //void incomingMessage(const MyMessage &message)
        void receive(const MyMessage &message){
          if (message.type == V_LIGHT)
            if (message.sensor < noRelays)            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
              digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
              gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
        //gw.wait(50);
          you don't need to use begin() with 2.x. It's explained in the link above ;) Take a look at the examples in case
          DickD 2 Replies Last reply
          • scalzS scalz
            DickD
            DickD
            Dick
            @scalz That is a good idea, totaly forgotten:cyclone:
            • scalzS scalz
              DickD
              DickD
              Dick
              @scalz I changed everything as mentioned before. I uploaded to my Nano but I see nothing in the serial monitor. I hope it is my last queation:
              the code is until now:
              In// 2x binary switch + dallas temp example
              #define RELAY_OFF 0
              int lastMOTION;
              #define noRelays 1
              public:
              int numSensors=0;
                //sensors.begin();
                //begin receive, AUTO, true;
                  present(i, S_TEMP);
                  Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                  delay(250);
              //gw.wait(50);
                in the link i provided above, at the 2nd line..
                "It is important to do these defines before including MySensors.h, otherwise they will go unnoticed when the library evaluates which parts to include."
                • DickD Dick
                  #define RELAY_OFF 0
                  int lastMOTION;
                  #define noRelays 1
                  public:
                  int numSensors=0;
                    //sensors.begin();
                      present(i, S_TEMP);
                      delay(250);
                  //gw.wait(50);
                  DickD
                  DickD
                  Dick
                  @Dick I hope it is the last time to keep you involved, still nothing in the serial Monitor. For a test I loaded an Example and that showed up in the monitor. Any idea?
                  #define noRelays 1
                  #define RELAY_OFF 0
                  int lastMOTION;
                    public:
                  int numSensors = 0;
                  MyMessage msg(0, V_TEMP);
                    //sensors.begin();
                    for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++)
                      present(i, S_TEMP);
                      delay(250);
                        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                          send(msg.setSensor(i).set(temperature, 1));
                          lastTemperature[i] = temperature;
                    //gw.wait(50);
                  korttomaK 1 Reply Last reply
                  • DickD Dick
                    #define noRelays 1
                    #define RELAY_OFF 0
                    int lastMOTION;
                      public:
                    int numSensors = 0;
                      //sensors.begin();
                        present(i, S_TEMP);
                        delay(250);
                      //gw.wait(50);
                    korttomaK
                    korttomaK
                    korttoma
                    @Dick Add the following to the beginning of your sketch to enable serial print:
                    • Tomas
                    • korttomaK korttoma
                      DickD
                      DickD
                      Dick
                      @korttoma That is easy,Thanks for the solution.
