  2. Announcements
  • Sergio RiusS
    Sergio RiusS
    Sergio Rius
    #582
    That's it. It doesn't use MOSI, MISO and SCLK from the SPI1. I removed the NRF1 and only connected those tree pins of NRF2 into SPI0 and service2 works with NRF2 at channel 125.
    I've tried to share those pins (MOSI, MISO, SCLK) between both radios but as soon as I connect NRF1, 2 stops communicating. Same effect than connecting NRF2 to SPI1.
    What a pity... #@%&!!! :grinning:
    Edit: I finally tried a more "standard" configuration. Using only the first SPI bank and also doesn't work.
    • R
      R
      Roman
      Hi!
      I have a problem with the pseudo port. Node-serialport (v4.0.7) on the command serialport.list produces the result of the undefined.
      Rpi3 and DietPi, nodejs 4.8.4
        @Matt log files for the time where the problem occurred will be essential for troubleshooting.
        make uninstall will stop the service and uninstall
        make cleanconfig will remove previous ./configure settings
        make clean will remove compiled code
        Matt
        @mfalkvidd OK have attached the logfiles below.
        No clues that I can see. At 1502 the NRF goes quiet. I have tried a different pi2, different NRF (PA/LNA) and am currently running the NRF off of 5V from the PI through one of those $1.00 regulator adapter things with built in caps and such. Have also tried different PSUs including a 2A one.
        Only thing I can think left to try is reducing the power output in case the high output of the radio module is inducing transients in the cables...
        Am kinda stumped here. I have an arduino NRF gateway that I will try via USB if low power does not work. I have tried setting up MYSGW as LAN and USB via ./configure but the same thing happens each time.
        One thought just came to me, I AM using the pin15 IRQ option on the NRF now that is still experimental?
        So next time will try without IRQ and low power...
        Any help/suggestions greatly appreciated.
        FYI I have had domoticz running on a lubuntu netbook with USB arduino NRF gateway that has been rock solid. Am trying the get a workable PI solution though, for myself and my father in law but not workable as yet sadly...
        At 15:02:34 you can see the last incoming node message after that the only MYSGW activity is the PING thing... which seems to happen every 10S or so. This goes on for an hour after that with no more incomings. I have ~12 sensors around the place including a power meter one which reports every minute.
        15:02:29 raspberrypi dhcpcd[734]: wlan0: Router Advertisement from fe80::260:64ff:fed7:f613
        Aug  5 15:02:33 raspberrypi mysgw: TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:18.0
        Aug  5 15:02:33 raspberrypi mysgw: TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:21.0
        Aug  5 15:02:34 raspberrypi mysgw: TSF:MSG:READ,23-23-0,s=255,c=3,t=0,pt=1,l=1,sg=0:68
        Aug  5 15:02:34 raspberrypi dhcpcd[734]: wlan0: Router Advertisement from fe80::260:64ff:fed7:f613
        Aug  5 15:02:36 raspberrypi mysgw: Client 0: 0;0;3;0;18;PING
        Aug  5 15:02:37 raspberrypi mysgw: TSF:MSG:READ,41-7-0,s=0,c=1,t=0,pt=7,l=5,sg=0:11.6
        Aug  5 15:02:41 raspberrypi dhcpcd[734]: wlan0: Router Advertisement from fe80::260:64ff:fed7:f613
        Aug  5 15:02:46 raspberrypi mysgw: Client 0: 0;0;3;0;18;PING
        Aug  5 15:02:50 raspberrypi dhcpcd[734]: wlan0: Router Advertisement from fe80::260:64ff:fed7:f613
        Aug  5 15:02:56 raspberrypi mysgw: Client 0: 0;0;3;0;18;PING
        Aug  5 15:02:57 raspberrypi dhcpcd[734]: wlan0: Router Advertisement from fe80::260:64ff:fed7:f613
        Aug  5 15:03:06 raspberrypi dhcpcd[734]: wlan0: Router Advertisement from fe80::260:64ff:fed7:f613
        Aug  5 15:03:06 raspberrypi mysgw: Client 0: 0;0;3;0;18;PING
        Aug  5 15:03:13 raspberrypi dhcpcd[734]: wlan0: Router Advertisement from fe80::260:64ff:fed7:f613
        Aug  5 15:03:16 raspberrypi mysgw: Client 0: 0;0;3;0;18;PING
        Also FWIW to log from domoticz below. Ignore FANFLAG thats just a blockly flag I use...
        2017-08-05 15:01:18.936 (GW) General/Voltage (FanIntakeV)
        2017-08-05 15:02:04.935 (GW) General/kWh (Meter)
        2017-08-05 15:02:33.940 (GW) Temp + Humidity (Mitch2)
        2017-08-05 15:02:33.945 (GW) Temp + Humidity (Mitch2)
        2017-08-05 15:02:37.941 (GW) Temp (MBR Fan)
        2017-08-05 15:50:02.678 Set UserVariable FanFlag = 1
        2017-08-05 15:51:02.693 Set UserVariable FanFlag = 1
        2017-08-05 15:52:02.703 Set UserVariable FanFlag = 1
        2017-08-05 15:53:02.710 Set UserVariable FanFlag = 1
        2017-08-05 15:54:00.037 Set UserVariable FanFlag = 1
        Matt
        • M Matt
          Matt
          @Matt I agree that power is the most likely cause. The nrf24 is very sensitive.
          Before you recompile, add --extra-cxxflags=-DMY_DEBUG_VERBOSE_RF24 to the configure command and you'll get extra details on the radio status in the gateway's debug log.
            Matt
            @mfalkvidd Thankyou. Stable for now. Not sure if they are even genuine modules so... Can reach outside to my glasshouse even on low power setting.
            If it starts playing up again I'll add verbose logging and have another look.
            • O
              O
              Oliviakrk
              Anyone having issues with compilation of latest stable?
              Looks like missing libraries... fatal error: SPI.h: No such file or directory
              • N
                N
                niehoff80
                Yesterday I've tried compiling it also (first time for me) and I had same error.
                • N niehoff80
                  @niehoff80 and/or @Oliviakrk can you run
                  sudo raspi-config
                  (install it using sudo apt-get install raspi-config if it isn't already installed)
                  Select
                  8 Advanced Options
                  and
                  A6 SPI
                  and
                  Yes
                  to all questions. Reboot the raspberry pi and try running make again. If that works I'll add it to the documentation.
                  • N
                    N
                    niehoff80
                    @mfalkvidd
                    I was able to compile it after doing what you're suggesting. It's still have error message during communication with the gateway but that is probably a noobs-error in my config. so I have to investigate a bit more.
                    • O
                      O
                      Oliviakrk
                      Hi
                      I enabled SPI. For Rasberry PI B it was under 5. Interfacing options. The build completed successfully. Thanks!
                      But there is a problem...When I run mysqgw -d I get:
                      mysgw: Starting gateway...
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: !TSM:INIT:TSP FAIL
                      mysgw: TSM:FAIL:CNT=1
                      mysgw: TSM:FAIL:PDT
                      I also tried development release. Works perfectly. Looks like there is problem with stable.
                        syotos
                        Have the same problem with the stable branch as @Oliviakrk using the NRF24 transport on an Raspberry PI B, it might be a driver issue, is see that the make for the development branche builds the BCM drivers while the master branche does not.
                        • N
                          N
                          niehoff80
                          Ok, I had same error as Oliviakrk & syotos on my Raspberry Pi 3 and I also tried the development release and that one works perfectly!
                            mikkelox
                            Hi I followed the instructions, but I can't get it to work, I have a Raspberry Pi 1 Rev1 with NRF24 connected following the instructions.
                            First I configured it just using ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0 --soc=BCM2835 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-gateway=ethernet --my-port=5003
                            I also tried with almost every combination but I always get the same errors.
                            The idea is for it to be used as a standalone GW running from RPI with RF directly attached to it (SPI is enabled and I don't get any errors when compiling)
                            I can send the logs if needed, any help will be welcome, thanks!
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: TSM:FAIL:PDT
                            mysgw: TSM:FAIL:RE-INIT
                            mysgw: TSM:INIT
                            mysgw: TSM:FAIL:CNT=2
                            mysgw: TSM:FAIL:PDT
                              Try latest mysensors version from development branch
                                mikkelox
                                Tried it and got the same output, I also tried with a different NRF24 just in case and doublechecked the connections. are the options I am using ok?
                                ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0 --soc=BCM2835 --my-debug=enable --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-gateway=ethernet --my-port=5003
                                  mikkelox
                                  @gohan, Thank you! I got it to work. First I tried with the development branch and it didn't work either, then I used the following instructions https://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                                  And when that didn't work either I rechecked the wiring which ended up being the reason for it to fail previously, "faulty wires".
                                  I got it to work with the master branch.
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:INIT:TSP OK
                                  mysgw: TSM:INIT:GW MODE
                                  mysgw: MCO:REG:NOT NEEDED
                                  • Z
                                    Z
                                    Zuhairi
                                    Sorry, just want to ask does anyone have the output of this gateway?
                                    gohanG 1 Reply Last reply
                                    • Z Zuhairi
                                      @Zuhairi the previous post?
                                      • Djames SuhankoD
                                        Djames SuhankoD
                                        Djames Suhanko
                                        Hi.
                                        I have a Raspberry Pi already configured as gateway, but I don't know how to interact with. I means, how can I read incoming data from? I tried open /dev/ttyMySensorsGateway as a common serial port but I got a message error:
                                        cu: open (/dev/ttyMySensorsGateway): Permission denied
                                        cu: /dev/ttyMySensorsGateway: Line in use
                                        With 'ps ax' command I can see only '/usr/local/sbin/PiGatewaySerial -d' running as a deamon.
                                        Could someone explain me what's ne next step for?
                                          I'd compile it as ethernet gateway, follow the guide on how to configure the parameters, then you can use MySController (search the forum, there is a topic with download link) and use that to connect to it
                                          Djames SuhankoD 1 Reply Last reply
