  3. How do I get multiple different mock barometers?
53 Posts 6 Posters 11.5k Views 5 Watching
    @NeverDie https://www.mysensors.org/build/pressure has an example on how to use two child IDs to report two values. Just use the same type for both, but different child ids.
    Multiple child ids is one of the basics of MySensors. I've actually never considered that people might not know how to use them :)
    @mfalkvidd
    Can I use that as a pattern, then, to add more than one child ID to the barometer as well?
      @mfalkvidd
      @NeverDie yes. use something like
      #define BARO_1_CHILD 0
      #define BARO_2_CHILD 1
      MyMessage pressure1Msg(BARO_1_CHILD, V_PRESSURE);
      MyMessage pressure2Msg(BARO_2_CHILD, V_PRESSURE);
      present(BARO_1_CHILD, S_BARO);
      present(BARO_2_CHILD, S_BARO);
      send(pressure1Msg.set(pressure1, 0));
      send(pressure2Msg.set(pressure2, 0));
      You can of course use arrays and/or loops if you prefer that (like the relay example does), but duplicating the code like this makes it more readable when you only have a few sensors.
      Do you think there is something we could add to the examples or the documentation to make it clearer how to use child ids?
      • mfalkviddM
        Child id is also described at https://www.mysensors.org/download/sensor_api_20#presentation
          @mfalkvidd said in How do I get multiple different mock barometers?:
          Thanks for that link. It certainly helps. It's funny, though, that in the simple example NODE_ID appears to be completely undefined. I assume it's missing this line?
          #define NODE_ID 0
            #define NODE_ID 0
            @NeverDie if NODE_ID is not defined in the sketch, the controller will(/needs to) provide the next available node id.
            https://www.mysensors.org/download/sensor_api_20#received-node-id
            Node id 0 is reserved for the gateway.
            • korttomaK
              korttomaK
              korttoma
              The correct line for API 2.x is actually:
              #define MY_NODE_ID 1
              • Tomas
                The text of the wiki says:
                child-sensor-id This is where you specify the child sensor that's reporting the data. In the example we only have one child sensor so we pick 0.
                So, based on @mfalkvidd and @korttoma remarks, that is wrong and we should avoid naming child sensor id's as zero? Or, is this confusing the node-id with the child-id?
                Regarding the node-id, doesn't the gateway provide the actual node-id, not the programmer?
                  #21
                  @NeverDie child sensor id and sensor node id are different things.
                  A sensor node (usually arduino + radio) has a node id. Node id 0 is reserved for the gateway. A sensor node can have many child sensors (two bme280 for example). There is no reservation for child sensor id (except maybe 255, I think that is used by some controllers for special data)
                    I have it working now, but why are:
                    #define LONG_WAIT 500
                    #define SHORT_WAIT 50
                    needed?
                    rmtuckerR gohanG 2 Replies Last reply
                      needed?
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      Why barometer instead of voltage and multimeter?
                      • rmtuckerR rmtucker
                        @rmtucker said in How do I get multiple different mock barometers?:
                        No real reason anymore. If you rewind the tape to the beginning, though, it was because barometer compiled and volt meter didn't.
                        rmtuckerR 1 Reply Last reply
                          needed?
                          @NeverDie said in How do I get multiple different mock barometers?:
                          needed?
                          I think those are used in the code to delay the sending of mock values
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            Here is a little sketch that compiles on the NRF5.
                            #define MY_RADIO_NRF5_ESB
                               @def MY_NRF5_ESB_PA_LEVEL
                               @brief Default nRF5 PA level. Override in sketch if needed.
                               - NRF5_PA_MIN = -40dBm
                               - NRF5_PA_LOW = -16dBm
                               - NRF5_PA_HIGH = 0dBm
                               - NRF5_PA_MAX = 4dBm
                            #define MY_NRF5_ESB_PA_LEVEL (NRF5_PA_MAX)
                            #define MY_NRF5_ESB_CHANNEL (76)
                            #define MY_NRF5_ESB_MODE (NRF5_250KBPS)
                            #define MY_NODE_ID 10
                            #define VOLTAGE     0
                            float vcc = (hwCPUVoltage() / 1000.0);
                            MyMessage VoltageMsg(VOLTAGE, V_VOLTAGE);
                              sendSketchInfo("General sensor", "1.0");
                              present(VOLTAGE, S_MULTIMETER);
                            //  Serial.begin(115200);
                            //  while (!Serial) ; // wait for Arduino Serial Monitor
                              send(VoltageMsg.set(vcc, 3));
                            //  Serial.print(F("Voltage = "));
                            //  Serial.print(vcc, 3);
                            //  Serial.println(F("v"));
                              sleep(60000);
                              needed?
                              #27
                              @gohan said in How do I get multiple different mock barometers?:
                              needed?
                              Yes, but why? Is it to give the serial gateway time to process it?
                              I'd like to know the motivation for it because I'm using an ESP8266 as my serial gateway (the Easy-Peasy), and it's considerably faster than, say, an Arduino UNO. For instance, maybe it doesn't need these delays on the sending side to keep up.
                                I think it's more related to allow enough time for people to read the log without flooding it
                                  LOL. Glad I asked!
                                    #30
                                    No, there's more going on than just that apparently. If I reduce their value to zero, it bombs. Reducing short-wait to zero causes the mote to get stuck in a loop somewhere, and reducing long-wait to zero causes the gateway to miss receiving some packets.
                                    If these examples are meant to teach, it sure would be nice if it was documented code!
                                      It is always good practice not to flood the gateway anyway :)
                                      • rejoe2R
                                        rejoe2R
                                        rejoe2
                                        wrote on last edited by rejoe2
                                        #32
                                        This wait() can also help to avoid packet losses due to insufficient power supply when using nRF24.
                                          #33
                                          @NeverDie I am not sure, but I think the mock sketch is meant only for validating new builds of MySensors (by the Jenkins build system connected to Github). It is not included on the build page and as you said it is not documented so I don't think it is meant to teach.
                                          I may be wrong though, I didn't know that sketch existed before you mentioned it.
                                          At almost 1,500 lines it is 10x bigger than most of the build examples, which seems like a very bad idea if the intention is to teach.
