  3. Domoticz
  4. Help Relay Example with button
help relay example with button
3 Posts 2 Posters 1.7k Views 2 Watching
  • A
    ago1980
    I need help for the 'relay button' code. I noticed the code runs well, but if the node losts the communication with the gateway, it can't activate the relay. Can You help me to modify this code to runs the same way also with the node and the gateway stop working to comunicate each other? So, in the case they stop communicating, I Can activate the relay from the node also if It isn't the communication
    (I'm Italian, Sorry for the bad english)
    Bye.
    Relay Example with button: https://www.mysensors.org/build/relay
    Boots33B 1 Reply Last reply
    • A ago1980
      Bye.
      Boots33B
      Boots33B
      Boots33
      @ago1980 Have a look at this Synchronising Light switch you may be able to get a start from there.
      A 1 Reply Last reply
      • Boots33B Boots33
        ago1980
        @Boots33 Thanks a lot worksπŸ˜ŠπŸ˜ŠπŸ˜ŠπŸ˜ŠπŸ˜ŠπŸ˜πŸ˜πŸ‘πŸ‘πŸ‘
        With your input, this post could be even better πŸ’—
        12.5k
