  2. Bug Reports
  3. Out of memory in pressureSensor example
3 Posts 2 Posters 2.5k Views 2 Watching
  • P
    P
    portals
    I've tried to use a pressureSensor example but Arduino nano clone didn't send any data. During compilation i have seen:
    Sketch uses 23,540 bytes (76%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,677 bytes (81%) of dynamic memory, leaving 371 bytes for local variables. Maximum is 2,048 bytes.
    Low memory available, stability problems may occur.
    Serial was looped:
    send:sensor started, id 1
    I solved this problem by disable weather forecast. I suppose device run out of memory with enabled weather forecast.
    N 1 Reply Last reply
    • P portals
      Serial was looped:
      N
      N
      niccodemi
      @portals I had same issue - see this thread.
      Download latest library, disable debug and follow @BulldogLowell advice. I managed to get dynamic memory to 75% and that seems sufficient - it has been running for a week now without issues.
      • P
        P
        portals
        wrote on last edited by portals
        For now i found this solution:
        I changed a pressureAvg and pressureSamples to unsigned int. Next changed int forecast = sample(pressure) to int forecast = sample(pressure * 10) to avoid big precision lost. Sample function still may need correction but probably it is a good and easy way to fix this problem.
        Result:
        Sketch uses 18,636 bytes (60%) of program storage space. Maximum is 30,720 bytes.
        Global variables use 1,268 bytes (61%) of dynamic memory, leaving 780 bytes for local variables. Maximum is 2,048 bytes.
