  3. Relay with button wihtout ackn from controller
4 Posts 2 Posters 1.4k Views 1 Watching
    Markus.
    Hi All,
    I am a bit lost at the moment with the Sketch "relay with button". If i understand this code correctly, is the normal process "push the button" ->node sends Status Change to Controller and wait for ack from Controller.
    How can i get this working without to wait for the Controllers ack ?
    #define RELAY_PIN 5  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN 6  // Arduino Digital I/O pin number for button
    #define RELAY_ON 1
    #define RELAY_OFF 0
    //#define MY_NODE_ID 98
    //#define MY_PARENT_NODE_ID 0
    //#define MY_RF24_PA_LEVEL RF24_PA_MIN
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      pinMode(RELAY_PIN, OUTPUT);
      state = loadState(CHILD_ID);
    void presentation()  {
      present(CHILD_ID, S_LIGHT);
    *  Example on how to asynchronously check for new messages from gw
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         saveState(CHILD_ID, state);
    Many Thanks
    Markus
    • M Markus.
      Hi All,
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue=0;
      bool state;
        // Setup the button
        debouncer.update();
        oldValue = value;
      Many Thanks
      Markus
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Markus. said in Relay with button wihtout ackn from controller:
      right now, the device
      1. waits for a button press
      2. sends a message to your controller with the new state
      3. waits for the message type (V_LIGHT) to acknowledge the state change and updates the relay
      if you want to change the state of the relay on the button press (isn't clear to me that you want to do that) you need to move:
      inside the button press state change event:
        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
      this would allow you to update the relay regardless of the connection to the gateway.
        Markus.
        ahh okay thanks :-)
        And If I want to use both funtionallitys ... For example a Button Input Change the state and also the Controller itself can Change the state like the normal relay sketch?
        • M Markus.
          ahh okay thanks :-)
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @Markus.
          I think that is how your original sketch works!
          Unless the gateway isn't functioning.
          You can always leave the function in both places.
