  3. Maximum of relais and Binary buttons on Nano?
7 Posts 2 Posters 2.0k Views 4 Watching
  • DickD
    DickD
    Dick
    I try to get 5 relais and 2 binary buttons activated on my nano and have them controlled by Domoticz.
    What I found was that everything is working 2 bin buttons and 3 relais but adding another relais (4) I loose one bin button and had 4 relais. adding another relay I lost my last bin button. How can I get it in place 5 relais and 2 binary button?
    here you see my script:
    #define MY_REPEATER_FEATURE
    #define CHILD_ID1 3
    #define BUTTON_PIN1  4  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID2 4
    #define BUTTON_PIN2  5  // Arduino Digital I/O pin for button/reed switch
    #define RELAY_1  A0  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 5 // Total number of attached relays
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce(); // debouncer for the second switch
    int oldValue1 = -1;
    int oldValue2 = -1; // second switch needs to have it's own old state
    MyMessage msg1(CHILD_ID1, V_TRIPPED), msg2(CHILD_ID2, V_TRIPPED);
    void before()
      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
        digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
      sendSketchInfo("Serre", "1.0");
        present(sensor, S_BINARY);
      pinMode(BUTTON_PIN1, INPUT_PULLUP ); // You can assign pinmode and use pullup in one statement.
      pinMode(BUTTON_PIN2, INPUT_PULLUP);
      debouncer1.attach(BUTTON_PIN1);
      debouncer1.interval(5);
      debouncer2.attach(BUTTON_PIN2);
      debouncer2.interval(5);
      present(CHILD_ID1, S_DOOR);
      present(CHILD_ID2, S_DOOR);
      // Check if the first switch state has changed
      debouncer1.update();
      // Get the update value
      int value = debouncer1.read();
      if (value != oldValue1) {
        // Send in the new value
        send(msg1.set(value == HIGH ? 1 : 0));
        oldValue1 = value;
      debouncer2.update();
      value = debouncer2.read(); // no need to redeclare it (I removed int)
      if (value != oldValue2) {
        send(msg2.set(value == HIGH ? 1 : 0)); // this is where you turn the second switch in your controller
        oldValue2 = value;
        // Change relay state
        digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
    rejoe2R 1 Reply Last reply
    • DickD Dick
      #define CHILD_ID1 3
      #define CHILD_ID2 4
      int oldValue1 = -1;
      void before()
          oldValue1 = value;
          oldValue2 = value;
      rejoe2R
      rejoe2R
      rejoe2
      @Dick Most likely your problems are related to the use of analog out pins for switching on your relay. Maybe your problem is solved by addressing pin 14 as the digital equivalent to A0 (see https://forum.arduino.cc/index.php?topic=147582.0).
      In case you have to use different PINs, you could use an array to store info about the used pins, see https://forum.mysensors.org/topic/4847/multi-button-relay-sketch/33# as a (more complex) example.
      DickD 1 Reply Last reply
      • rejoe2R rejoe2
        DickD
        DickD
        Dick
        @rejoe2 Thanks for the links and I cange my code. The 5 relais are visibl, the 2 binary switches as wel ut the relais are not switching??? any idea
        • DickD Dick
          DickD
          DickD
          Dick
          wrote on last edited by Dick
          @Dick said in Maximum of relais and Binary buttons on Nano?:
          @rejoe2 Thanks for the links and I changed my code. The 5 relais are visible, the 2 binary switches as well but the relais are not switching??? any idea
          here my code for now:
          #define MOTION_SENSOR 3
          #define CHILD_ID_MOTION 10
          #define RELAY1_PIN  2  // Arduino Digital I/O pin number for relay alarm serre (groen)
          #define BUTTON1_PIN  14  // Arduino Digital I/O pin number for button with relay
          #define CHILD_ID_1 1   // Id of the sensor child
          #define RELAY2_PIN  4  // Arduino Digital I/O pin number for relay garden light serre (grijs)
          #define BUTTON2_PIN  15  // Arduino Digital I/O pin number for button with relay
          #define CHILD_ID_2 2   // Id of the sensor child
          #define RELAY3_PIN  5  // Arduino Digital I/O pin number for relay gordijn serre open (grijs)
          #define BUTTON3_PIN  16  // Arduino Digital I/O pin number for button with relay
          #define CHILD_ID_3 3   // Id of the sensor child
          #define RELAY6_PIN  6  // Arduino Digital I/O pin number for relay gordijn serre dicht (groen)
          #define BUTTON6_PIN  17  // Arduino Digital I/O pin number for button with relay
          #define CHILD_ID_6 12   // Id of the sensor child
          #define RELAY7_PIN  18  // Arduino Digital I/O pin number for relay gordijn serre stop (geel)
          #define BUTTON7_PIN  8  // Arduino Digital I/O pin number for button with relay
          #define CHILD_ID_7 11   // Id of the sensor child
          #define BUTTON4_PIN  19  // Arduino Digital I/O pin number for button without relay
          #define CHILD_ID_4 4   // Id of the sensor child
          #define BUTTON5_PIN  8  // Arduino Digital I/O pin number for button without relay
          #define CHILD_ID_5 5   // Id of the sensor child
          #define RELAY_ON 0
          #define RELAY_OFF 1
          int oldValue1 = 0;
          bool state1;
          int oldValue2 = 0;
          bool state2;
          Bounce debouncer3 = Bounce();
          int oldValue3 = 0;
          bool state3;
          Bounce debouncer4 = Bounce();
          int oldValue4 = 0;
          bool state4;
          Bounce debouncer5 = Bounce();
          int oldValue5 = 0;
          bool state5;
          Bounce debouncer6 = Bounce();
          int oldValue6 = 0;
          bool state6;
          Bounce debouncer7 = Bounce();
          int oldValue7 = 0;
          bool state7;
          Bounce debouncerMotion = Bounce();
          MyMessage msg1(CHILD_ID_1, V_LIGHT);
          MyMessage msg3(CHILD_ID_3, V_LIGHT);
          MyMessage msg4(CHILD_ID_4, V_LIGHT);
          MyMessage msg5(CHILD_ID_5, V_LIGHT);
          MyMessage msg6(CHILD_ID_6, V_LIGHT);
          MyMessage msg7(CHILD_ID_7, V_LIGHT);
          unsigned long SLEEP_TIME = 6000;
          unsigned long blockMotionTimer = 0;
          MyMessage msgRelay1(CHILD_ID_1, V_LIGHT), msgRelay2(CHILD_ID_2, V_LIGHT), msgRelay3(CHILD_ID_3, V_LIGHT), msgButton4(CHILD_ID_4, V_TRIPPED), msgButton5(CHILD_ID_5, V_TRIPPED), msgMotion(CHILD_ID_MOTION, V_TRIPPED), msgRelay6(CHILD_ID_6, V_LIGHT), msgRelay7(CHILD_ID_7, V_LIGHT);
            sendSketchInfo("Relay & Button & Motion", "1.0");
            // Setup the button
            pinMode(BUTTON1_PIN, INPUT);  // Activate internal pull-up
            digitalWrite(BUTTON1_PIN, HIGH);
            pinMode(BUTTON2_PIN, INPUT);
            digitalWrite(BUTTON2_PIN, HIGH);
            pinMode(BUTTON3_PIN, INPUT);
            digitalWrite(BUTTON3_PIN, HIGH);
            pinMode(BUTTON4_PIN, INPUT);
            digitalWrite(BUTTON4_PIN, HIGH);
            pinMode(BUTTON5_PIN, INPUT);
            digitalWrite(BUTTON5_PIN, HIGH);
            pinMode(MOTION_SENSOR, INPUT_PULLUP);
            pinMode(BUTTON6_PIN, INPUT);
            digitalWrite(BUTTON6_PIN, HIGH);
            pinMode(BUTTON7_PIN, INPUT);
            digitalWrite(BUTTON7_PIN, HIGH);
            debouncer3.attach(BUTTON3_PIN);
            debouncer3.interval(5);
            debouncer4.attach(BUTTON4_PIN);
            debouncer4.interval(5);
            debouncer5.attach(BUTTON5_PIN);
            debouncer5.interval(5);
            debouncer6.attach(BUTTON6_PIN);
            debouncer6.interval(5);
            debouncer7.attach(BUTTON7_PIN);
            debouncer7.interval(5);
            debouncerMotion.attach(MOTION_SENSOR);
            debouncerMotion.interval(400);
            present(CHILD_ID_1, S_LIGHT);
            digitalWrite(RELAY1_PIN, RELAY_OFF);
            pinMode(RELAY1_PIN, OUTPUT);
            present(CHILD_ID_2, S_LIGHT);
            digitalWrite(RELAY2_PIN, RELAY_OFF);
            pinMode(RELAY2_PIN, OUTPUT);
            present(CHILD_ID_3, S_LIGHT);
            digitalWrite(RELAY3_PIN, RELAY_OFF);
            pinMode(RELAY3_PIN, OUTPUT);
            present(CHILD_ID_6, S_LIGHT);
            digitalWrite(RELAY6_PIN, RELAY_OFF);
            pinMode(RELAY6_PIN, OUTPUT);
            present(CHILD_ID_7, S_LIGHT);
            digitalWrite(RELAY7_PIN, RELAY_OFF);
            pinMode(RELAY7_PIN, OUTPUT);
            present(CHILD_ID_4, S_DOOR);
            present(CHILD_ID_5, S_DOOR);
            present(CHILD_ID_MOTION, S_MOTION, "Motion needs presentation", true);
            state1 = loadState(CHILD_ID_1);
            digitalWrite(RELAY1_PIN, state1 ? RELAY_ON : RELAY_OFF);
            digitalWrite(RELAY2_PIN, state2 ? RELAY_ON : RELAY_OFF);
            state3 = loadState(CHILD_ID_3);
            digitalWrite(RELAY3_PIN, state1 ? RELAY_ON : RELAY_OFF);
            state6 = loadState(CHILD_ID_6);
            digitalWrite(RELAY6_PIN, state6 ? RELAY_ON : RELAY_OFF);
            state7 = loadState(CHILD_ID_7);
            digitalWrite(RELAY7_PIN, state7 ? RELAY_ON : RELAY_OFF);
            int value1 = debouncer1.read();
            if (value1 != oldValue1 && value1 == 0) {
              send(msgRelay1.set(state1 ? false : true), true); // Send new state and request ack back
            oldValue1 = value1;
            if (value2 != oldValue2 && value2 == 0) {
              send(msgRelay2.set(state2 ? false : true), true); // Send new state and request ack back
            oldValue2 = value2;
            debouncer3.update();
            int value3 = debouncer3.read();
            if (value3 != oldValue3 && value3 == 0) {
              send(msgRelay3.set(state3 ? false : true), true); // Send new state and request ack back
            oldValue3 = value3;
            debouncer4.update();
            int value4 = debouncer4.read();
            if (value4 != oldValue4)
              //Send in the new value
              send(msgButton4.set(value4 == HIGH ? 1 : 0));
              oldValue4 = value4;
            debouncer6.update();
            int value6 = debouncer6.read();
            if (value6 != oldValue6 && value6 == 0) {
              send(msgRelay6.set(state6 ? false : true), true); // Send new state and request ack back
            oldValue6 = value6;
            debouncer7.update();
            int value7 = debouncer7.read();
            if (value7 != oldValue7 && value7 == 0) {
              send(msgRelay7.set(state7 ? false : true), true); // Send new state and request ack back
            oldValue7 = value7;
            debouncer5.update();
            int value5 = debouncer5.read();
            if (value5 != oldValue5)
              send(msgButton5.set(value5 == HIGH ? 1 : 0));
              oldValue5 = value5;
            if (blockMotionTimer == 0) {
              if (debouncerMotion.update()) {
                int valueMotion = debouncerMotion.read();
                Serial.println( "PIR " + (String)valueMotion );
                send( msgMotion.set( valueMotion ), true ); // Also it might need inverted value
                blockMotionTimer = (millis() + SLEEP_TIME);
              debouncerMotion.update(); // dummy update to prevent false trigger after timer expires
              if (blockMotionTimer < millis()) {
            if (message.isAck()) {
              switch (message.sensor) {
                case CHILD_ID_1:
                  state1 = message.getBool();
                  saveState(CHILD_ID_1, state1);
                case CHILD_ID_2:
                  state2 = message.getBool();
                case CHILD_ID_3:
                  state3 = message.getBool();
                  digitalWrite(RELAY3_PIN, state3 ? RELAY_ON : RELAY_OFF);
                  saveState(CHILD_ID_3, state3);
                case CHILD_ID_6:
                  state6 = message.getBool();
                  saveState(CHILD_ID_6, state6);
                case CHILD_ID_7:
                  state7 = message.getBool();
                  saveState(CHILD_ID_7, state7);
                default:
                  Serial.print("Incoming sensor unknown");
          • DickD Dick
            #define RELAY_ON 0
            #define RELAY_OFF 1
            int oldValue1 = 0;
            bool state1;
            int oldValue2 = 0;
            bool state2;
            int oldValue3 = 0;
            bool state3;
            int oldValue4 = 0;
            bool state4;
            int oldValue5 = 0;
            bool state5;
            int oldValue6 = 0;
            bool state6;
            int oldValue7 = 0;
            bool state7;
              // Setup the button
              oldValue1 = value1;
              oldValue2 = value2;
              oldValue3 = value3;
                oldValue4 = value4;
              oldValue6 = value6;
              oldValue7 = value7;
                oldValue5 = value5;
                  case CHILD_ID_1:
                  case CHILD_ID_2:
                  case CHILD_ID_3:
                  case CHILD_ID_6:
                  case CHILD_ID_7:
                  default:
            rejoe2R
            rejoe2R
            rejoe2
            wrote on last edited by rejoe2
            @Dick Please review your code wrt to the usage of arrays. To me, this kind of code is really unreadable, use for-loops is much more straight forward. There are at least some points that seem not working for me:
            • A5+A6 are pure analog pins and may not be used as digital in/outputs
            • the things you are doing in case of a keypress are not clear to me. You are not switching anything, but sending a state[x], which seems never to be updated (EDIT: this part seems to be ok)
            Just in case you plan to have an equal number of relays and buttons, you may just use the sketch in the link above and adopt the values for the in- and outputs using just digital-usabel pins and you are done...
            • rejoe2R rejoe2
              DickD
              DickD
              Dick
              @rejoe2 I take a good look at my code and put comments in it. I play around. again thanks for the advise
              • DickD Dick
                DickD
                DickD
                Dick
                @Dick Still try to get it working. What I have untill now, 5 working relais, where 2 can be activated with a button. Only the Binary Button will not work and is not visible in Domoticz, For this Binary Button I used the default script (https://www.mysensors.org/build/binary). If I can get this button work (better is 2 Binary Buttons, my project is finished. Who can help me!
