  3. loungeroom sketch transport failure
18 Posts 4 Posters 4.6k Views 3 Watching
  • markjgabbM markjgabb
    7778 MCO:SLP:WUP=-1
    9306 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.0
    T: 20.00
    9316 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:18.0
    H: 18.00
    Battery percent: -89 %
    10326 MCO:SLP:MS=120000,SMS=0,I1=255,M1=255,I2=255,M2=255
    10332 MCO:SLP:TPD
    this is my current log....
    so temp and hum is wrking...but my lux level keeps coming back 0 i think thats what its saying....can i insert more logging on that one to see how its doing the math?
    sundberg84S
    sundberg84S
    @markjgabb - ok, communication looks good! Great!
    It looks like you are not getting anything out of the sensor. Is it powered? Did you connect it to analog output? (Some sensors have both digital and analog out).
    There is not much else to log.
    You could do: Serial.println(LIGHT_SENSOR_ANALOG_PIN); to see the raw value (should be 0-1v). on the analog input.
    You can also measure the voltage coming on the analog output pin on the sensor and see.
    The battery measurment looks strange though... negative 89? :)
    • markjgabbM
      markjgabbM
      markjgabb
      wrote on last edited by markjgabb
      ok raw lux is 15
      good point...ive used a 47k resistor instead of a 470k, ill change that in the morning
      Raw Lux: 15
      send Lux: 0
      obviously a sensor error, ive moved the photo resistor into diffrent light like 4 times, and no change in reading
        ok raw lux is 15
        Raw Lux: 15
        send Lux: 0
        sundberg84S
        sundberg84S
        @markjgabb - if you can confirm that with a multimeter, its defenetly a error in the sensor... but verify because it can be a fault in the pro mini hardware/software as well.
        Raw lux (Serial.println(LIGHT_SENSOR_ANALOG_PIN);) should be between value 0 and 1023.
        I probably wrote wrong above though... if you are using a 5v pro mini, the input voltage range should be 0 to 5 volts
        • markjgabbM
          markjgabbM
          markjgabb
          nah its a 3.3 pro mini
          back
          • markjgabbM
            markjgabbM
            markjgabb
            photo resistor is now working...domoticz is showing varied amounts of reading though the night and morning....
            but its back to front....
            its reads 90ish in the middle of the night and this morning fluxuated between 50-10 and is now sitting at 30 with an empty house......did i math backwards? or is this expected behaviour due to the way the resistance works?
            in domoticz would i just use low values as my brightness
            Nca78N 1 Reply Last reply
              @markjgabb said in loungeroom sketch transport failure:
              Resistance gets lower when you have light. So higher when you have no light, meaning you have higher voltage when you measure voltage across the photoresistor.
              • Nca78N Nca78
                sundberg84S
                sundberg84S
                @Nca78 - what kind of sensor are you using? Or just a single photoresistor as Nca78 suggested?
                • markjgabbM
                  markjgabbM
                  markjgabb
                  just a single photoresistor,
                  i just wasnt sure if there was a way to reverse map the numbers so that if it says 1 it sends 99
                    sundberg84S
                    sundberg84S
                    @markjgabb - a single photoresistor can be extremly sensitive, ie 0 to full in a small change in light. There are alot of guides out there, just google around.
                    • markjgabbM
                      markjgabbM
                      markjgabb
                      @sundberg84 solved the light sensitivity level by swapping the 10k for a 100k...
                      makes it more acurate in lighter enviroments, but less so in dark enviroments
                      but by my theory after its a little dim im counting it as dark all the way to full dark for lighting purposes anyway
                      cheers for all your help....
