  3. loungeroom sketch transport failure
18 Posts 4 Posters 4.6k Views 3 Watching
  • markjgabbM markjgabb
    god i need new glasses...back to fornt capacitor on the antenna module....
    ok thanks guys...that parts resolved, now just gotta go though no parent found part....other devices in the same location works, just not this one...time to start swapping capacitors
    sundberg84S
    sundberg84S
    @markjgabb - no reply means the node can't find its way to the radio. Just as you are saying look over that you have all the right capacitors. Sometimes you need a 47uF capacitor instead of the 4,7uF on the radio. (Sometimes you need to try different ones).
    How do you power the node?
    • markjgabbM
      markjgabbM
      markjgabb
      its battery powered, i have the jumpers, i just got registration on node....but not all sensors are sending data....
      @sundberg84 would it be possible for you to review the below code....have i missed something?
      // Enable debug prints
      #define MY_NODE_ID 4
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_LIGHT 2
      #define HUMIDITY_SENSOR_DIGITAL_PIN 6
      #define LIGHT_SENSOR_ANALOG_PIN A1
      unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
      #define SKETCH_NAME "loungeroom living sensor #1"        // Change to a fancy name you like
      #define SKETCH_VERSION "1"                    // Your version
      DHT dht;
      float lastTemp;
      float lastHum;
      boolean metric = true;
      int LightLevel = 0;
      int lastLightLevel;
      MyMessage LightMsg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
        present(CHILD_ID_HUM, S_HUM);
        if (isnan(temperature)) {
          lastTemp = temperature;
          Serial.print("T: ");
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
        int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        Serial.println(lightLevel);
            send(LightMsg.set(lightLevel));
            lastLightLevel = lightLevel;
        batM();
         delay(500);
         // Battery monitoring reading
         delay(500);
         // Calculate the battery in %
         if (batLoop > 2) {
         if (batteryPcnt > 100) {
           batteryPcnt=100;
             batLoop = 0;
           batLoop++;
        DHT dht;
        float lastTemp;
        float lastHum;
        int LightLevel = 0;
        int lastLightLevel;
              lastHum = humidity;
          batM();
           delay(500);
           delay(500);
           if (batLoop > 2) {
             batteryPcnt=100;
               batLoop = 0;
             batLoop++;
        sundberg84S
        sundberg84S
        @markjgabb said in loungeroom sketch transport failure:
        This means it will only send if the value is changed... could that be the cause?
        Any logs from the node? Ack ok?
        • markjgabbM
          markjgabbM
          markjgabb
          wrote on last edited by markjgabb
          7778 MCO:SLP:WUP=-1
          9306 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.0
          T: 20.00
          9316 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:18.0
          H: 18.00
          Battery percent: -89 %
          10326 MCO:SLP:MS=120000,SMS=0,I1=255,M1=255,I2=255,M2=255
          10332 MCO:SLP:TPD
          this is my current log....
          so temp and hum is wrking...but my lux level keeps coming back 0 i think thats what its saying....can i insert more logging on that one to see how its doing the math?
            7778 MCO:SLP:WUP=-1
            T: 20.00
            H: 18.00
            10332 MCO:SLP:TPD
            sundberg84S
            sundberg84S
            @markjgabb - ok, communication looks good! Great!
            It looks like you are not getting anything out of the sensor. Is it powered? Did you connect it to analog output? (Some sensors have both digital and analog out).
            There is not much else to log.
            You could do: Serial.println(LIGHT_SENSOR_ANALOG_PIN); to see the raw value (should be 0-1v). on the analog input.
            You can also measure the voltage coming on the analog output pin on the sensor and see.
            The battery measurment looks strange though... negative 89? :)
            • markjgabbM
              markjgabbM
              markjgabb
              ok raw lux is 15
              good point...ive used a 47k resistor instead of a 470k, ill change that in the morning
              Raw Lux: 15
              send Lux: 0
              obviously a sensor error, ive moved the photo resistor into diffrent light like 4 times, and no change in reading
                ok raw lux is 15
                Raw Lux: 15
                send Lux: 0
                sundberg84S
                sundberg84S
                @markjgabb - if you can confirm that with a multimeter, its defenetly a error in the sensor... but verify because it can be a fault in the pro mini hardware/software as well.
                Raw lux (Serial.println(LIGHT_SENSOR_ANALOG_PIN);) should be between value 0 and 1023.
                I probably wrote wrong above though... if you are using a 5v pro mini, the input voltage range should be 0 to 5 volts
                • markjgabbM
                  markjgabbM
                  markjgabb
                  nah its a 3.3 pro mini
                  back
                  • markjgabbM
                    markjgabbM
                    markjgabb
                    photo resistor is now working...domoticz is showing varied amounts of reading though the night and morning....
                    but its back to front....
                    its reads 90ish in the middle of the night and this morning fluxuated between 50-10 and is now sitting at 30 with an empty house......did i math backwards? or is this expected behaviour due to the way the resistance works?
                    in domoticz would i just use low values as my brightness
                    Nca78N 1 Reply Last reply
                      Resistance gets lower when you have light. So higher when you have no light, meaning you have higher voltage when you measure voltage across the photoresistor.
                      • Nca78N Nca78
                        sundberg84S
                        sundberg84S
                        @Nca78 - what kind of sensor are you using? Or just a single photoresistor as Nca78 suggested?
                        • markjgabbM
                          markjgabbM
                          markjgabb
                          just a single photoresistor,
                          i just wasnt sure if there was a way to reverse map the numbers so that if it says 1 it sends 99
                            sundberg84S
                            sundberg84S
                            @markjgabb - a single photoresistor can be extremly sensitive, ie 0 to full in a small change in light. There are alot of guides out there, just google around.
                            • markjgabbM
                              markjgabbM
                              markjgabb
                              @sundberg84 solved the light sensitivity level by swapping the 10k for a 100k...
                              makes it more acurate in lighter enviroments, but less so in dark enviroments
                              but by my theory after its a little dim im counting it as dark all the way to full dark for lighting purposes anyway
                              cheers for all your help....
