  2. Announcements
  • N
    N
    niehoff80
    Ok, I had same error as Oliviakrk & syotos on my Raspberry Pi 3 and I also tried the development release and that one works perfectly!
      mikkelox
      Hi I followed the instructions, but I can't get it to work, I have a Raspberry Pi 1 Rev1 with NRF24 connected following the instructions.
      First I configured it just using ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0 --soc=BCM2835 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-gateway=ethernet --my-port=5003
      I also tried with almost every combination but I always get the same errors.
      The idea is for it to be used as a standalone GW running from RPI with RF directly attached to it (SPI is enabled and I don't get any errors when compiling)
      I can send the logs if needed, any help will be welcome, thanks!
      mysgw: Starting gateway...
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: !TSM:INIT:TSP FAIL
      mysgw: TSM:FAIL:CNT=1
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:FAIL:RE-INIT
      mysgw: TSM:INIT
      mysgw: TSM:FAIL:CNT=2
      mysgw: TSM:FAIL:PDT
        Try latest mysensors version from development branch
          mikkelox
          Tried it and got the same output, I also tried with a different NRF24 just in case and doublechecked the connections. are the options I am using ok?
          ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0 --soc=BCM2835 --my-debug=enable --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-gateway=ethernet --my-port=5003
            mikkelox
            @gohan, Thank you! I got it to work. First I tried with the development branch and it didn't work either, then I used the following instructions https://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
            And when that didn't work either I rechecked the wiring which ended up being the reason for it to fail previously, "faulty wires".
            I got it to work with the master branch.
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:INIT:TSP OK
            mysgw: TSM:INIT:GW MODE
            mysgw: MCO:REG:NOT NEEDED
            • Z
              Z
              Zuhairi
              Sorry, just want to ask does anyone have the output of this gateway?
              gohanG 1 Reply Last reply
              • Z Zuhairi
                @Zuhairi the previous post?
                • Djames SuhankoD
                  Djames SuhankoD
                  Djames Suhanko
                  Hi.
                  I have a Raspberry Pi already configured as gateway, but I don't know how to interact with. I means, how can I read incoming data from? I tried open /dev/ttyMySensorsGateway as a common serial port but I got a message error:
                  cu: open (/dev/ttyMySensorsGateway): Permission denied
                  cu: /dev/ttyMySensorsGateway: Line in use
                  With 'ps ax' command I can see only '/usr/local/sbin/PiGatewaySerial -d' running as a deamon.
                  Could someone explain me what's ne next step for?
                    I'd compile it as ethernet gateway, follow the guide on how to configure the parameters, then you can use MySController (search the forum, there is a topic with download link) and use that to connect to it
                    Djames SuhankoD 1 Reply Last reply
                    • Djames SuhankoD Djames Suhanko
                      Hi.
                      Welcome to the MySensors community @Djames-Suhanko
                      It looks like you are using the Raspberry Pi gateway for MySensors 1.5. If you are just starting out, I suggest you use the gateway for the current version instead. Documentation: https://www.mysensors.org/build/raspberry
                      That version of the gateway has a debug mode where you can see the messages in the console.
                      The next step would be to select a controller. Information about this is available at https://www.mysensors.org/about/network
                        Djames SuhankoD
                        Djames SuhankoD
                        Djames Suhanko
                        @gohan Thank you to answer! Good tip, I will do that!
                          Djames SuhankoD
                          Djames SuhankoD
                          Djames Suhanko
                          @mfalkvidd Yes, I'm using 1.5. Thank you for suggest me the newer version. I will update it today!
                          • Djames SuhankoD
                            Djames SuhankoD
                            Djames Suhanko
                            wrote on last edited by Djames Suhanko
                            #605
                            Hello, all!
                            I read a lot of comments to find a solution to my problem, but seems it's something that I couldn't understand yet.
                            The old version was working in my Raspberry Pi using Raspbian Wheeze, so, to install the new version i updated my system until the latest version (Raspbian Stetch). I could compile MySensors, but I'm getting the common error when testing with mysgw -d:
                            "MYSGW: MCD:BGN INIT GW, CP=RNNG---,VER-2.1.1" and so on.
                            I used this parameters in configure:
                            ./configure --my-transport=nrf24 --my-gateway=ethernet
                            --my-port=5003 --my-controlle-ip-address=192.168.1.2
                            --my-gateway=mqtt --my-mqtt-publish-topic-prefix=mysensors-out
                            --my-mqtt-subscribe-topic-prefix=mysensors-in
                            --my-mqtt-client-id=mygateway1
                            I couldn't find a solution yet. Can someone help me?
                              Hello, all!
                              #606
                              @Djames-Suhanko MYSGW: MCD:BGN INIT GW, CP=RNNG---,VER-2.1.1 means that the gateway is starting up. It is not an error.
                              "controller" is misspelled in your configure command though.
                                @Djames-Suhanko I think you have to decide wether you want to make an ethernet or mqtt gateway, you can't specify both
                                • Djames SuhankoD
                                  Djames SuhankoD
                                  Djames Suhanko
                                  #608
                                  wow, it's was really fast! Thanks to answer. I'm use an ethernet interface. It's up but have no cable on their. I didn't install a controller yet, so, is there no problem yet, right?
                                  Sorry that, I'm really a newbie using MySensors.
                                  [updating]
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                    @Djames-Suhanko said in 💬 Building a Raspberry Pi Gateway:
                                    this also is not necessary. Also for now remove all these --my-gateway=mqtt --my-mqtt-publish-topic-prefix=mysensors-out
                                    and use it as ethernet gateway to keep it simple
                                    • Djames SuhankoD
                                      Djames SuhankoD
                                      Djames Suhanko
                                      Ok, I will try it right now!
                                      • E
                                        E
                                        erobot
                                        Hello folks,
                                        my past experience is using nrf24 library at https://github.com/Blavery/lib_nrf24, and i was able to send/receive "text" data (or "string" data) in between Raspi3 (master node) and Arduino (slave). And this is a big issue, because what i need is numerical data (float or integer), not text data, so Raspi 3 can process the numerical data (such as to do the plotting), and based on the processed data to make some decisions. My raspi 3 is controlling a moving robot. Can you advise appropriate nrf24 library for raspberry pi and Arduino, and sample codes for this kind of applicaitons? Thanks
                                        • E erobot
                                          Hello folks,
                                          Welcome to the MySensors community @erobot !
                                          Not sure how you found us, but the library we use here is...MySensors. It certanly does what you describe. The best way to start is to read how MySensors works at https://www.mysensors.org/about and then go on to the many build examples and build your first node.
