  3. NodeManager
  4. NodeManager v1.6-dev: comments and issues
14 Posts 3 Posters 5.7k Views 4 Watching
  • B
    B
    betonmoewe
    hi,
    yes, there is a value, but there is no output (presentation) of the value ... the bme sensor works perfect. Wy is this an "I" value and not a "F" like the other values?
    AWAKE
    TSL I=1 L=2521
    SEND D=0 I=1 C=1 T=37 S= I=2521 F=0.00
    BME I=2 T=24.76
    SEND D=0 I=2 C=1 T=0 S= I=0 F=24.76
    BME I=3 H=52.88
    SEND D=0 I=3 C=1 T=1 S= I=0 F=52.88
    BME I=4 P=1007.86
    SEND D=0 I=4 C=1 T=4 S= I=0 F=1007.86
    SLEEP 60s
    Best regards
    Frank (Betonmoewe)
    U 1 Reply Last reply
    • B betonmoewe
      hi,
      AWAKE
      TSL I=1 L=2521
      BME I=2 T=24.76
      BME I=3 H=52.88
      BME I=4 P=1007.86
      SLEEP 60s
      Best regards
      Frank (Betonmoewe)
      U
      U
      user2684
      wrote on last edited by user2684
      @betonmoewe the way I read it is a message of type 37 (V_LEVEL) whose value is 2521 has been sent to the controller. S, I and F correspond to string, integer and float and depending on the sensor a value is set to only one of those. So your reported light level is 2521. The BME sensor reports float values so 24.76 is under F. Does it make sense? Thanks
      • B
        B
        betonmoewe
        okok ... my fault ... you are right LUX is int not float ...
        but no reading is send (I use fhem as reciever):
        2017-08-13 18:57:18 Global global ATTR MYSENSOR_113 mode node
        2017-08-13 18:57:18 Global global ATTR MYSENSOR_113 version 2.1.1
        2017-08-13 18:57:18 MYSENSORS_DEVICE MYSENSOR_113 parentId: 110
        2017-08-13 18:57:18 MYSENSORS_DEVICE MYSENSOR_113 SKETCH_NAME: MultiSensor_NM
        2017-08-13 18:57:19 MYSENSORS_DEVICE MYSENSOR_113 batterylevel: 100
        2017-08-13 18:57:19 MYSENSORS_DEVICE MYSENSOR_113 temperature2: 24.84
        2017-08-13 18:57:19 MYSENSORS_DEVICE MYSENSOR_113 humidity3: 50.85
        2017-08-13 18:57:19 MYSENSORS_DEVICE MYSENSOR_113 pressure4: 1007.90
        no brightness1 and I have no idea ...
        Best regards
        Betonmoewe
        • B betonmoewe
          Best regards
          Betonmoewe
          U
          U
          user2684
          @betonmoewe mmm this is weird, as far as there is a:
          should imply send() has been called successfully. Any chance to check debug output in the gateway to ensure messages are actually delivered? Thanks
          • B
            B
            betonmoewe
            I will try tomorrow ...
            thanks for your help !
            • B
              B
              betonmoewe
              wrote on last edited by betonmoewe
              ok ... if I change V_LEVEL to V_LIGHT_LEVEL in NodeManager.cpp, I got a reading ... strange
              By the way: I have a small problem with the BME Sensor: pressure and forecast have both the same ID
              mapReading_forecast4 4 forecast
              mapReading_pressure4 4 pressure
              is this correct?
              I have got a forcast reading only one time :(
              Betonmoewe
              • B betonmoewe
                is this correct?
                Betonmoewe
                U
                U
                user2684
                @betonmoewe thanks, but according to https://www.mysensors.org/download/serial_api_20, V_LIGHT_LEVEL is for uncalibrated light level (0-100%) V_LEVEL for light level in lux. Anyway, glad you made it working for your setup.
                As for the duplicated child ID issue, this shouldn't happen (https://github.com/mysensors/NodeManager/blob/development/NodeManager.cpp#L3277). I wonder if you have reached the maximum number of child IDs, try increasing MAX_SENSORS (e.g. #define MAX_SENSORS 15) in your config.h. Thanks
                • A
                  ArduiSens
                  FYI
                  I already had report this in "https://forum.mysensors.org/topic/6534/nodemanager/100", but in that case I was already using V1.6-dev version.
                  *ArduiSens 4 days ago
                  @user2684, why does NodeManager take so many sketch memory?
                  e.g.
                  (#define BATTERY_MANAGER 1; #define DEBUG 1; #define MODULE_DS18B20 1)
                  sketch NodeManager RS485 config for DS18B20 --> 28730 bytes (93%) of program storage space. Maximum is 30720 bytes.
                  own sketch for RS485 SR04T --> 17078 bytes (55%) of program storage space. Maximum is 30720 bytes.
                  OK, DS18B20 and SR04T are not the same but DS18B20 is less complex, so 38% more memory is pretty much.*
                  MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
                  • A
                    ArduiSens
                    I see a problem when using setSleepSeconds / setPowerPins in combination with the serial RS485 option.
                    void before() {
                    Serial.begin(MY_BAUD_RATE);
                    nodeManager.setSleepSeconds(30);
                    nodeManager.setPowerPins(11,12,1000);
                    • Register below your sensors
                      nodeManager.registerSensor(SENSOR_DS18B20,3);
                    gives a temperature value of 7368:
                    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=22,pt=5,l=4,sg=0:7368
                    3;255;3;0;22;7368
                    RECV S=3 I=255 C=3 T=22 P=
                    void before() {
                    nodeManager.setReportIntervalSeconds(50);
                    gives a correct value:
                    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:19.75
                    3;1;1;0;0;19.75
                    RECV S=3 I=1 C=1 T=0 P=
                    • A ArduiSens
                      FYI
                      e.g.
                      U
                      U
                      user2684
                      @ArduiSens thanks, I'll keep track about this issue issue with this https://github.com/mysensors/NodeManager/issues/210
                      • A ArduiSens
                        void before() {
                        3;255;3;0;22;7368
                        void before() {
                        3;1;1;0;0;19.75
                        U
                        U
                        user2684
                        @ArduiSens do you have the full logs to share for the setSleepSeconds / setPowerPins issue? because from what you have posted, that 3;255;3;0;22;7368 should be a heartbeat response not the value of the temperature. Thanks!
