  3. Whitelist not wirking from sensor to gateway
26 Posts 2 Posters 5.6k Views 2 Watching
  • K
    K
    karelsmits
    Okay here is the gateway code:
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,0,249   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5487
    //#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    // Select soft/hardware signing method
    #define MY_SIGNING_SOFT //!< Software signing
    //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
    // Enable node whitelisting
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = 1,.serial = {0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD8}}} // for sensor
    //#define MY_SIGNING_NODE_WHITELISTING {{{.nodeId = GATEWAY_ADDRESS,.serial = {0x4E,0xD3,0xAD,0x93,0xC6,0xF2,0xC6,0xF3,0x25}},{.nodeId = 2,.serial = {0xDC,0x1E,0x7F,0x20,0x62,0x2F,0xD3,0x04,0x29}}}
     * @def MY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL
     * @brief Enable this to have gateway require all nodes in the network to sign messages sent to it. @ref MY_SIGNING_REQUEST_SIGNATURES must also be set.
     * Use this for maximum security, but be aware that every single node will have to be personalized before they can be used.
     * Note that if this is enabled, and whitelisting is also enabled, whitelisting will also be in effect for all nodes.
    #define MY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL
    Here is the Sensor-node code:
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    //#define MY_RS485
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define MY_NODE_ID 1
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD9}}} // for gateway
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    And here is the signing code at MyConfig.h:
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD9}},{.nodeId = 1,.serial = {0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD8}}}
    And this is pretty much Vanilla, as you can see.
    Thanks for your help!
    AnticimexA 1 Reply Last reply
    • K karelsmits
       * LED purposes:
      #define MY_SOFTSPI
      // Enable to UDP
      //#define MY_RS485
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      AnticimexA
      AnticimexA
      Anticimex
      @karelsmits I am not talking about your sketch, I am talking about the MySensors library.
      • K
        K
        karelsmits
        what files in the library do you mean?
        • K karelsmits
          AnticimexA
          AnticimexA
          Anticimex
          @karelsmits the one I mentioned above.
          However, I do notice one important thing here; you have made changes to MyConfig.h. You should not enable the flags for signing and whitelisting in that file. You do that in your sketch. If you have defined them in two places, you don't know which setting is used. Revert the signing settings you tweaked in MyConfig.h and use the settings in your sketches (the GW and the node).
          • K
            K
            karelsmits
            wrote on last edited by karelsmits
            Thank you so much for your help so far, especially the myconfig.h file that it should not be modified regarding signing.
            Now I have the following error:
            Gateway:
            0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.1.1
            0;255;3;0;9;TSM:INIT
            0;255;3;0;9;TSF:WUR:MS=0
            0;255;3;0;9;TSM:INIT:TSP OK
            0;255;3;0;9;TSM:INIT:GW MODE
            IP: 192.168.0.249
            0;255;3;0;9;MCO:BGN:STP
            0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            0;255;3;0;9;TSF:MSG:BC
            0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
            0;255;3;0;9;TSF:PNG:SEND,TO=0
            0;255;3;0;9;TSF:CKU:OK
            0;255;3;0;9;TSF:MSG:GWL OK
            0;255;3;0;9;Will not sign message for destination 1 as it does not require it
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            0;255;3;0;9;TSF:MSG:PINGED,ID=1,HP=1
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
            0;255;3;0;9;Mark node 1 as one that require signed messages
            0;255;3;0;9;Mark node 1 as one that do not require whitelisting
            0;255;3;0;9;Informing node 1 that we require signatures
            0;255;3;0;9;Informing node 1 that we do not require whitelisting
            0;255;3;0;9;Skipping security for command 3 type 15
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
            0;255;3;0;9;Skipping security for command 3 type 16
            0;255;3;0;9;SHA256: FA0CEF05B11135F19B646D3FA36FE1BCFCC8DAC1A3773BDC7900000000000000
            0;255;3;0;9;Skipping security for command 3 type 17
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:FA0CEF05B11135F19B646D3FA36FE1BCFCC8DAC1A3773BDC79
            0;255;3;0;9;Transmitted nonce
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=0,t=18,pt=0,l=5,sg=1:2.1.1
            0;255;3;0;9;Signature in message: 01EDFE67C83BA7ADD4B868950DA55ADF92E74C2D
            0;255;3;0;9;Message to process: 01002E0012FF322E312E31
            0;255;3;0;9;Current nonce: FA0CEF05B11135F19B646D3FA36FE1BCFCC8DAC1A3773BDC79AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 41EDFE67C83BA7ADD4B868950DA55ADF92E74C2D89903167166C396470C02F3E
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
            0;255;3;0;9;SHA256: D92FBB57AB79BCCC3E9452F7E4B876FFFBC7FE47C2AD0613C8AAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:D92FBB57AB79BCCC3E9452F7E4B876FFFBC7FE47C2AD0613C8
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
            0;255;3;0;9;Signature in message: 01815088794CC5704C5790821D82DFD0435B5A47B4FBC14C
            0;255;3;0;9;Message to process: 01000E2306FF00
            0;255;3;0;9;Current nonce: D92FBB57AB79BCCC3E9452F7E4B876FFFBC7FE47C2AD0613C8AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 1D815088794CC5704C5790821D82DFD0435B5A47B4FBC14C745AA2B639D4D9DA
            0;255;3;0;9;SHA256: E38FE6554A3AE6D02B91B69EE2B67602506D8308DB5D4EAF3EAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:E38FE6554A3AE6D02B91B69EE2B67602506D8308DB5D4EAF3E
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=5,sg=1:Relay
            0;255;3;0;9;Signature in message: 01E3BCEFCF2F06C922BD6D487BBA7E67C9B717BC
            0;255;3;0;9;Message to process: 01002E030BFF52656C6179
            0;255;3;0;9;Current nonce: E38FE6554A3AE6D02B91B69EE2B67602506D8308DB5D4EAF3EAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 4BE3BCEFCF2F06C922BD6D487BBA7E67C9B717BCF2852083854E7555620473AD
            0;255;3;0;9;SHA256: 2385BA03A156C8D203085EE05B480A4819CC88E82D9BA6209FAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:2385BA03A156C8D203085EE05B480A4819CC88E82D9BA6209F
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.0
            0;255;3;0;9;Signature in message: 01DDCD53799743889B645AC6524B32B4AEB4B71E368C
            0;255;3;0;9;Message to process: 01001E030CFF312E30
            0;255;3;0;9;Current nonce: 2385BA03A156C8D203085EE05B480A4819CC88E82D9BA6209FAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: F3DDCD53799743889B645AC6524B32B4AEB4B71E368CCE2BE60CC00E0AD2D183
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
            0;255;3;0;9;SHA256: F1048244D308662147413A8531A71EF5C5E241710A859D7562AAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F1048244D308662147413A8531A71EF5C5E241710A859D7562
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=0,t=3,pt=0,l=0,sg=1:
            0;255;3;0;9;Signature in message: 01E5C5B659AF41CC4B5C9315F94E1A22E2DF10FAD361061CB3
            0;255;3;0;9;Message to process: 010006000301
            0;255;3;0;9;Current nonce: F1048244D308662147413A8531A71EF5C5E241710A859D7562AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 4EE5C5B659AF41CC4B5C9315F94E1A22E2DF10FAD361061CB3DB7925952BFDAE
            0;255;3;0;9;SHA256: 24D0165B9B9152F2003597B3747DC61B9C67C595A1518C31BDAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:24D0165B9B9152F2003597B3747DC61B9C67C595A1518C31BD
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=22,sg=1:TemperatureAndHumidity
            0;255;3;0;9;Signature in message: 013E8E
            0;255;3;0;9;Message to process: 0100B6030BFF54656D7065726174757265416E6448756D6964697479
            0;255;3;0;9;Current nonce: 24D0165B9B9152F2003597B3747DC61B9C67C595A1518C31BDAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 513E8E942127E5E2D512CE288F2B7E6418B8809F69B8B1EAE20D97A4407F9C86
            0;255;3;0;9;SHA256: F95653815901C8FACA219583E9C6FEA53596238E460528DA6AAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F95653815901C8FACA219583E9C6FEA53596238E460528DA6A
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.1
            0;255;3;0;9;Signature in message: 01FD4A335914B1FA7065E23D2B0C98FFB67E06B582AA
            0;255;3;0;9;Message to process: 01001E030CFF312E31
            0;255;3;0;9;Current nonce: F95653815901C8FACA219583E9C6FEA53596238E460528DA6AAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 22FD4A335914B1FA7065E23D2B0C98FFB67E06B582AA0C8B3865B44CE9E1D49E
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
            0;255;3;0;9;SHA256: D356C66B145EA4E7DCF69EC5B3C20E38D6046C50A4FEACE71BAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:D356C66B145EA4E7DCF69EC5B3C20E38D6046C50A4FEACE71B
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=0,t=7,pt=0,l=0,sg=1:
            0;255;3;0;9;Signature in message: 01E7923AA716F2CE850EB4A27962F15BF36941D559BA1DCF45
            0;255;3;0;9;Message to process: 010006000700
            0;255;3;0;9;Current nonce: D356C66B145EA4E7DCF69EC5B3C20E38D6046C50A4FEACE71BAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: F4E7923AA716F2CE850EB4A27962F15BF36941D559BA1DCF45C1821C7AD8E479
            0;255;3;0;9;SHA256: E4DDE1558F406F93C24ACC4978B5DAD078700CB3E898D665BBAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:E4DDE1558F406F93C24ACC4978B5DAD078700CB3E898D665BB
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=1:
            0;255;3;0;9;Signature in message: 01D9D7F016D4900614542F96199D1C1848E66826E164117C3F
            0;255;3;0;9;Message to process: 010006000601
            0;255;3;0;9;Current nonce: E4DDE1558F406F93C24ACC4978B5DAD078700CB3E898D665BBAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 17D9D7F016D4900614542F96199D1C1848E66826E164117C3F91395B119DB817
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
            0;255;3;0;9;Skipping security for command 3 type 26
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
            0;255;3;0;9;Nonce requested from 1. Waiting...
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=17,pt=6,l=25,sg=0:70A5921ABD527FBF58E2644ACAC3EB9D7D190A1ECFA2B45BB4
            0;255;3;0;9;Nonce received from 1.
            0;255;3;0;9;Proceeding with signing...
            0;255;3;0;9;Message to process: 00010E231BFF01
            0;255;3;0;9;Current nonce: 70A5921ABD527FBF58E2644ACAC3EB9D7D190A1ECFA2B45BB4AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 417F60D164B7EF1EE9F5664945AEE360F44F196E52428D274230D8D0DB830028
            0;255;3;0;9;Signature in message: 017F60D164B7EF1EE9F5664945AEE360F44F196E52428D27
            0;255;3;0;9;Message signed
            0;255;3;0;9;Message to send has been signed
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
            0;255;3;0;9;SHA256: B946C285F3F5F9204731209AF33E759FF1F604EADDAC89BE1CAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:B946C285F3F5F9204731209AF33E759FF1F604EADDAC89BE1C
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=1:24.0
            0;255;3;0;9;Signature in message: 01E74C2A504B304F48E28201FBB2B85E10BD50EB
            0;255;3;0;9;Message to process: 01002EE100010000C04101
            0;255;3;0;9;Current nonce: B946C285F3F5F9204731209AF33E759FF1F604EADDAC89BE1CAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 69EB3E1CFCF0B6629300837110B152CA8F7A0E2D53A4C8BFEBE4903F1B090864
            0;255;3;0;9;Signature bad: 01EB3E1CFCF0B6629300837110B152CA8F7A0E2D
            0;255;3;0;9;Signature verification failed!
            0;255;3;0;9;!TSF:MSG:SIGN VERIFY FAIL
            0;255;3;0;9;SHA256: AC6CB618B3BB07F385D25228E62B753BF888DA6351087FD39DAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:AC6CB618B3BB07F385D25228E62B753BF888DA6351087FD39D
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=1:46.0
            0;255;3;0;9;Signature in message: 0151796D338A1717D7B544C78054CBE9E39D901D
            0;255;3;0;9;Message to process: 01002EE101000000384201
            0;255;3;0;9;Current nonce: AC6CB618B3BB07F385D25228E62B753BF888DA6351087FD39DAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: A54694E7B219D7065CFD2D3C449350372739185EAC6EE5376C0E10561344CB12
            0;255;3;0;9;Signature bad: 014694E7B219D7065CFD2D3C449350372739185E
            Node:
            3 MCO:BGN:BFR
            5 TSM:INIT
            6 TSF:WUR:MS=0
            13 TSM:INIT:TSP OK
            15 TSF:SID:OK,ID=1
            16 TSM:FPAR
            17 Will not sign message for destination 255 as it does not require it
            59 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            203 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            207 Skipping security for command 3 type 8
            211 TSF:MSG:FPAR OK,ID=0,D=1
            2066 TSM:FPAR:OK
            2067 TSM:ID
            2068 TSM:ID:OK
            2070 TSM:UPL
            2071 Will not sign message for destination 0 as it does not require it
            2079 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2096 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2101 Skipping security for command 3 type 25
            2105 TSF:MSG:PONG RECV,HP=1
            2107 TSM:UPL:OK
            2109 TSM:READY:ID=1,PAR=0,DIS=1
            2112 Signing required
            2114 Will not sign message for destination 0 as it does not require it
            2121 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
            2128 Waiting for GW to send signing preferences...
            2158 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
            2163 Skipping security for command 3 type 15
            2167 Mark node 0 as one that require signed messages
            2171 Mark node 0 as one that do not require whitelisting
            2181 Skipping security for command 3 type 16
            2186 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
            2192 Nonce requested from 0. Waiting...
            2225 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=0:FA0CEF05B11135F19B646D3FA36FE1BCFCC8DAC1A3773BDC79
            2234 Skipping security for command 3 type 17
            2238 Nonce received from 0.
            2240 Proceeding with signing...
            2334 Message signed
            2341 Message to send has been signed
            2348 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=18,pt=0,l=5,sg=1,ft=0,st=OK:2.1.1
            2354 Skipping security for command 3 type 16
            2361 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            2367 Nonce requested from 0. Waiting...
            2492 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:D92FBB57AB79BCCC3E9452F7E4B876FFFBC7FE47C2AD0613C8
            2501 Skipping security for command 3 type 17
            2505 Nonce received from 0.
            2508 Proceeding with signing...
            2601 Message signed
            2609 Message to send has been signed
            2615 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
            4621 Skipping security for command 3 type 16
            4627 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            4633 Nonce requested from 0. Waiting...
            4665 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:E38FE6554A3AE6D02B91B69EE2B67602506D8308DB5D4EAF3E
            4675 Skipping security for command 3 type 17
            4679 Nonce received from 0.
            4681 Proceeding with signing...
            4775 Message signed
            4783 Message to send has been signed
            4789 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=5,sg=1,ft=0,st=OK:Relay
            4795 Skipping security for command 3 type 16
            4802 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            4808 Nonce requested from 0. Waiting...
            4933 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:2385BA03A156C8D203085EE05B480A4819CC88E82D9BA6209F
            4942 Skipping security for command 3 type 17
            4946 Nonce received from 0.
            4950 Proceeding with signing...
            5043 Message signed
            5050 Message to send has been signed
            5056 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.0
            5062 Skipping security for command 3 type 16
            5069 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            5075 Nonce requested from 0. Waiting...
            5200 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:F1048244D308662147413A8531A71EF5C5E241710A859D7562
            5210 Skipping security for command 3 type 17
            5214 Nonce received from 0.
            5217 Proceeding with signing...
            5310 Message signed
            5317 Message to send has been signed
            5323 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=1,ft=0,st=OK:
            5329 Skipping security for command 3 type 16
            5336 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            5342 Nonce requested from 0. Waiting...
            5468 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:24D0165B9B9152F2003597B3747DC61B9C67C595A1518C31BD
            5477 Skipping security for command 3 type 17
            5481 Nonce received from 0.
            5483 Proceeding with signing...
            5577 Message signed
            5584 Message to send has been signed
            5591 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=1,ft=0,st=OK:TemperatureAndHumidity
            5599 Skipping security for command 3 type 16
            5605 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            5611 Nonce requested from 0. Waiting...
            5736 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:F95653815901C8FACA219583E9C6FEA53596238E460528DA6A
            5746 Skipping security for command 3 type 17
            5750 Nonce received from 0.
            5752 Proceeding with signing...
            5847 Message signed
            5854 Message to send has been signed
            5860 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.1
            5866 Skipping security for command 3 type 16
            5872 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            5878 Nonce requested from 0. Waiting...
            6003 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:D356C66B145EA4E7DCF69EC5B3C20E38D6046C50A4FEACE71B
            6013 Skipping security for command 3 type 17
            6018 Nonce received from 0.
            6020 Proceeding with signing...
            6114 Message signed
            6121 Message to send has been signed
            6127 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=1,ft=0,st=OK:
            6132 Skipping security for command 3 type 16
            6139 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            6146 Nonce requested from 0. Waiting...
            6270 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:E4DDE1558F406F93C24ACC4978B5DAD078700CB3E898D665BB
            6280 Skipping security for command 3 type 17
            6284 Nonce received from 0.
            6287 Proceeding with signing...
            6380 Message signed
            6387 Message to send has been signed
            6393 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=1,ft=0,st=OK:
            6400 MCO:REG:REQ
            6401 Skipping security for command 3 type 26
            6408 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
            6514 TSF:MSG:READ,0-0-1,s=255,c=3,t=16,pt=0,l=0,sg=0:
            6519 Skipping security for command 3 type 16
            SHA256: 70A5921ABD527FBF58E2644ACAC3EB9D7D190A1ECFA2B45BB400000000000000
            6539 Skipping security for command 3 type 17
            6551 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:70A5921ABD527FBF58E2644ACAC3EB9D7D190A1ECFA2B45BB4
            6561 Transmitted nonce
            6681 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=1:1
            HMAC: 71BFB4D075B6FC246460FC35C2173D8DBD366ABF0A6ED0C23FA2F84AC4293267
            Signature bad: 01BFB4D075B6FC246460FC35C2173D8DBD366ABF0A6ED0C2
            6782 Signature verification failed!
            6791 !TSF:MSG:SIGN VERIFY FAIL
            6794 MCO:BGN:STP
            6796 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
            6801 !MCO:SLP:REP
            7803 MCO:BGN:INIT OK,TSP=1
            7827 Skipping security for command 3 type 16
            7834 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            7840 Nonce requested from 0. Waiting...
            7872 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:B946C285F3F5F9204731209AF33E759FF1F604EADDAC89BE1C
            7881 Skipping security for command 3 type 17
            7885 Nonce received from 0.
            7888 Proceeding with signing...
            HMAC: 4BE74C2A504B304F48E28201FBB2B85E10BD50EB7C577F3F443691573796A4F6
            7982 Message signed
            7989 Message to send has been signed
            7995 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:24.0
            T: 24.00
            8002 Skipping security for command 3 type 16
            8008 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            8014 Nonce requested from 0. Waiting...
            8153 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:AC6CB618B3BB07F385D25228E62B753BF888DA6351087FD39D
            8162 Skipping security for command 3 type 17
            8166 Nonce received from 0.
            8169 Proceeding with signing...
            HMAC: EB51796D338A1717D7B544C78054CBE9E39D901D56F76EBA9A61CC753EFADB59
            8262 Message signed
            8269 Message to send has been signed
            8275 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=1,ft=0,st=OK:46.0
            H: 46.00
            8283 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            8288 !MCO:SLP:REP
            68311 Skipping security for command 3 type 16
            68317 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            68323 Nonce requested from 0. Waiting...
            68356 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:8A0A85658B3A6AA9ABBBDC34E3B6891159CF3BD3369A0334BA
            68365 Skipping security for command 3 type 17
            68369 Nonce received from 0.
            68372 Proceeding with signing...
            Message to process: 01002EE101000000344201
            Current nonce: 8A0A85658B3A6AA9ABBBDC34E3B6891159CF3BD3369A0334BAAAAAAAAAAAAAAA
            HMAC: 6D6A1E530B4840BFF51DD3D926CEE1761909EB6F458B16F0D7CF2EBBB48321CB
            Signature in message: 016A1E530B4840BFF51DD3D926CEE1761909EB6F
            68465 Message signed
            68473 Message to send has been signed
            68482 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=1,ft=0,st=OK:45.0
            H: 45.00
            68489 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            68494 !MCO:SLP:REP
            This is without using whitelisting, just signing. The node and gateway are both working in regular mode. I am able to send a command through Domoticz to turn on/off the relay and also see the temperature sensor attached to the same arduino.
            All I added to the scetches of the GW and node was the following:
            #define MY_SIGNING_SOFT_RANDOMSEED_PIN A5 //!< Unconnected analog pin for random seed
            // SETTINGS FOR MY_SIGNING_ATSHA204
            //#define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached
            What step am I missing?
            AnticimexA 3 Replies Last reply
            • K karelsmits
              Gateway:
              IP: 192.168.0.249
              Node:
              3 MCO:BGN:BFR
              5 TSM:INIT
              6 TSF:WUR:MS=0
              13 TSM:INIT:TSP OK
              15 TSF:SID:OK,ID=1
              16 TSM:FPAR
              2066 TSM:FPAR:OK
              2067 TSM:ID
              2068 TSM:ID:OK
              2070 TSM:UPL
              2107 TSM:UPL:OK
              2334 Message signed
              2601 Message signed
              4775 Message signed
              5043 Message signed
              5310 Message signed
              5577 Message signed
              5847 Message signed
              6114 Message signed
              6380 Message signed
              6400 MCO:REG:REQ
              6794 MCO:BGN:STP
              6801 !MCO:SLP:REP
              7982 Message signed
              T: 24.00
              8262 Message signed
              H: 46.00
              8288 !MCO:SLP:REP
              H: 45.00
              68494 !MCO:SLP:REP
              AnticimexA
              AnticimexA
              Anticimex
              @karelsmits Any configuration settings you do in your sketch MUST be placed before
              • K karelsmits
                Gateway:
                IP: 192.168.0.249
                Node:
                3 MCO:BGN:BFR
                5 TSM:INIT
                6 TSF:WUR:MS=0
                13 TSM:INIT:TSP OK
                15 TSF:SID:OK,ID=1
                16 TSM:FPAR
                2066 TSM:FPAR:OK
                2067 TSM:ID
                2068 TSM:ID:OK
                2070 TSM:UPL
                2107 TSM:UPL:OK
                2334 Message signed
                2601 Message signed
                4775 Message signed
                5043 Message signed
                5310 Message signed
                5577 Message signed
                5847 Message signed
                6114 Message signed
                6380 Message signed
                6400 MCO:REG:REQ
                6794 MCO:BGN:STP
                6801 !MCO:SLP:REP
                7982 Message signed
                T: 24.00
                8262 Message signed
                H: 46.00
                8288 !MCO:SLP:REP
                H: 45.00
                68494 !MCO:SLP:REP
                AnticimexA
                AnticimexA
                Anticimex
                @karelsmits Also, you cannot have the same whitelist on both GW and node. Each have their own serial, and nodeId so they have different whitelists. You had this in your original settings. They were correct and in line with the personalization data you provided.
                Just make sure that these settings take place before including MySensors.h and make sure you don't have settings in MyConfig.h that would override the settings you do in your sketch,
                • K karelsmits
                  Gateway:
                  IP: 192.168.0.249
                  Node:
                  3 MCO:BGN:BFR
                  5 TSM:INIT
                  6 TSF:WUR:MS=0
                  13 TSM:INIT:TSP OK
                  15 TSF:SID:OK,ID=1
                  16 TSM:FPAR
                  2066 TSM:FPAR:OK
                  2067 TSM:ID
                  2068 TSM:ID:OK
                  2070 TSM:UPL
                  2107 TSM:UPL:OK
                  2334 Message signed
                  2601 Message signed
                  4775 Message signed
                  5043 Message signed
                  5310 Message signed
                  5577 Message signed
                  5847 Message signed
                  6114 Message signed
                  6380 Message signed
                  6400 MCO:REG:REQ
                  6794 MCO:BGN:STP
                  6801 !MCO:SLP:REP
                  7982 Message signed
                  T: 24.00
                  8262 Message signed
                  H: 46.00
                  8288 !MCO:SLP:REP
                  H: 45.00
                  68494 !MCO:SLP:REP
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @karelsmits
                  I have checked your most recent log and it looks very strange. Signatures are correctly verified in one direction but not the other.
                  I honestly have no explanation for how this is possible.
                  Could you try the beta version? That I have verified myself to be working.
                  But be advised; you will have to re-run the personalization procedure if you do that. Details are here.
                  The beta also provide some other security related options that you could try.
                  Firstly I recommend that you define MY_SIGNING_WEAK_SECURITY since security is a bit tighter for the next release (a GW will remember and not reset the signing preferences of a node unless that flag is set, and that could be a pain when testing signing but not committing to stick with it).
                  • K
                    K
                    karelsmits
                    okay will do and post you. thank again.
                    BTW where do i find the beta link?
                    • K
                      K
                      karelsmits
                      sorry, but do you mind pointing the beta link you're referring to?
                      thanks.
                      • K karelsmits
                        thanks.
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @karelsmits
                        https://github.com/mysensors/MySensors/archive/development.zip
                        • K
                          K
                          karelsmits
                          Hi, thanks for your help so far.
                          I am usinf the version you recommended. Now the signing seems to work, because I get a confirmation message from the gateway and the node. For some reason the gateway reports that the connection is dropped, it keeps on happening. What is wrong?
                          I am only using signing, not whitelisting
                          When signing is disabled, everything is working.
                          Just FYI,I did not change anything in MyConfig.h
                          Gateway:
                          __  __       ____
                                  |___/                      2.2.0-beta
                          17 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.2.0-beta
                          49 SGN:PER:OK
                          79 SGN:INI:BND OK
                          81 TSM:INIT
                          82 TSF:WUR:MS=0
                          90 TSM:INIT:TSP OK
                          91 TSM:INIT:GW MODE
                          93 TSM:READY:ID=0,PAR=0,DIS=0
                          96 MCO:REG:NOT NEEDED
                          IP: 192.168.0.249
                          1398 MCO:BGN:STP
                          1400 MCO:BGN:INIT OK,TSP=1
                          2089 TSF:MSG:READ,9-9-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          2095 TSF:MSG:BC
                          2097 TSF:MSG:FPAR REQ,ID=9
                          2099 TSF:CKU:OK,FCTRL
                          2101 TSF:MSG:GWL OK
                          2158 SGN:SKP:MSG CMD=3,TYPE=8
                          2164 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          4141 TSF:MSG:READ,9-9-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          4146 SGN:SKP:MSG CMD=3,TYPE=24
                          4149 TSF:MSG:PINGED,ID=9,HP=1
                          4151 SGN:SKP:MSG CMD=3,TYPE=25
                          4158 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                          4180 TSF:MSG:READ,9-9-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                          4186 SGN:SKP:MSG CMD=3,TYPE=15
                          4189 SGN:PRE:SGN REQ,FROM=9
                          4192 SGN:PRE:SGN REQ,TO=9
                          4194 SGN:PRE:WHI NREQ,TO=9
                          4196 SGN:SKP:MSG CMD=3,TYPE=15
                          4201 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                          4207 SGN:PRE:XMT,TO=9
                          4215 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                          4220 SGN:SKP:MSG CMD=3,TYPE=16
                          4238 SGN:SKP:MSG CMD=3,TYPE=17
                          4246 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                          4253 SGN:NCE:XMT,TO=0
                          4355 TSF:MSG:READ,9-9-0,s=255,c=0,t=17,pt=0,l=10,sg=1:2.2.0-beta
                          4361 SGN:BND:NONCE=4F5AD49AA0F433BE26060A9B1C55F23CC577EA281775DC0B02AAAAAAAAAAAAAA
                          4448 SGN:BND:HMAC=78CCB5B0692D9B11DDE1FFB97C0DE0A17040DD6D55BC5BF357163635ACAAE484
                          4456 SGN:VER:OK
                          4458 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                          4462 SGN:SKP:MSG CMD=3,TYPE=16
                          4480 SGN:SKP:MSG CMD=3,TYPE=17
                          4486 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                          4492 SGN:NCE:XMT,TO=0
                          4594 TSF:MSG:READ,9-9-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                          4599 SGN:BND:NONCE=A7CA0C7EF09F65DE5D02E9351E48E2A3D6DBF3537ECCF333F4AAAAAAAAAAAAAA
                          4686 SGN:BND:HMAC=E731F01B8DF928A36DACBBCDE45651A4B7BE0B1D1248FAB2936CADC0BE85B9AF
                          4694 SGN:VER:OK
                          6606 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                          6611 SGN:SKP:MSG CMD=3,TYPE=16
                          6628 SGN:SKP:MSG CMD=3,TYPE=17
                          6634 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                          6641 SGN:NCE:XMT,TO=0
                          6743 TSF:MSG:READ,9-9-0,s=255,c=3,t=11,pt=0,l=11,sg=1:Secure Lock
                          6749 SGN:BND:NONCE=CFCF368C893918E8B30F5BB9BD05BE2137CE6BC1C9D0A0C46AAAAAAAAAAAAAAA
                          6836 SGN:BND:HMAC=E8CCAAE5D1577EFAE089947D520345555DF0A2A7038CDB17E8B9D897C41B5137
                          6844 SGN:VER:OK
                          6846 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                          6850 SGN:SKP:MSG CMD=3,TYPE=16
                          6867 SGN:SKP:MSG CMD=3,TYPE=17
                          6874 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                          6880 SGN:NCE:XMT,TO=0
                          6985 TSF:MSG:READ,9-9-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.0
                          6990 SGN:BND:NONCE=81349D41F58F0A4219206D8C6A6C5CD822CD125BA0E22C1D08AAAAAAAAAAAAAA
                          7077 SGN:BND:HMAC=144CC1F339C5D15BADE41B8CB8EC95FC6AAA37249EB4198169206F8D2116B6C0
                          7085 SGN:VER:OK
                          7087 TSF:MSG:READ,9-9-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                          7092 SGN:SKP:MSG CMD=3,TYPE=16
                          7109 SGN:SKP:MSG CMD=3,TYPE=17
                          7114 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                          7121 SGN:NCE:XMT,TO=0
                          7224 TSF:MSG:READ,9-9-0,s=1,c=0,t=19,pt=0,l=14,sg=1:SecureActuator
                          7230 SGN:BND:NONCE=80764434FE2DB0B952CE5DB13822E08EA76E4CC32848155EBCAAAAAAAAAAAAAA
                          7317 SGN:BND:HMAC=7EBFF55E368306D2C1E9A0339DED228E80A0887140052FA13AABF1E5FE533218
                          7324 SGN:VER:OK
                          7326 TSF:MSG:READ,9-9-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                          7331 SGN:SKP:MSG CMD=3,TYPE=26
                          7334 SGN:SKP:MSG CMD=3,TYPE=16
                          7340 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                          7346 SGN:SGN:NCE REQ,TO=9
                          9250 TSF:MSG:READ,9-9-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                          9255 SGN:SKP:MSG CMD=3,TYPE=26
                          9259 SGN:SKP:MSG CMD=3,TYPE=16
                          9264 TSF:MSG:SEND,58-80-9-77,s=67,c=7,t=32,pt=2,l=10,sg=0,ft=0,st=OK:17485
                          9270 SGN:SGN:NCE REQ,TO=9
                           __  __       ____
                                  |___/                      2.2.0-beta
                          18 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.2.0-beta
                          50 SGN:PER:OK
                          77 SGN:INI:BND OK
                          79 TSM:INIT
                          80 TSF:WUR:MS=0
                          88 TSM:INIT:TSP OK
                          90 TSM:INIT:GW MODE
                          91 TSM:READY:ID=0,PAR=0,DIS=0
                          94 MCO:REG:NOT NEEDED
                          IP: 192.168.0.249
                          1397 MCO:BGN:STP
                          1398 MCO:BGN:INIT OK,TSP=1
                          1988 TSF:MSG:READ,9-9-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                          1993 SGN:SKP:MSG CMD=3,TYPE=26
                          1996 SGN:SKP:MSG CMD=3,TYPE=16
                          2000 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                          2007 SGN:SGN:NCE REQ,TO=9
                          2030 TSF:MSG:READ,9-9-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                          2035 SGN:SKP:MSG CMD=3,TYPE=17
                          2038 SGN:NCE:FROM=9
                          2040 SGN:NCE:15!=9 (DROPPED)
                           __  __       ____
                                  |___/                      2.2.0-beta
                          51 SGN:PER:OK
                          80 SGN:INI:BND OK
                          82 TSM:INIT
                          83 TSF:WUR:MS=0
                          91 TSM:INIT:TSP OK
                          92 TSM:INIT:GW MODE
                          94 TSM:READY:ID=0,PAR=0,DIS=0
                          97 MCO:REG:NOT NEEDED
                          IP: 192.168.0.249
                          1399 MCO:BGN:STP
                          1401 MCO:BGN:INIT OK,TSP=1
                          1956 TSF:MSG:READ,9-9-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                          1961 SGN:SKP:MSG CMD=3,TYPE=26
                          1965 SGN:SKP:MSG CMD=3,TYPE=16
                          1969 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                          1975 SGN:SGN:NCE REQ,TO=9
                          1998 TSF:MSG:READ,9-9-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                          2003 SGN:SKP:MSG CMD=3,TYPE=17
                          2007 SGN:NCE:FROM=9
                          2009 SGN:NCE:7!=9 (DROPPED)
                           __  __       ____
                                  |___/                      2.2.0-beta
                          51 SGN:PER:OK
                          79 SGN:INI:BND OK
                          81 TSM:INIT
                          82 TSF:WUR:MS=0
                          90 TSM:INIT:TSP OK
                          92 TSM:INIT:GW MODE
                          IP: 192.168.0.249
                          1399 MCO:BGN:STP
                          1965 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                          1969 SGN:SKP:MSG CMD=3,TYPE=16
                          1986 SGN:SKP:MSG CMD=3,TYPE=17
                          1991 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                          1998 SGN:NCE:XMT,TO=0
                          2101 TSF:MSG:READ,9-9-0,s=255,c=3,t=23,pt=0,l=3,sg=1:LDB
                          2107 SGN:BND:NONCE=82C773EAE20327A3D8AF62421F246E67B56C3B228CA6370164AAAAAAAAAAAAAA
                          2194 SGN:BND:HMAC=52A2F9D7C90A5A8EB3B5820C654689041561D8FB42BCE89A7B9A91B3D73353E2
                          2201 SGN:VER:OK
                          Node:
                          __  __       ____
                                  |___/                      2.2.0-beta
                          17 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.2.0-beta
                          49 SGN:PER:OK
                          77 SGN:INI:BND OK
                          79 TSM:INIT
                          80 TSF:WUR:MS=0
                          88 TSM:INIT:TSP OK
                          89 TSF:SID:OK,ID=9
                          91 TSM:FPAR
                          92 SGN:SGN:NREQ=255
                          129 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2137 !TSM:FPAR:NO REPLY
                          2139 TSM:FPAR
                          2140 SGN:SGN:NREQ=255
                          2177 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4185 !TSM:FPAR:NO REPLY
                          4187 TSM:FPAR
                          4188 SGN:SGN:NREQ=255
                          4225 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4265 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          4270 SGN:SKP:MSG CMD=3,TYPE=8
                          4273 TSF:MSG:FPAR OK,ID=0,D=1
                          6233 TSM:FPAR:OK
                          6234 TSM:ID
                          6235 TSM:ID:OK
                          6237 TSM:UPL
                          6238 SGN:SKP:MSG CMD=3,TYPE=24
                          6242 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          6259 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          6263 SGN:SKP:MSG CMD=3,TYPE=25
                          6266 TSF:MSG:PONG RECV,HP=1
                          6269 TSM:UPL:OK
                          6270 TSM:READY:ID=9,PAR=0,DIS=1
                          6274 SGN:PRE:SGN REQ
                          6276 SGN:PRE:WHI NREQ
                          6278 SGN:SKP:MSG CMD=3,TYPE=15
                          6282 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                          6289 SGN:PRE:XMT,TO=0
                          6291 SGN:PRE:WAIT GW
                          6301 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                          6307 SGN:SKP:MSG CMD=3,TYPE=15
                          6309 SGN:PRE:SGN REQ,FROM=0
                          6312 SGN:SKP:MSG CMD=3,TYPE=16
                          6317 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                          6323 SGN:SGN:NCE REQ,TO=0
                          6347 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                          6352 SGN:SKP:MSG CMD=3,TYPE=17
                          6355 SGN:NCE:FROM=0
                          6358 SGN:BND:NONCE=4F5AD49AA0F433BE26060A9B1C55F23CC577EA281775DC0B02AAAAAAAAAAAAAA
                          6445 SGN:BND:HMAC=78CCB5B0692D9B11DDE1FFB97C0DE0A17040DD6D55BC5BF357163635ACAAE484
                          6452 SGN:SGN:SGN
                          6456 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=10,sg=1,ft=0,st=OK:2.2.0-beta
                          6463 SGN:SKP:MSG CMD=3,TYPE=16
                          6469 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                          6475 SGN:SGN:NCE REQ,TO=0
                          6586 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                          6592 SGN:SKP:MSG CMD=3,TYPE=17
                          6594 SGN:NCE:FROM=0
                          6596 SGN:BND:NONCE=A7CA0C7EF09F65DE5D02E9351E48E2A3D6DBF3537ECCF333F4AAAAAAAAAAAAAA
                          6684 SGN:BND:HMAC=E731F01B8DF928A36DACBBCDE45651A4B7BE0B1D1248FAB2936CADC0BE85B9AF
                          6691 SGN:SGN:SGN
                          6695 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
                          8702 SGN:SKP:MSG CMD=3,TYPE=16
                          8708 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                          8714 SGN:SGN:NCE REQ,TO=0
                          8734 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                          8740 SGN:SKP:MSG CMD=3,TYPE=17
                          8743 SGN:NCE:FROM=0
                          8745 SGN:BND:NONCE=CFCF368C893918E8B30F5BB9BD05BE2137CE6BC1C9D0A0C46AAAAAAAAAAAAAAA
                          8833 SGN:BND:HMAC=E8CCAAE5D1577EFAE089947D520345555DF0A2A7038CDB17E8B9D897C41B5137
                          8840 SGN:SGN:SGN
                          8844 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=11,sg=1,ft=0,st=OK:Secure Lock
                          8851 SGN:SKP:MSG CMD=3,TYPE=16
                          8857 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                          8863 SGN:SGN:NCE REQ,TO=0
                          8974 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                          8980 SGN:SKP:MSG CMD=3,TYPE=17
                          8982 SGN:NCE:FROM=0
                          8984 SGN:BND:NONCE=81349D41F58F0A4219206D8C6A6C5CD822CD125BA0E22C1D08AAAAAAAAAAAAAA
                          9071 SGN:BND:HMAC=144CC1F339C5D15BADE41B8CB8EC95FC6AAA37249EB4198169206F8D2116B6C0
                          9079 SGN:SGN:SGN
                          9086 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.0
                          9093 SGN:SKP:MSG CMD=3,TYPE=16
                          9098 TSF:MSG:SEND,9-9-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                          9104 SGN:SGN:NCE REQ,TO=0
                          9216 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                          9221 SGN:SKP:MSG CMD=3,TYPE=17
                          9224 SGN:NCE:FROM=0
                          9226 SGN:BND:NONCE=80764434FE2DB0B952CE5DB13822E08EA76E4CC32848155EBCAAAAAAAAAAAAAA
                          9313 SGN:BND:HMAC=7EBFF55E368306D2C1E9A0339DED228E80A0887140052FA13AABF1E5FE533218
                          9320 SGN:SGN:SGN
                          9324 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=19,pt=0,l=14,sg=1,ft=0,st=OK:SecureActuator
                          9332 MCO:REG:REQ
                          9333 SGN:SKP:MSG CMD=3,TYPE=26
                          9339 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                          9441 TSF:MSG:READ,0-0-9,s=255,c=3,t=16,pt=0,l=0,sg=1:
                          9445 !TSF:MSG:PVER,1=2
                          11346 SGN:SKP:MSG CMD=3,TYPE=26
                          11352 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                          11364 TSF:MSG:READ,58-80-77,s=67,c=7,t=32,pt=2,l=10,sg=0:17485
                          11369 !TSF:MSG:PVER,3=2
                          13358 SGN:SKP:MSG CMD=3,TYPE=26
                          13363 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                          13374 TSF:MSG:READ,0-0-9,s=255,c=3,t=16,pt=0,l=0,sg=0:
                          13379 SGN:SKP:MSG CMD=3,TYPE=16
                          13382 SGN:NCE:LEFT=4
                          13399 SGN:SKP:MSG CMD=3,TYPE=17
                          13404 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                          13411 SGN:NCE:XMT,TO=9
                          15369 SGN:SKP:MSG CMD=3,TYPE=26
                          15374 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                          15385 TSF:MSG:READ,0-0-9,s=255,c=3,t=16,pt=0,l=0,sg=0:
                          15390 SGN:SKP:MSG CMD=3,TYPE=16
                          15393 SGN:NCE:LEFT=3
                          15410 SGN:SKP:MSG CMD=3,TYPE=17
                          15415 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                          15422 SGN:NCE:XMT,TO=9
                          17382 MCO:NLK:NODE LOCKED. TO UNLOCK, GND PIN 14 AND RESET
                          17387 SGN:SKP:MSG CMD=3,TYPE=16
                          17392 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                          17398 SGN:SGN:NCE REQ,TO=0
                          17420 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                          17425 SGN:SKP:MSG CMD=3,TYPE=17
                          17428 SGN:NCE:FROM=0
                          17430 SGN:BND:NONCE=82C773EAE20327A3D8AF62421F246E67B56C3B228CA6370164AAAAAAAAAAAAAA
                          17517 SGN:BND:HMAC=52A2F9D7C90A5A8EB3B5820C654689041561D8FB42BCE89A7B9A91B3D73353E2
                          17525 SGN:SGN:SGN
                          17529 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=23,pt=0,l=3,sg=1,ft=0,st=OK:LDB
                          17536 MCO:NLK:TSL
                          Thank you
                          • K
                            K
                            karelsmits
                            This is my node code regarding signing:
                            #define MY_NODE_ID 5
                            #define MY_DEBUG //!< Enable debug prints to serial monitor
                            #define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
                            #define MY_NODE_LOCK_FEATURE //!< Enable lockdown of node if suspicious activity is detected
                            #define MY_RADIO_NRF24 //!< NRF24L01 radio driver
                            //#define MY_RADIO_RFM69 //!< RFM69 radio driver
                            • K karelsmits
                              Gateway:
                              __  __       ____
                                      |___/                      2.2.0-beta
                              49 SGN:PER:OK
                              79 SGN:INI:BND OK
                              81 TSM:INIT
                              82 TSF:WUR:MS=0
                              90 TSM:INIT:TSP OK
                              91 TSM:INIT:GW MODE
                              IP: 192.168.0.249
                              1398 MCO:BGN:STP
                              2095 TSF:MSG:BC
                              2101 TSF:MSG:GWL OK
                              4456 SGN:VER:OK
                              4694 SGN:VER:OK
                              6844 SGN:VER:OK
                              7085 SGN:VER:OK
                              7324 SGN:VER:OK
                               __  __       ____
                                      |___/                      2.2.0-beta
                              50 SGN:PER:OK
                              77 SGN:INI:BND OK
                              79 TSM:INIT
                              80 TSF:WUR:MS=0
                              88 TSM:INIT:TSP OK
                              90 TSM:INIT:GW MODE
                              IP: 192.168.0.249
                              1397 MCO:BGN:STP
                              2038 SGN:NCE:FROM=9
                               __  __       ____
                                      |___/                      2.2.0-beta
                              51 SGN:PER:OK
                              80 SGN:INI:BND OK
                              82 TSM:INIT
                              83 TSF:WUR:MS=0
                              91 TSM:INIT:TSP OK
                              92 TSM:INIT:GW MODE
                              IP: 192.168.0.249
                              1399 MCO:BGN:STP
                              2007 SGN:NCE:FROM=9
                               __  __       ____
                                      |___/                      2.2.0-beta
                              51 SGN:PER:OK
                              79 SGN:INI:BND OK
                              81 TSM:INIT
                              82 TSF:WUR:MS=0
                              90 TSM:INIT:TSP OK
                              92 TSM:INIT:GW MODE
                              IP: 192.168.0.249
                              1399 MCO:BGN:STP
                              2201 SGN:VER:OK
                              Node:
                              __  __       ____
                                      |___/                      2.2.0-beta
                              49 SGN:PER:OK
                              77 SGN:INI:BND OK
                              79 TSM:INIT
                              80 TSF:WUR:MS=0
                              88 TSM:INIT:TSP OK
                              89 TSF:SID:OK,ID=9
                              91 TSM:FPAR
                              92 SGN:SGN:NREQ=255
                              2139 TSM:FPAR
                              4187 TSM:FPAR
                              6233 TSM:FPAR:OK
                              6234 TSM:ID
                              6235 TSM:ID:OK
                              6237 TSM:UPL
                              6269 TSM:UPL:OK
                              6355 SGN:NCE:FROM=0
                              6452 SGN:SGN:SGN
                              6594 SGN:NCE:FROM=0
                              6691 SGN:SGN:SGN
                              8743 SGN:NCE:FROM=0
                              8840 SGN:SGN:SGN
                              8982 SGN:NCE:FROM=0
                              9079 SGN:SGN:SGN
                              9224 SGN:NCE:FROM=0
                              9320 SGN:SGN:SGN
                              9332 MCO:REG:REQ
                              17525 SGN:SGN:SGN
                              17536 MCO:NLK:TSL
                              Thank you
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @karelsmits on beta with all debugging enabled and signing, code gets so large that the stack becomes too small. This can cause "cheap" gateways to crash and reboot. I am guessing you run some atmga328p based gw right?
                              Try to disable at least the verbose debug, possible all debug on the GW and it should run better.
                              • K
                                K
                                karelsmits
                                Dear Anticimex,
                                Thank you so much for helping out.
                                This is what I had to do to solve this:
                                I used the development edition of mysensors, I had to disable debugging, because indeed I use cheap boards. Then I also had to use the personalizer from the development and not change anything in the config file.
                                I just have 1 more question for now. Everything is secured for now, the only thing which isn’t, according to my understanding, is that any controller could communicate with my Ethernet gateway. Of course I could specify the ip address of the controller I want to use in the Ethernet gateway ino file configurations, but an ip address could easily be “doubled” either by causing an ip-conflict, or just plugging out or somehow disabling my controller.
                                So, the question is; how can a code or something be specified, besides the ipaddress, in the gateway. And with that security code only, the gateway will be able to be controlled by a controller device like eg Domoticz.
                                .Thank you.
                                • K karelsmits
                                  Dear Anticimex,
                                  .Thank you.
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @karelsmits great that you got it up and running at last!
                                  Regarding gateway security, the security of the library is limited to the OTA parts. It is assumed that you connect your gateway to a secure environment. Your LAN or USB host. If criminals can access your LAN you have a bigger problem than somebody spoofing your controller
                                  • K
                                    K
                                    karelsmits
                                    #25
                                    when it says in the gateway code:
                                    which mac address is this referring to? the gateway? the controller?
                                    And what happens if it doesn't match?
                                    thanks
                                    • K karelsmits
                                      thanks
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @karelsmits this is rather off topic. I suggest you move that question to a different thread as it has no relation to signing or security.
                                      12.5k
