  3. How to build an overridable MySensors relay based device (e.g. lamp with manual switch)
22 Posts 8 Posters 8.2k Views 9 Watching
  • A anonymouslemming
    @Boots33 said in How to build an overridable MySensors relay based device (e.g. lamp with manual switch):
    Do you need this to go through your controller? Usually the best way to treat a remote switch is to use direct node to node communication.
    The reason I was considering going via the controller is so that the controller stays in sync. My worry with communicating directly with the node is that then the controller will think that the light is on, when it's off, or vice versa.
    Perhaps you can give us a better idea of the physical layout of your setup, this may help us to suggest a more specific solution.
    For the initial prototype, it's a lamp that sits in the far corner of the lounge. Control is currently the in-line switch on the lamp cable. I'd like to place the local control switch somewhere near it, if not on the cable, then on the bookcase that the lamp sits on.
    The ethernet gateway is about 5m away from this switch and plug socket, with the controller running on a VM on the same ethernet network.
    Boots33B
    Boots33B
    Boots33
    wrote on last edited by Boots33
    @anonymouslemming said in How to build an overridable MySensors relay based device (e.g. lamp with manual switch):
    You can still notify the controller of the change but use node to node to activate the light. This is usually the simplest way to go. It also has the advantage that even if the controller is not available the light will still switch.
    Like i said having the switch connected to the node that controls the light is the most reliable way, but not always the most convenient.
    Where is the node that will control the light going to be. Are you fitting it inside the lamp or is it to be external?
    You may get some ideas from these posts
    AC-DC double solid state relay module
    Synchronising Light switch
    AC Power controller with node to node remotes
    Outdoors Touch Switch light controller
    A 1 Reply Last reply
    • Boots33B Boots33
      anonymouslemming
      @Boots33 said in [How to build an overridable MySensors relay based device
      Ok - I'll look into that.
      The node is going to be in a plug socket type device instead of in the lamp in some way. The lamp will plug into this socket. So I can't work out a way to conveniently have the local switch attached to that without being quite ugly and ungainly.
      It'll be external - built into a plug socket. I figured that gives me more space to work, much like the X10 equipment I'm replacing.
      Thanks - I'll have a look over those !
      • P
        P
        pouniok
        • G
          G
          ghiglie
          Hi! How did it end?
          Obtaining the WAF is the most part of my tinkering... I'm going for Sonoff ESP-based products to drive lights, mixing up the actuators via Home Assistant.
          atmega328p serial killer
          HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
          • G ghiglie
            Hi! How did it end?
            anonymouslemming
            @ghiglie
            It's stalled a bit due to work commitments. Prototype does everything EXCEPT keep the OpenHAB status in sync. I can control from openhab or from a separate node (that's just a switch).
            I need to update the code on the light node to keep openhab in sync and it'll be done. Then on to trying to build hardware that'll suit.
            G D 2 Replies Last reply
              @ghiglie
              G
              G
              ghiglie
              @anonymouslemming I understand. I'll track this topic! ;)
                @ghiglie
                doctor64
                @anonymouslemming Sorry for self-advertising, but i'm think my project https://forum.mysensors.org/topic/7417/ikea-varv-lamp-and-mysensors exactly what you wish - lamp with local control and, of course, OpenHab status automatically updated on flick a switch.
                • D doctor64
                  anonymouslemming
                  @doctor64
                  Hey - that does look really really good! I think I looked at it early in the project as inspiration.
                  The lamps I'm using (http://www.ikea.com/gb/en/products/lighting/table-lamps/fado-table-lamp-white-art-10096375/) have in-line switches and there's no sensible space in the body to mount anything, so I need something that controls power at the plug socket end.
                  I also want them at the plug socket end just for more flexibility in the longer term so that they can drive things other than just lamps.
                  D 1 Reply Last reply
                    @doctor64
                    doctor64
                    @anonymouslemming Hmm, you wish to use existing switch on mains cord? Or have some socket block with control is enough? I have use old one-for-all remote-controller socket for that - it have button, place for LED, nice case and i put inside arduino pro mini and 5 volt supply, using existing relay.
                    You are from Great Britain, right? So you have different power socket, but, may be you can find something similar?
                    • dbemowskD
                      dbemowskD
                      I use the in-wall switches that I designed to control sonoffs around the room. The switch is basically a MySensorized scene controller. It does not have any relays or do any other kind of local switching. It simply talks to my Vera controller and the Vera controller handles the logic. Surprisingly, from pushing the switch to the light turning on, it is a nearly unnoticeable fraction of a second. When you think about what has to happen, that is awesome.
                      When the switch is pushed, it sends a radio signal to the gateway which tells the Vera controller that I pushed the switch. The Vera controller looks up the logic from my programmed scene and sends a wifi HTTP request to my Sonoff. The Sonoff then needs to process that and turn on the relay. ALL OF THAT in a fraction of a second.
                      Oh, and the WAF is a thumbs up.
                      G A 2 Replies Last reply
                      • dbemowskD dbemowsk
                        G
                        G
                        ghiglie
                        @dbemowsk I was reading your thread... very inspirational. My main problem is can't change (for now!) the in-wall switches, so trying to figure out how to "decline" them.
                        dbemowskD 1 Reply Last reply
                        • G ghiglie
                          dbemowskD
                          dbemowskD
                          @ghiglie There can be some issues in replacing normal switches with these kinds of switches. The main thing with ones that I built require a 110v (would work with 220v) line in the box where the switch is going to be located. Depending when the house was constructed, some wall switch boxes only have the switch line coming to the box. If this is the case then you are trying to re-wire things up where the switched device (light, fan , etc...) is located to send your power through the old switched line. That can be a pain if you don't know what you are doing. When doing that kind of re-wiring, I recommend labels, labels, labels to tell how things should be re-wired if you need to get it back to the way it was.
                          One other issue you can run into is that the box may be too shallow to where the switch won't fit all the way in with the wire nuts or connectors. If that is the case, you may need to cut out the old box and replace it with a new one.
                          If you are comfortable with remodeling and house wiring, these may not be issues for you.
                            anonymouslemming
                            @dbemowsk
                            Hmm - that's interesting. I've been looking at the Sonoff stuff since you posted this, thanks!
                            One of my goals is to have no Internet connectivity to my devices, and it looks like there are some firmware options that would let me achieve that. So that's a plus.
                            The minus so far is that I can't find anything about range extenders / relay (signal, not power) for these. Two of my early use cases are out of WiFi range, so I'd like to be able to have something between the shed and the controller that acts as a relay. One of the things that attracted me to MySensors is that nodes can act as relays for other nodes.
                            Do you know if that's possible with Sonoff ?
                              @dbemowsk
                              dbemowskD
                              dbemowskD
                              @anonymouslemming I am not even sure this would work because I am not sure about how the 433MHz side of the Sonoff RF's work, but what about adding a repeater of some sort to your setup. Something like this
                              http://www.dx.com/p/dc-12v-2a-433mhz-ni-hi-wireless-signal-repeater-white-454782?tc=USD&gclid=CjwKCAjwranNBRBhEiwASu908AcpaXRztfgkD8tTEGI-DKxVMZWfywYffgjebQVSD5gl9fvpyAfcsBoCz1UQAvD_BwE#.WaqirHWGNpg
                              • D
                                drock1985
                                I know this may sound weird, but I would recommend just going with the basic Sonoff switch and skip the MySensors part.
                                I build a lamp controlled by MySensors a long time ago, has external Tact button for on/off. Works great, took a while to build and I have an ugly box screwed to my lamp now that houses it all.
                                I wanted to build another, but didn't want it be be aesthetically displeasing. I ended up using these (https://www.itead.cc/sonoff-wifi-wireless-switch.html) and they are everything in one small package. You have wifi, a tact button for manual on/off, and it will report to any home automation system using MQTT after flashing some customer firmware (https://github.com/arendst/Sonoff-Tasmota). Just cut the power cable, screw into appropriate terminals and it's all good to go.
                                As much as I love MySensors; for this type of project I think there is a better solution.
                                My Projects
                                2 Door Chime Sensor
                                Washing Machine Monitor
