  3. NRF24L01 SMD to DIP converter
19 Posts 6 Posters 6.9k Views 4 Watching
  • B bilbolodz
    @kalina Now "for real": I will be more than happy if you provide gerber files for PCB factory and thank you very much for you work.
    kalinaK
    kalinaK
    kalina
    @bilbolodz said in NRF24L01 SMD to DIP converter:
    Already added to project files.
    B 1 Reply Last reply
    • kalinaK kalina
      B
      B
      bilbolodz
      wrote on last edited by bilbolodz
      @kalina Thanks.
      At the begging quick question: are you sure that all is fine with drills? Some gerber renders in PCB factories show strange results (pcbs.io and oshpark.com).
      I've maid a quick research with comparison of cost (I've always took "the cheapest product and shipment option):
      • www.seeedstudio.com 10 pcs 4.90 USD + shipment 11.30 USD - (PCB max size 100 mm x 100m)
      • pcbs.io 4 pcs 1.50 USD + shipment free (probably problems with drills need to be checked more throughly)
      • oshpark.com 3 pcs 1.85USD + shipment free (probably problems with drills need to be checked more throughly)
      • dirtypcbs.com "protopack" (at least 10 pcs maybe more) 11.95 USD + 2 USD shipment (PCB max size 50mm x 50m, factory complaining after ZIP upload: "No board outline (.GML/.GKO/.GBR) file found")
      Of course it depends of "someone needs" but I think it could be a good idea to prepare "panelized version" with a few pcs of PCB which fits into PCB factory needs (dirtypcbs.com: 5cmx5cm, www.seeedstudio.com 10cmx10cm) for a "batch order" it should be more costs efficient.
      kalinaK 1 Reply Last reply
      • B bilbolodz
        @kalina Thanks.
        kalinaK
        kalinaK
        kalina
        Yes.
        For example, 20 pcs with delivery (to Poland) cost 11$ on PCBWay.
        • kalinaK kalina
          Yes.
          B
          B
          bilbolodz
          @kalina said in NRF24L01 SMD to DIP converter:
          I've never used PCBWay but I will add it to "my list".
          • B
            B
            bilbolodz
            What's the size of these PCB?
            • Nca78N
              10*10 cm on PCBWay
              You can also add elecrow, 5 boards with a max of 10*10cm for 5$, and I think I have seen a 5$ China Post shipping.
              • B
                B
                bilbolodz
                I mean: what is the size of @kalina designed PCB.
                • B bilbolodz
                  kalinaK
                  kalinaK
                  kalina
                  If you need get size for ordering - you can specify 15.2x15.5mm.
                  • B bilbolodz
                    @mfalkvidd Yes but it's ONLY for "normal version of SMD". Versions with PA have a little different pinout.
                    E
                    E
                    emc2
                    @bilbolodz Actually a PA+LNA version is on github (untested)
                    https://github.com/emc2cube/SMDnRF24_adapter/tree/master/PA_LNA
                    But yes, I did not update the openhardware part yet.
                    • A
                      antonio_clinton
                      Banned
                      If you want to order PCB, maybe try -Removed by moderator-. They provide rapid prototyping.
                      Their minimum order is at least one board, the board is of good quality.
                      To Poland about four or five days.
                      They now have activities. Can be paid on delivery.
