  3. WS2812B - Information LEDs blinking
2 Posts 2 Posters 1.3k Views 2 Watching
  • MiKaM
    MiKaM
    MiKa
    have someone idea how to easy convert standard 3 LEDs for information:
    example:
    // LEDs
    • Information LEDs blinking
      // If one of the following is defined here, or in the sketch, the pin will be used for the
      // corresponding led function.
      // They have to be enabled here (or in your sketch). Replace x with the pin number you have the LED on.
      // NOTE!! that on some platforms (for example sensebender GW) the hardware variant can enable LEDs by default,
      // These defaults can be overridden by defining one of these.
      #define MY_DEFAULT_ERR_LED_PIN 9
      #define MY_DEFAULT_TX_LED_PIN 6
      #define MY_DEFAULT_RX_LED_PIN 5
    to one WS2812B LED using Adafruit neopixel or FastLED library?
    Regards,
    MiKa
    • MiKaM MiKa
      example:
      // LEDs
      Regards,
      MiKa
      @MiKa this is not supported by default by the library.
      Using the indication callback however, it is possible.
      Have a look at this project to get some inspiration: https://www.openhardware.io/view/349/MySensors-ESP8266-MQTT-gateway
