  3. Battery level don't show up
dht22vera plugin 1.4pro miniverabattery powered
8 Posts 3 Posters 5.8k Views 1 Watching
  • C
    C
    cheesepower
    wrote on last edited by cheesepower
    Hello all,
    I encounter an issue with my battery powered sensor.
    It's based on an arduino pro mini 3,3 V, a DHT 22 and powered via a LiPo 3,7V battery.
    It runs on a Vera 3 with the 1.4 library.
    After inclusion, my vera see 1 node, 1 humidity sensor and 1 temperature sensor. The temperature and humidity are working fine, The problem is that the battery level don't show up :-(
    On th serial connection i can see my battery level.
    Here is my code:
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    unsigned long SLEEP_TIME = 300000; // Sleep time between reads (in milliseconds)
    int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    int oldBatteryPcnt = 0;
    gw.begin();
    gw.sendSketchInfo("Humidity", "1.0");
    gw.sendSketchInfo("Battery Meter", "1.0");
    //metric = gw.getConfig().isMetric;
    if (isnan(temperature)) {
    lastTemp = temperature;
    if (!metric) {
    Serial.print("T: ");
    if (isnan(humidity)) {
    lastHum = humidity;
    Serial.print("H: ");
    Serial.println(humidity);
    // get the battery Voltage
    Serial.println(sensorValue);
    float batteryV = sensorValue * 0.0041;
    Serial.print("Input Value: ");
    Serial.print(batteryV);
    Serial.println(" V");
    Serial.print(batteryPcnt);
    Serial.println(" %");
    // Power up radio after sleep
    oldBatteryPcnt = batteryPcnt;
    RJ_MakeR 1 Reply Last reply
    • C cheesepower
      Hello all,
      Here is my code:
      DHT dht;
      float lastTemp;
      float lastHum;
      gw.begin();
      if (!metric) {
      lastHum = humidity;
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @cheesepower I've notice that sometimes it take a while for the indicator to show up in Vera.
      RJ_Make
      • C
        C
        cheesepower
        My sensor runs for 2 weeks now.
        One more question : where did the battery level is supposed to be ? on the node under a variable or elsewhere ?
        • RJ_MakeR
          RJ_MakeR
          RJ_Make
          Looks like this.....
          RJ_Make
          • C
            C
            cheesepower
            I have this:
            http://img15.hostingpics.net/pics/796697vera.jpg
            • m26872M
              m26872M
              m26872
              wrote on last edited by m26872
              I assume you've done extensive resets, reloads, reboots of sensor, vera, luup, and gateway in all diffent ways?
              And a little dare to use custom device names before you get it going if you ask me.
              And yes, the battery level as a number is also visible under variables after first receive..
              • C cheesepower
                I have this:
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @cheesepower as @m26872 suggested, you should try a power cycle your equipment.. if that doesn't work...... you have a problem. I can't see any issue in the sketch.
                RJ_Make
                • C
                  C
                  cheesepower
                  Yes i made several reset, exclusions, inclusions, vera reset and clear EPROM but nothing worked...
                  I made a new sensor and it works perfectly
                  Strange... I will try again when i will have more time.
                  Thanks for the help :D
