  3. How to send MQTT message from controller to Node?
4 Posts 2 Posters 3.3k Views 3 Watching
  • siodS
    siodS
    siod
    I´ve set up a IR sender to control a RGB LED behind my TV. Now I want to communicate with this node using openhab and MQTT over NRF24. Unfortunately I have no idea how to send commands to a node, until now I was only sending informations from the Nodes/Sensors to the controller.
    So, I need to create functions for the Node like
    If command "ON/Off" received from openhab
    -send IR Command for ON/OFF
    If Command "Red" received from openhab
    -send IR Command for color red
    If Command "Fade" received from openhab
    -send IR Command for fading through colors
    I need to know how to send this from openhab or Mosquitto for example and especially how to catch these messages and process them in the Arduino code.
    I guess this is a beginners task but I have no idea where to start...
    Thanks for your help!
    still learning...
    maghacM 1 Reply Last reply
    • siodS siod
      maghacM
      maghacM
      maghac
      @siod Your mysensors gateway will handle this for you (assuming you have a MQTT gw, which I think you do since you can receive data from your mysensors nodes).
      Just send the correct MQTT message and the gateway will route it to the node. You then need to handle the message in the receive() function in your sketch.
      Have a look at https://forum.mysensors.org/topic/6765/rgb-led-strip, where I describe how I built my RGB lamp. It both sends and receives messages.
      • siodS
        siodS
        siod
        wrote on last edited by siod
        So, if I want to send HEX Values to the node, can I send them through openahb over MQTT like this (Node 2 / Sensor 2 / SET / NO ACK / V_IR_RECEIVE):
        Switch MQTTTestSwitch  "MQTT Test Switch"  (gBasement)  {mqtt=">[mysensor:mygateway1-in/2/2/1/0/33:command:ON:1E240],>[mysensor:mygateway1-in/2/2/1/0/33:command:OFF:1E249]"}  //????
        and pick it up on the node uisng the receive() function like this:
          if (message.type==V_IR_RECEIVE) {
             // Send command to Turn LEDs On
             if (message.getstring()==1E240){   // ???
                Irsend.NEC(1E240)   //send IR command using IRemote Library over IR LED attached to PIN 4
        Of course I could sned 1 or 0 to turn it On or Off, but when going to send color HEX Codes I thought I should start working whith HEX Codes from the beginning...
        still learning...
        • siodS
          siodS
          siod
          This the code I got so far, which does not work :(
          // Define Node ID
          #define MY_NODE_ID 5
          //#define MY_PARENT_NODE_ID 50 //Repeater Node 1!
          #include <IRremote.h>
          IRsend irsend;
          // Initialize motion message
          MyMessage msg(CHILD_ID, V_IR_SEND);
            Serial.begin(9600);
              sendSketchInfo("LED Licht TV Steuerung", "1.0");
              present(CHILD_ID, S_IR);
            if (message.type == V_IR_SEND) {
              if (message.getString() == "FF02FD") { // ???
                for (int i = 0; i < 3; i++) {
                  irsend.sendNEC(0xFF02FD, 32);
                  Serial.println("Message sent");
                  delay(40);
          edit: from the serial monitor I see that the node receives the "FF02FD" String, but it does not enter this part
                  delay(40);
          edit2:
          This is what I am sending from openhab over MQTT:
          mygateway1-in/5/1/1/0/32
          edit3:
          Ok, now I see where it fails:
          message.getString()
          contains FF02FD
          but when I say
          it does not recognise the FF02FD. But I don´t understand why
          edit4:
          Ok, I got it, finally...:
          message.getString("FF02FD");
          :astonished: :facepunch:
          still learning...
