  3. OpenHAB
  4. Openhab MQTT Example
openhab mqtt ex
49 Posts 8 Posters 74.9k Views 1 Watching
    Marcus
    Okay, i found the mistake.
    test.sitemap schould look like this:
    sitemap Test label="Menu"
    Frame label="MQTT"
    	Switch item=mqttsw1 label="MQTT Switch 1"
    	Switch item=mqttsw2 label="MQTT Switch 2"
    Now i can go on with testing.
      Marcus
      wrote on last edited by Marcus
      Now it looks like this.
      But i still have the problem that i cant see the position of my window switch.
      {mqtt=">[mysensor:/testsw/1:command:on:default],>[mysensor:/testsw/1:command:off:default]"}
      This line has to be modified i think. Plz tell me how it must be to show the status of my sensor-node.
      send: 20-20-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:0
      send: 20-20-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
      this is what the serial monitor from my sensor node prints.
      Can someone explain what this meesage mean?!
      • T
        tboha
        @Marcus .. I have to think about this. Meanwhile I would be interested in your OpenHab output concernig lines like these:
        15:19:49.599 DEBUG o.o.b.m.i.MqttItemBinding[:44] - Publishing command OFF to /tbtestm/1
        15:19:49.599 DEBUG o.o.i.t.m.i.MqttBrokerConnection[:437] - Publishing message 325 to topic '/tbtestm/1'
        You got some messages similar to this?
          Marcus
          Well u are back.
          pi@raspberrypi /opt/openhab $ sudo ./start.sh
          Launching the openHAB runtime...
          osgi> 2014-12-10 14:59:25.455 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been     started (v1.6.1).
          2014-12-10 14:59:45.668 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
          2014-12-10 14:59:46.488 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
          2014-12-10 14:59:46.589 [INFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
          2014-12-10 14:59:46.597 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mymqtt'
          2014-12-10 14:59:50.693 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'exec.persist'
          2014-12-10 14:59:55.287 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'logging.persist'
          2014-12-10 14:59:55.513 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist'
          2014-12-10 14:59:55.702 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
          2014-12-10 14:59:56.627 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.items'
          2014-12-10 15:00:10.357 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.script'
          2014-12-10 15:00:24.527 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.sitemap'
          2014-12-10 15:00:31.120 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
          2014-12-10 15:00:38.539 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
          2014-12-10 15:00:59.480 [INFO ] [.o.io.habmin.HABminApplication] - Started HABmin REST API at /services/habmin
          This happened when i activated/deactivated the switches in the "test-environment" on the webpage.
           2014-12-10 15:02:30.560 [INFO ] [runtime.busevents             ] - mqttsw1 received command ON
          2014-12-10 15:02:31.060 [INFO ] [runtime.busevents             ] - mqttsw1 received command OFF
          2014-12-10 15:02:31.969 [INFO ] [runtime.busevents             ] - mqttsw2 received command ON
           2014-12-10 15:02:32.736 [INFO ] [runtime.busevents             ] - mqttsw2 received command OFF
          This is everything it prints. but if i switch on the node it prints nothing.
          This must be simple problem with the item definition i think. But there are less examples where i can look an figure out how it works.
            Marcus
            Now I installed MyMQTT on my smartphone and connected it to my MQTT Gateway.
            If i activate and deactivate the switch on the node it prints this:
            MyMQTT/20/3/V_TRIPPED
            I hope this helps.
            • T
              tboha
              I forgot about the DEBUG part.
              <logger name="org.openhab" level="INFO"/>
              <logger name="org.openhab.binding.mqtt" level="DEBUG" />
              <logger name="org.openhab.io.transport.mqtt" level="DEBUG" />
              In File "logback.xml" look for the first line and insert the second and third line.
              This will lead to some additional infos in Openhabs output.
              I'm looking for some trace of successfully established connections between OpenHab and MQTT broker.
              If there is no connection the switch will show like you described above.
                Marcus
                I did what u said.
                This is what openhab says after start.
                 osgi> 2014-12-10 17:32:36.323 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.6.1).
                 2014-12-10 17:32:56.766 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
                 2014-12-10 17:32:57.084 [DEBUG] [.io.transport.mqtt.MqttService] - Starting MQTT Service...
                 2014-12-10 17:32:58.022 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
                 2014-12-10 17:32:58.139 [INFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
                 2014-12-10 17:32:58.154 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mymqtt'
                 2014-12-10 17:32:58.232 [DEBUG] [o.i.t.m.i.MqttBrokerConnection] - Creating new client for 'tcp://192.168.0.3:1883' using id 'MyMQTT' and file store '/tmp/mymqtt'
                 2014-12-10 17:33:01.703 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'exec.persist'
                 2014-12-10 17:33:04.772 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'logging.persist'
                 2014-12-10 17:33:05.181 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist'
                 2014-12-10 17:33:05.437 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
                 2014-12-10 17:33:06.092 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.items'
                 2014-12-10 17:33:29.493 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.sitemap'
                 2014-12-10 17:33:33.644 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.script'
                 2014-12-10 17:33:47.367 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
                 2014-12-10 17:33:53.419 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
                 2014-12-10 17:34:15.084 [INFO ] [.o.io.habmin.HABminApplication] - Started HABmin REST API at /services/habmin
                 2014-12-10 17:34:20.543 [DEBUG] [.b.mqtt.internal.MqttActivator] - MQTT binding has been started.
                 2014-12-10 17:34:20.703 [DEBUG] [b.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'mqttsw1' : 0 subscribers, 2 publishers
                 2014-12-10 17:34:20.722 [DEBUG] [b.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'mqttsw2' : 0 subscribers, 2 publishers
                 2014-12-10 17:34:20.794 [DEBUG] [m.internal.MqttEventBusBinding] - MQTT: Activating event bus binding.
                0 subscribers, 2 publishers???
                • T
                  tboha
                  This is not the expected result. Where does the second publisher come from?
                  But this result tells us that your broker and your connection are working fine, at least for output (regarded from the OpenHab side).
                  Toggling the switch should now result in a message like shown above ( "Publishing command....). This message should show up in your MyMQTT on your Smartphone.
                  Maybe I misunderstood your intentions. I thought you wanted to control some appliance with a switch from within OpenHab. This should work with the given example.
                  If you want to control a switch (e.g. MySensors BinarySwitchSensor) things get a little more complex. You need an inbound channel from the broker. A code example for this purpose can be found in http://forum.mysensors.org/topic/303/mqtt-broker-gateway. The following line implements this.
                  Switch node2_sw2  "sw2 send + recieve example"  (node2,all)      {mqtt=">[mysensor:MyMQTT/21/2/V_LIGHT:command:ON:1],>[mysensor:MyMQTT/21/2/V_LIGHT:command:OFF:0],<[mysensor:MyMQTT/21/2/V_LIGHT:command:MAP(1on0off.map)]"}
                  ( This will not fit for a switch - its only an example for inbound channels)
                  I tried this, but it was not successful. I got a Feed-back-loop blocking my OpenHab Server.
                  If you want to monitor your switch, the String Example some lines below could be an option.
                   String sketch20 "Switch 20 [%s]"  (sketch,all) {mqtt="<[mysensor:MyMQTT/20/3/V_TRIPPED:state:default]"}
                    Marcus
                    I only wanna see the state of the switch.
                    For example i wanna know if the window is open or not.
                    But the line does not work. i cannot see the state of the switch.
                    I used the example and edited the line u gave me in there:
                     Group all
                     Group node1  (all)
                     Group node2  (all)
                     Group sketch (all)
                     Number node1_temp  "Temp [%.1f °C]"     (node1,all)  {mqtt="<[mysensor:MyMQTT/20/10/V_TEMP:state:default]"}
                     Number node1_humid "Humid [%.1f %%Rh]" (node1,all)  {mqtt="<[mysensor:MyMQTT/20/11/V_HUM:state:default]"}
                     Switch node2_sw1  "sw2"  (node2,all)  {mqtt=">[mysensor:MyMQTT/21/1/V_LIGHT:command:ON:1],>[mysensor:MyMQTT/21/1/V_LIGHT:command:OFF:0]"}
                      String sketch20 "Switch name 20 [%s]"  (sketch,all) {mqtt="<[mysensor:MyMQTT/20/3/V_TRIPPED:state:default]"}
                    • T
                      tboha
                      I stripped my Openhab Installation to the bones and tried to run the example - now I'm getting strange errors like "InstantiationException on org.openhab.core.library.types.StringType"
                      It will take a while to check out the reasons this behavior.
                      If I change the MQTT-Topics by hand (e.g. with mosquitto_pub from the raspberry) with some String, they show up correct, if it's a number it won't. Strange.
                      • T
                        tboha
                        A little update. I couldn't figure out the reasons of this strange behavior, bus at least there exist a kind of workaround.
                        File mqtt.sitemap
                        sitemap mqtt label="MQTT-Test"
                         Frame label="MQTT"
                            Switch item=mqttsw1 label="MQTT Switch 1 (text)"
                            Text item=mqttsw1s
                            Switch item=mqttsw2 label="MQTT Switch 2 (raw)"
                            Text item=mqttsw2s
                            Switch item=mqttsw3 label="MQTT Switch 3 (string)"
                            Text item=mqttsw3s
                            Text item=sketch20
                        File mqtt.items
                        Switch mqttsw1 "MQTT Switch 1" (all,mqtt) {mqtt=">[mysensor:/testsw/1:command:on:RED],>[mysensor:/testsw/1:command:off:Green]"}
                        Switch mqttsw2 "MQTT Switch 2" (all,mqtt) {mqtt=">[mysensor:/testsw/2:command:off:default],>[mysensor:/testsw/2:command:on:default]"}
                         Switch mqttsw3 "MQTT Switch 3" (all,mqtt) {mqtt=">[mysensor:/testsw/3:command:*:Switch ${itemName} was turned ${command}]"}
                        String mqttsw1s "MQtt Switch 1 Status [%s]" (all,mqtt) {mqtt="<[mysensor:/testsw/1:state:default]"}
                         String mqttsw2s "MQtt Switch 2 Status [%s]" (all,mqtt) {mqtt="<[mysensor:/testsw/2:state:default]"}
                        String mqttsw3s "MQtt Switch 3 Status [%s]" (all,mqtt) {mqtt="<[mysensor:/testsw/3:state:default]"}
                         String sketch20 "Sketch name 20 [%s]"  (all,mqtt) {mqtt="<[mysensor:MyMQTT/20/255/V_SKETCH_NAME:state:default]"}
                        Switch 1 : default is replaced with RED/Green and this text is output to the topic /testsw/1.
                        Toggling this switch will result in RED/Green in the status field.
                        Switch 2: the original statement.
                        Toggling this switch will result in ON/OFF messages shown in the broker (e.g. MyMQTT)
                        Switch 3: copied from manual : https://github.com/openhab/openhab/wiki/MQTT-Binding
                        Toggling this switch will result in a well formed Message in status and broker.
                        This line resolves the secret of the 2 publishers : OpenHab counts every ">" as a separate publisher.
                        Furthermore the browser used seems to affect the results. It is mentioned somewhere in the documentation that browsers behave different. I'm using Opera 12.17 - for some items
                        manual refreshing is required. Chrome does this automatically.
                        However - the line "String sketch20....." should have been functional despite of all this. I can't see an obvious explanation for failure.
                        Maybe you can adapt the above skeleton files for your needs.
                          Marcus
                          Good morning.
                          I did what u said. But i dont see the status of my switch.
                           Switch mqttsw1 "MQTT Switch 1" (all,mqtt) {mqtt=">[mysensor:MyMQTT/20/3/V_TRIPPED:command:on:RED],>[mysensor:MyMQTT/20/3/V_TRIPPED:command:off:Green]"}
                          Switch mqttsw2 "MQTT Switch 2" (all,mqtt) {mqtt=">[mysensor:MyMQTT/20/3/V_TRIPPED:command:off:default],>[mysensor:MyMQTT/20/3/V_TRIPPED:command:on:default]"}
                          Switch mqttsw3 "MQTT Switch 3" (all,mqtt) {mqtt=">[mysensor:MyMQTT/20/3/V_TRIPPED:command:*:Switch ${itemName} was turned ${command}]"}
                          String mqttsw1s "MQtt Switch 1 Status [%s]" (all,mqtt) {mqtt="<[mysensor:MyMQTT/20/3/V_TRIPPED:state:default]"}
                          String mqttsw2s "MQtt Switch 2 Status [%s]" (all,mqtt) {mqtt="<[mysensor:MyMQTT/20/3/V_TRIPPED:state:default]"}
                          String mqttsw3s "MQtt Switch 3 Status [%s]" (all,mqtt) {mqtt="<[mysensor:MyMQTT/20/3/V_TRIPPED:state:default]"}
                          String sketch20 "Sketch name 20 [%s]"  (all,mqtt) {mqtt="<[mysensor:MyMQTT/20/3/V_TRIPPED:state:default]"}
                          The sitemap is the same as yours.
                          As u can see there is no red/green and no well formed text-message.
                          Thanks anyway! Would be very nice if we get this to work.
                          • T
                            tboha
                            It seems your broker does not response to OpenHab or the binding is not effective.
                            Your installation is different from mine - you are running OpenHab on your raspberry , I'm running OpenHab on my desktop.
                            We both use OpenHab 1.6.1.
                            Probably you are running your MQTT Broker (presumably mosquitto?) on your raspberry - so do I.
                            You are running MyMQTT on Android, so do I.
                            (by the way -- I am not able to publish something from MyMQTT despite MyMQTT says "Message published" - nothing arrives at the broker. You got similar experiences?)
                            For a basic debugging environment I use mosquitto_sub in an extra terminal on my Raspberry with
                            mosquitto_sub -t /#
                            which should show all messages arriving at the broker.
                            First test with mosquitto_pub in another terminal:
                            mosquitto_pub -t /testsw/1 -m "switch1"
                            If this Message shows up we got our topic instantiated (and the broker is working).
                            mosquitto_pub -t /testsw/1 -m "ON" -r
                            Now sending a retained message. If OpenHab connects to the broker, this message will be sent immediately
                            in the OpenHab log you should see this:
                            11:15:07.844 INFO  runtime.busevents[:26] - mqttsw1s state updated to switch1.
                            11:16:21.289 INFO  runtime.busevents[:26] - mqttsw1s state updated to ON
                            Toggling some switch should give the followin log:
                            12:00:03.976 DEBUG o.o.b.m.i.MqttItemBinding[:44] - Publishing command OFF to /testsw/1
                            12:00:03.991 DEBUG o.o.i.t.m.i.MqttBrokerConnection[:437] - Publishing message 6 to topic '/testsw/1'
                            12:00:03.994 INFO  runtime.busevents[:22] - mqttsw1 received command OFF
                            12:00:04.004 INFO  runtime.busevents[:26] - mqttsw1s state updated to Green
                            what does your log show?
                              Marcus
                              I use the MQTT Ethernet-Ethernet Gateway as broker http://www.mysensors.org/build/mqtt_gateway
                              And with MyMQTT on my Smartphone i can see that its working.
                              Later i will test the other thing.
                              • T
                                tboha
                                This may be the fault. The MQTT Gateway is not a broker - it is just a special form of client, it "only" translates messages from the MySensors network into MQTT acceptable forms an supplies Ethernet access. It does not perform any broker function.
                                To install a broker you should spend a little time with Mosquitto (http://mosquitto.org/) or http://jpmens.net/2013/09/01/installing-mosquitto-on-a-raspberry-pi/
                                In a short way: To install MQTT on your raspberry:
                                sudo apt-get update
                                sudo apt-get upgrade
                                to be up to date.
                                sudo apt-get install mosquitto mosquitto-clients
                                this should be enough to get your broker up and running with default parameters.
                                Replace the IP-adress in OpenHab accordingly and you should be done.
                                  Marcus
                                  Its not a broker????
                                  "The MQTT gateway is basically a Ethernet Gateway with modified software which makes it act as a MQTT broker. "
                                  This text in the build instructions has to be fixed. In no minute i thought about installing mosquitto.
                                  But i hope the installation of mosquitto will get it to work.
                                  JohnJ 1 Reply Last reply
                                  • M Marcus
                                    JohnJ
                                    JohnJ
                                    John
                                    wrote on last edited by John
                                    #21
                                    @Marcus It does act as a broker, only with very limited functions, you do not have to subscribe and also no QOS is done. But it is a broker.
                                    Just try to connect an mqtt client to it, and you will see messages being received by the client. (for example mqtt.fx)
                                      Marcus
                                      #22
                                      @John
                                      I use MyMQTT on my smartphone is this a client? There are messages coming in.
                                      Do i need mosquitto for make mysensors work with openhab or not. Thats the only thing that is interesting for me at the moment.
                                      • T
                                        tboha
                                        Hi Marcus, I have to confess I mingled up the names and got a little lack of information. I referred to something I tried several months ago - i didn't fit my needs, so I changed back to the serial Interface - which performed reasonably good and i lost contact to the MySensors-MQTT side via Ethernet.
                                        To my surprise i read there shall be some basic broker functionality in the Gateway sketch - which sounds really good. It will take a while to reactivate my Ethernetshield and give it a try. Sadly my holidays are over tomorrow and there will be not much spare time to test it.
                                        Nevertheless trying Mosquitto would be interesting, e.g. to talk to the MySensors broker directly and to check the OpenHab->Broker connectivity.
                                          Marcus
                                          Hmm, now i am nearly at the beginning. It would be nice if i dont need mosquitto.
                                          Maybe here are others who can help.
                                          Thank u anyway for ur help.
                                          Are we both the only who want to use openhab???
                                          Is there no other way to check if openhab recieves the messages from the broker (ethernet gateway)?
