  3. nRF5 Multi Sensor Board (12-14€)
52 Posts 24 Posters 30.7k Views 30 Watching
  • F
    F
    floe
    As usual, ask for something on a public forum and ~5 minutes later, I finally find it myself:
    http://linksprite.com/wiki/index.php5?title=Bluetooth_4.0_BLE_Sensor_Tag/iBeacon_Station_NRF51822
    • MiKaM
      MiKaM
      MiKa
      Have someone ready working arduino sketch for this board for sharing?
      P 1 Reply Last reply
      • d00616D d00616
        51822_ITC_PolyU_HK
        The "ITC PolyU HK" is one of the most interesting nRF5 Boards I have found. This board is useable with the upcoming MySensors 2.2 release. The radio can communicate with nRF24 networks.
        At eBay or aliexpress boards are available starting at 12€. The ob board hardware is:
        • nRF51822QFAA (Cortex-M0, 16kB RAM, 256kb Flash, SPI, I2C, UART...)
        • Two Buttons
        • one RGB LED
        • MPU6050 accelerometer
        • AP3216C distance and ambient light sensor
        • BMP180 pressure and temperature sensor
        • CR2032 Battery Holder
        At the moment I have decoded the layout. There is no arduino-nrf5 board definition. My idea is to build a repository of YAML based board definitions to generate board definitions without letting the list of arduino-nrf5 included boards growing.
        Issues:
        • Board is not supported by arduino-nrf5 at the moment
        • UART only available via two of the solder/contact pads
        • ~~Sleeping until pin interrupt consumes 1mA -> https://github.com/sandeepmistry/arduino-nRF5/issues/153~~
        When the arduino-nrf5 board definition is ready, I reply here.
        d00616D
        d00616D
        d00616
        @d00616 said in nRF5 Multi Sensor Board (12-14€):
        I have found some documentation. The high current consumption was listed as PAN#39 and is fixed with this MCU: http://infocenter.nordicsemi.com/pdf/nRF51822-pan_v3.0.pdf
        The MCU is nRF51822QFAAH0.
        Nca78N P 2 Replies Last reply
        • d00616D d00616
          I don't see the link with anomaly #39 ?
          But I see it #72 which is not fixed
          72. RTC: Writing to RTC registers without starting the LFCLK could lead to increased current consumption.
          Symptoms:
          Increased current consumption
          Conditions:
          Setting up the RTC by writing to its registers without starting the LFCLK
          Consequences:
          The user will experience an increase in the current consumption of ~1 mA
          Workaround:
          Always run the LFCLK for a minimum of one LFCLK clock cycle after writing to the RTC registers.
            @Nca78
            I think it was about the GPIOTE module and pin interrupts needing hfclk, so more power, #39, p.4, listed as fixed
            Nca78N 1 Reply Last reply
            • scalzS scalz
              @Nca78
              Thank you @scalz I took time for some reading about NRF51 (should have done that before posting stupid things... :blush: ) and it's much clearer now...
              My one and only NRF51822 has build code H0 so it seems I will not pull too many hair when trying to make it run at low power :)
              • MiKaM MiKa
                P
                P
                Ptibu
                wrote on last edited by Ptibu
                @MiKa Here is my sketch if it helps (MySensors v2.2.0-Beta). It uses ALS, BMP180 and RGB leds.
                Working well with my nRF24 LNA+PA GW.
                #include <Arduino.h>
                #define MY_BAUD_RATE 9600
                // Mode Radio / Enable and select radio type attached
                #define MY_RADIO_NRF5_ESB
                #define MY_NRF5_ESB_PA_LEVEL NRF5_PA_MAX
                #define MY_NODE_ID 6
                #include "MySensors.h"
                #include <Adafruit_BMP085.h>
                Adafruit_BMP085 bmp = Adafruit_BMP085();
                #define CHILD_ID_TEMP 0
                #define CHILD_ID_BARO  1
                #define CHILD_ID_ALS  2
                #define SLEEP_NODE true // True to activate Sleep Mode, but currently unsupported on esp8266
                unsigned long SLEEP_TIME = 120 * 1000; // Sleep time between reads (in milliseconds)
                #define RED_PIN 17
                #define GREEN_PIN 18
                #define BLUE_PIN 19
                #define COLOR_OFF     0
                #define COLOR_RED     1
                #define COLOR_GREEN   2
                #define COLOR_BLUE    4
                MyMessage msgBaro(CHILD_ID_BARO, V_PRESSURE);
                MyMessage msgForecast(CHILD_ID_BARO, V_FORECAST);
                MyMessage msgALS(CHILD_ID_ALS, V_LIGHT_LEVEL);
                void setColor (uint8_t c) {
                  digitalWrite (RED_PIN, !(c & COLOR_RED));
                  digitalWrite (GREEN_PIN, !(c & COLOR_GREEN));
                  digitalWrite (BLUE_PIN, !(c & COLOR_BLUE));
                  setColor (COLOR_RED);
                  setColor (COLOR_GREEN);
                  setColor (COLOR_BLUE);
                  Wire.begin();
                  pinMode (RED_PIN, OUTPUT);
                  pinMode (GREEN_PIN, OUTPUT);
                  pinMode (BLUE_PIN, OUTPUT);
                  delay(250);
                  delay(250);
                  delay(250);
                  setColor (COLOR_OFF);
                  /* BMP180.  */
                  if (!bmp.begin()) {
                    Serial.println("Could not find a valid BMP085 sensor, check wiring!");
                    while (1);
                void presentation()  {
                  sendSketchInfo("nrf Sensor TAG", "1.0.0");
                  // Sensor presentation to the GW
                  present(CHILD_ID_BARO, S_BARO);
                  present(CHILD_ID_ALS, S_LIGHT_LEVEL);
                void AP3216_write(uint8_t regAddress, uint8_t value) {
                  Wire.beginTransmission(0x1E); // I2C Address of AP3216 sensor is 0x1E
                  Wire.write(regAddress);
                  Wire.write(value);
                  Wire.endTransmission();
                uint8_t AP3216_read(uint8_t regAddress) {
                  Wire.requestFrom(0x1E, 1, true);
                  return Wire.read() & 0xFF;
                uint16_t readALS (void)
                  /* System mode: ALS function once */
                  AP3216_write (0x0, 0x5);
                  delay (250);
                  return ((uint16_t) AP3216_read (0xC) << 8) | AP3216_read (0xD);
                  send(msgTemp.set(bmp.readTemperature(), 1));
                  send(msgBaro.set(bmp.readPressure(), 1));
                  send(msgForecast.set(bmp.readSealevelPressure(834.0), 1));  /* Change altitude here !   */
                  send(msgALS.set(readALS(), 1));
                  delay (250);
                  if (SLEEP_NODE)
                    sleep(SLEEP_TIME);
                    delay (SLEEP_TIME);
                You also need to change SDA/SCL pins by creating a new board from the Generic nRF51 (or modifying it)
                In variant.h:
                #define PIN_WIRE_SDA         (9u)
                #define PIN_WIRE_SCL         (10u)
                d00616D 1 Reply Last reply
                • P Ptibu
                  #define RED_PIN 17
                  #define BLUE_PIN 19
                  #define COLOR_OFF     0
                  #define COLOR_RED     1
                    Wire.begin();
                    delay(250);
                    delay(250);
                    delay(250);
                    /* BMP180.  */
                    if (!bmp.begin()) {
                      while (1);
                    Wire.write(value);
                    delay (250);
                    delay (250);
                    if (SLEEP_NODE)
                      sleep(SLEEP_TIME);
                      delay (SLEEP_TIME);
                  In variant.h:
                  d00616D
                  d00616D
                  d00616
                  @Ptibu said in nRF5 Multi Sensor Board (12-14€):
                  @MiKa Here is my sketch if it helps. It uses ALS, BMP180 and RGB leds.
                  Thank you sharing your sketch. You can use https://github.com/mysensors/ArduinoHwNRF5 to redefine pin mappings in your sketch.
                  • d00616D d00616
                    P
                    P
                    Ptibu
                    @d00616 Thanks for porting !
                    • MiKaM
                      MiKaM
                      MiKa
                      Thanks for sketch, I will try
                      Which interface You use for upload?
                      I tryied ST-Link V2 from ebay it seems it working but I cant get working J-link under arduino (J-link also small version from Ali)
                      https://www.aliexpress.com/item/Die-Jlink-OB-ARM-emulator-debugger-jlink-programmierer-downloader-link-statt-V8-SWD/32763735160.html?spm=a2g0s.9042311.0.0.VVtIj7
                      Regards,
                      MiKa
                      • P
                        P
                        Ptibu
                        I only tried stlink v2 which works pretty well.
                        • MiKaM
                          MiKaM
                          MiKa
                          Works !!! :) :thumbsup:
                          Thanks Ptibu!
                          MiKa
                          • M mattewre
                            I don't know if you already managed to read correctly the BLE data.
                            Here follows what I get from this (nice and cheap!) sensor. Any tip about decoding?
                            0x6E400002 ACCELEROMETER (Acceleration)
                            0xFFA0002A3628 (it seems FA00 for x, 02A3 for y , 3628 for z)
                            0x6E400003 GYROSCOPE (Angular velocity)
                            0xFFA7007FFFC4
                            SERVICE 0x6E400004 BAROMETER (Pressure)
                            0x0018BE9 (on the table)
                            0x0018BDD (about 50 cm above the table)
                            SERVICE 0x6E400005 TEMPERATURE
                            0x012E (ambient)
                            0x0140 (inside warm hand)
                            SERVICE 0x6E400006 AMBIENT LIGHT
                            0x0000 (dark)
                            0x0936 (direct LED torch)
                            B
                            B
                            Bruce0
                            @mattewre Interesting that you got BLE Services, my board has no services. What .hex file did you flash to get that?
                            DO you have a copy?
                            • d00616D d00616
                              51822_ITC_PolyU_HK
                              • Two Buttons
                              • one RGB LED
                              Issues:
                              B
                              B
                              Bruce0
                              wrote on last edited by Bruce0
                              #21
                              @d00616 really wonderful of you to do the pinout work you have done, thank-you.
                              I have got the accelerometer (MPU6050) working as a service in nordic mbed, and I thought I would throw in some of what I learned to add to the great work you have done.
                              The schematic shows that the AD0 (pin 9) is floating (it is not, thank heavens!) it is tied to the VLogic pin ( pin 8 ). This results in the 7-Bit address of the board changing from 0x68 to 0x69.
                              I hope this helps others.
                              Also, other I2C also as posted by @Ptibu
                              Bosch BMP180 is 0x77 - untested
                              The AP3216C is 0x1E - untested
                              MPU6050 is 0x69 - works - tested
                              Also pins 17,18,19 are Red Green Blue
                              (And not Red Blue Green as shown on the schematic)
                              thanks for your help.
                              bb
                              • ben999B
                                ben999B
                                ben999
                                Hi Guys
                                Sorry for bringing the level of that thread down...
                                This little thing looks wonderful... but :
                                Could it be a direct replacement of Arduino Pro Mini and nRF24L01+ ?
                                Thanks a lot gentlemen !
                                • ben999B ben999
                                  Hi Guys
                                  d00616D
                                  d00616D
                                  d00616
                                  @ben999 said in nRF5 Multi Sensor Board (12-14€):
                                  Maybe, the NRF5 can replace the combination of ATMEGA+NRF24 chips but it's a 3.3V chip and I don't know an NRF5 board in Arduino Pro Mini layout.
                                  Please look at https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1092 for pros and cons.
                                  At the moment the radio protocol is a little bit unstable, because there is an hardware issue, which must be fixed in software. At the moment I do a rewrite of the ESB protocol, which fix this issue. My old implementation is hard to debug. With my new implementation the radio states are separated into extra functions and I use more of the nice event driven capabilities (PPI, Shorts). Until I have finished this fix, sometimes an NRF52 needs an reset.
                                  • d00616D d00616
                                    P
                                    P
                                    Ptibu
                                    I don't know how the sleep is implemented (CONFIG/GPIOTE) and if I'm facing this bug, but my battery lasts 2 days, with a wake-up period of 2 minutes (QFAAH0 MCU)... any idea?
                                    • P Ptibu
                                      d00616D
                                      d00616D
                                      d00616
                                      Do you have powered off the MCU after flashing? After programming, the debug interface is active. To disable this interface, you have to reset the MCU.
                                      • d00616D d00616
                                        P
                                        P
                                        Ptibu
                                        I'm not sure if I reset it. I will check this with a new battery and a multimeter. Thank you for the hint!
                                        A 1 Reply Last reply
                                        • P Ptibu
                                          aguedob
                                          @ptibu Did you finally solve the power consumption problem? My MCU is even newer (QFAAH1) and consumption is around 1mA all the time, which makes drain the battery in a few days.
                                          I bought my sensor in Aliexpress and I haven't flashed it. It's running with the code provided by the vendor. Can any of you recommend me a cheap cable/interface to flash it? It would be great to buy one that is already tested with this device. Thanks in advance!
                                          12.5k
