OTA preflash validation
I think it's a good idea to implement OTA "pre flash" validation. There should a possibility to define some HARDWARE_ID into sketch, modify OTA message to tell node "these new sketch is for XYZ HARDWARE_ID" and add some predefined function (as validate_OTA()) to block flashing if code is NOT for these hardware.
Accidentally I've flashed node mounted in a field and very well water protected with a wrong HEX. Dissembling module in "the middle of field", cleaning contacts from protecting grease, flashing it and protecting again was VERY painful...... -
