  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
132 Posts 32 Posters 89.7k Views 34 Watching
  • L
    L
    LastSamurai
    So I disabled debug output on the gateway to avoid the error messages but I still have problems with my setup. I used to have a motion sensor that worked with openhab. Now when the sensor sends a motion event to the gateway nothing happens in openhab.
    Part of the log of the motion sensor:
    6236 TSF:MSG:SEND,11-11-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
    6307 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    6367 TSF:TDI:TSL
    6385 MCO:SLP:WUP=-1
    6406 TSF:TRI:TSB
    6424 MCO:SLP:MS=86400000,SMS=0,I1=1,M1=1,I2=255,M2=255
    6481 TSF:TDI:TSL
    6500 MCO:SLP:WUP=1
    6520 TSF:TRI:TSB
    6541 TSF:MSG:SEND,11-11-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
    6612 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    6670 TSF:TDI:TSL
    So it seems like the message gets send succesfully but on the openhab log I see no mentioning of that (although I enable debug output for mysensors and I can switch on/off some led nodes). Any ideas why? I really want to get this working again.
    • L
      L
      LastSamurai
      Sorry for bothering you guys, I figured out the problem: I have installed domoticz on the same raspberry and after a restart I forgot to turn it off. So all the missing data was "hidden" away by domoticz instead of openhab.
      • L LastSamurai
        TimO
        @LastSamurai :smile:
        I'm glad you've found the problem, I was out of ideas. ;-)
        • L
          L
          LastSamurai
          The problem is that the motion sensor still doesn't show up at the gateway although it gets an answer from it. I disabled domoticz though so I need to find another reason ;( Earlier it showed up in domoticz ... strange. I will try to change the id and see if OH picks it up then.
          Btw @TimO Any idea yet when you will be able to work on the github issues I posted?
          • G
            G
            gonzalonal
            wrote on last edited by gonzalonal
            #57
            Hi @TimO and @andreacioni.
            Back in the day link we discussed about request type of messages being supported by the binding and the complex scenario it created.
            Are there any plans to continue developing this feature?
            • T
              TimO
              @LastSamurai I can't say when I'm able to solve those issues.
              According the ACK problem I need to enable ACK support in my network at home, which was something I already wanted to do a long time ago but haven't found the time yet.
              The RGBW is a tough nut for me. I don't have a RGBW node to test with and the conversion HSB <=> RGBW is driving me crazy. The algorithm for the conversion can be found here: https://github.com/tobof/openhab2-addons/blob/MySensors_Binding/addons/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/converter/MySensorsRGBWTypeConverter.java
              @gonzalonal May I ask you to add an issue on github? This would allow me track those enhancement requests. Thank you!
              • G
                G
                gonzalonal
                #59
                Yes, sure. I'll do that to keep track.
                By the way, I have RGBW led strip and I am using it with mysensors with no issues. Would you mind telling me what's wrong so I can recreate the scenario?
                L 1 Reply Last reply
                • G gonzalonal
                  L
                  L
                  LastSamurai
                  @gonzalonal said in openHAB 2.2 binding:
                  You can find the issues here. Basically you (I ;)) can't set RGBW nodes to display pure white colors via openhab, dimming is not working (error confirmed by TimO) and most importantly ACK isn't working properly (for me at least). If you can help with any of this (especially the conversion HSB <=> RGBW) you are most welcome.
                  G 1 Reply Last reply
                  • L LastSamurai
                    G
                    G
                    gonzalonal
                    #61
                    Please kindly check my contribution in the git issue. Maybe it will help to clarify your issues.
                    @LastSamurai said in openHAB 2.2 binding:
                    • L
                      L
                      LastSamurai
                      @gonzalonal I saw it earlier but did not understand it fully. I will take another look at it later.
                      @TimO I might have found the error... maybe. I reflashed the motion sensor (with cleared eeprom before) and removed the static id and signing. Now I see that the problem seems to be that the node is unable to get an ID. Any idea what's happening herer? Is there a setting concerning that somewhere?
                      Log from the node:
                      102477 TSM:FAIL:RE-INIT
                      102479 TSM:INIT
                      102488 TSM:INIT:TSP OK
                      102490 TSM:FPAR
                      102492 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      103426 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      103432 TSF:MSG:FPAR OK,ID=0,D=1
                      104501 TSM:FPAR:OK
                      104503 TSM:ID
                      104503 TSM:ID:REQ
                      104507 TSF:MSG:SEND,255-255-0-0,s=55,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      106516 TSM:ID
                      106516 TSM:ID:REQ
                      106520 TSF:MSG:SEND,255-255-0-0,s=20,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      108529 TSM:ID
                      108529 TSM:ID:REQ
                      108533 TSF:MSG:SEND,255-255-0-0,s=241,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      110542 TSM:ID
                      110542 TSM:ID:REQ
                      110546 TSF:MSG:SEND,255-255-0-0,s=206,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      112556 !TSM:ID:FAIL
                      112558 TSM:FAIL:CNT=6
                      112560 TSM:FAIL:DIS
                      112562 TSF:TDI:TSL
                      Log from the openhab server:
                      15:21:32.127 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 255;34;3;0;3;
                      15:21:34.135 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 255;0;3;0;3;
                      15:21:36.147 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 255;221;3;0;3;
                      and lots more similar requests with different ids.
                      • L LastSamurai
                        Log from the node:
                        102479 TSM:INIT
                        102490 TSM:FPAR
                        104501 TSM:FPAR:OK
                        104503 TSM:ID
                        104503 TSM:ID:REQ
                        106516 TSM:ID
                        106516 TSM:ID:REQ
                        108529 TSM:ID
                        108529 TSM:ID:REQ
                        110542 TSM:ID
                        110542 TSM:ID:REQ
                        112556 !TSM:ID:FAIL
                        112560 TSM:FAIL:DIS
                        112562 TSF:TDI:TSL
                        TimO
                        @LastSamurai Upgrade the binding. You're using the current beta of MySensors and the request for I'd has changed.
                        • T TimO
                          L
                          L
                          LastSamurai
                          @TimO Ahh thank you! I am using version 2.2 linked in the first post of this thread though. Where do I get a newer version? Maybe I overlooked it but I am not seeing any newer releases.
                          • L LastSamurai
                            TimO
                            @LastSamurai just replace the jar from the link above. I'm doing small changes from time to time.
                            • T TimO
                              L
                              L
                              LastSamurai
                              @TimO Thank you again for the help. Everything is now back up and running :+1: With the new jar my node could finally get a new id and after also enabling signing again everything worked as expected.
                              Can I see anywhere that you updated the jar file? I am using the current beta of mysensors mostly so I would also need to use an updated version of the openhab plugin.
                              • N
                                N
                                Nicklas Starkel
                                @TimO , is this binding supported via mysensors MQTT gateway?
                                In previous bending inormation you had some text indicating that you would implement it. But all that is gone.
                                So I'm thinking you either implemented it, or aborted that feature :)
                                • N Nicklas Starkel
                                  TimO
                                  @Nicklas-Starkel It happens, that MQTT support is sadly still on the to do list. There were some changes in the Smarthome MQTT library and we need to adopt them now.
                                  Here's the Issue: https://github.com/tobof/openhab2-addons/issues/98
                                  N 1 Reply Last reply
                                  • T TimO
                                    N
                                    N
                                    Nicklas Starkel
                                    @TimO, cool that you are stil on it, even if it's on the "todo-list".
                                    Kudos and keep up the great work :)
                                    • gahlawathomeG
                                      gahlawathomeG
                                      gahlawathome
                                      @TimO
                                      Can we use this binding for MQTT once the PR is available in OpenHAB?
                                      It is a separate mqtt generic binding in ESH for things discovery but I cannot make out if this will solve the dependency issue or not.
                                      https://github.com/eclipse/smarthome/pull/3876
                                      • L
                                        L
                                        LastSamurai
                                        @TimO My sketches are sending the nodes remaining battery power to the controller via a V_VOLTAGE. Openhab 2 with your binding doesn't seem to be able to read these values. Is this an error (possibly on my side) or does the not yet support this?
                                        • L LastSamurai
                                          TimO
                                          @LastSamurai Did you connect a channel / item for V_VOLTAGE? If the sensor is not represented by the sketch you need to connect it manually.
