  3. Minimal design thoughts
299 Posts 34 Posters 276.4k Views 17 Watching
    @tbowmo said:
    Seems like dirty pcb is doing a great job, compared to the price, only have experience with prinline.dk from previous jobs, but they are expensive like hell (just looked at their prices earlier today, together with Hek, They want 314$ (plus taxes) for the same job, that I pay 14$ for at dirtypcb, only advantage is that they have a turn arround time of 8 days, instead of 4-5 weeks from dirtypcbs.
    Ouch, that seems a bit steep. Never heard of any cheap board houses outside of China. OSHPark may be the exception? I thinks they have fabrication in the US right? I heard they were planning to set up a factory in Europe ... don't know if anything ever happened.
    It like a nice tool, Have to look at it :) Only problem is, that I have to generate gerbers myself then, instead of just uploading the eagle file, which dirtypcb turns into gerber files for me. (Remember a project 10 years ago, where it was a lot of work in creating gerbers in eagle).
    I don't know how CAM exports have changed over the years but compared to how backwards everything else works in Eagle, exporting Gerbers is easy. DirtyPCBs have a CAM-file listed on their about page. I sent them Gerbers of Meanpenguin's PCB designs and that seemed to have worked out. Knock on wood. Hopefully I'll have the boards back before xmas. The reason I didn't send the Eagle file was their new warning on the front page regarding Eagle v7+ files. Some unspecified problem with their Eagle 6.x installation. Only iffy thing I've run into so far (on some exports) is the drill file showing the holes all over the place because of the wrong precision settings. Now I'm sure the board house would have fixed this for me (their Gerber tools are bound to a great deal more advanced than mine and can probably detect Excellon formats automatically), but choosing EXCELLON_24 as output solved that problem. It's enough to send them impossible routing and endless stop mask errors ;-)
    Oh and btw, that Gerber Panelizer also helps to circumvent the 5x5cm limit on freeware Eagle since you can take your Gerbers and join them any way you please as a greater whole. Just to point out the obvious.
    tbowmoT
    tbowmoT
    tbowmo
    Hhm.. don't tell my boards that dirtypcbs have problems with eagle v7 files :) Haven't seen that warning before now.. So cross my fingers, that everything is ok.
    I remember the trouble with excellon format, and getting drill files alligned, but got some files made for printline back then, and they are still making the pcb, so must have done something right :)
    Think that the free eagle is 10x8cm board space, isn't it?
    • tbowmoT tbowmo
      bjornhallbergB
      bjornhallbergB
      bjornhallberg
      wrote on last edited by bjornhallberg
      #72
      @tbowmo Yes you're right, the Eagle board size is 10x8! Don't know where I got the 5x5 from. Nevertheless, since DirtyPCBs can do pretty mindblowing routing at no extra cost and have a pretty good price on 10x10 also ... you could probably save a great deal by doing what the Not Rocket Science guys did and create a heavily panelized board that covers a handful of different PCBs.
      • RJ_MakeR
        RJ_MakeR
        RJ_Make
        It will be interesting to see if that radio causes any interference for the MCU. Looks like it will be right over the MCU.?
        RJ_Make
        tbowmoT 1 Reply Last reply
        • RJ_MakeR RJ_Make
          tbowmoT
          tbowmoT
          tbowmo
          the antenna is not above the mcu, and the nrf module is using the entire backside as gnd. So should be shielded.. Also, I am kind of more worried about mcu generating noise for the radio..
          Specially for the first prototype, where I was a bit daft at placing powersupply pins on the wrong side of the pcb, as far away as possible, from the radio. And letting it run under the CPU to pick up noise from that.. Version 2 has this fixed, where I have the power input pins moved closer to the radio, and using wider tracks for VCC arround the board. (Should have done more reviews on the first design before sending it off to dirtypcbs)
          RJ_MakeR 1 Reply Last reply
          • tbowmoT tbowmo
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            wrote on last edited by RJ_Make
            #75
            @tbowmo Ah.. I didn't even think about the MCU causing interference for the radio. @Bandra's design suffers from this close proximity interference, which causes, I think, the MCU to lockup. I had to move the radio module from over top the Arduino for stability.
            RJ_Make
            • tbowmoT
              tbowmoT
              tbowmo
              @ServiceXp
              On one of my first mockups, I removed the connector on the radio and used some double sided tape to stick it to the back of an arduino micro, and then soldering wires between the boards. Works like a charm on battery. Antenna is just hanging off the edge of the arduino on the end opposite the serial port pins.
              Using it as a range tester for mysensors, logging into a raspberry pi with my mobile using ssh, and then running a serial port terminal emulator on the raspberry to connect to the serial GW. Then I can walk arround with the battery powered node, and check if the GW receives the data packages on my phone :)
              Haven't looked at @Bandra's design, but how close is the nrf antenna to the mcu?
              • tbowmoT tbowmo
                @ServiceXp
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @tbowmo
                This close.
                This close
                RJ_Make
                • tbowmoT
                  tbowmoT
                  tbowmo
                  This is my node, with radio close to the mcu, this works really good. So I would expect that it also works for the small module that I have made.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    #79
                    just ordered components for the first 10 boards. Just about 190$. My wife looked funny at me, as she saw the amount (she was sitting next to me when i ordered).
                    Well birthay present for myself :)
                    • tbowmoT tbowmo
                      bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      @tbowmo That was a tad more expensive than you expected I guess? Did Mouser add taxes etc at checkout?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @bjornhallberg
                        Yeah, they added Danish VAT to the order..
                        Just double checked, it's actually only 154$ (925dkk).. Remembered wrong with the exchange rate when I converted earlier, and just took some numbers from the top of my head. The VAT is around 31$.
                        But still it's a lot of money, specially this time of year..
                        • Ivan ZI
                          Ivan ZI
                          Ivan Z
                          If use one-sided mounting and on other side set CR2450 holder. Will get a small deviceю
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            And now the components arrived :d
                            Just miss one capacitor, which is out of stock at Mouser. Got a notice that they will get it in stok again in March 2015! So I'll have to see if I can find an alternative (It was decoupling for the radio).
                            Hopefully I get some time off to do the first board friday evening.
                            magpernM 1 Reply Last reply
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              #84
                              So, it's time for board mounting..
                              One advice, DOUBLE CHECK the component orders, and TRIPLE check them.. After I got the shipment from mouser, I discovered, that I accidentally had ordered some capacitors in 0101 housing, instead of 0204.. that's DAMN small components.. And I can't use it.. Well thats about 10$ down the drain.. (It was all the decoupling capacitors for the board).
                              Also found out that I forgot to order a ~100R resistor for the status LED's.. What a bummer!
                              So I'll have to see if I can source the components quickly from some friends in the next couple of days
                              Anyways, pic's from the build:
                              first depanelling in the "garage"
                              (And just for the fun of it a picture from the garage.. one of my other projects)
                              And then to the electronics workshop, mounted the atmega
                              And with NRF module attached...
                              • tbowmoT tbowmo
                                bjornhallbergB
                                bjornhallbergB
                                bjornhallberg
                                @tbowmo Sorry to hear about your sourcing troubles. Wish there was an easier and cheaper way to source things.
                                Smart depaneling, I have a saw like that standing around as well. I have used it to cut some aluminium profiles before but never considered it for cutting pcbs. Still, I will continue to try and look into tabs and "mouse bites" to make depaneling a bit easier.
                                Is that an old Ferguson that you're renovating? Sorry, but I immediately thought of Frank Erichsen ;-)
                                So, no problems hand soldering then? Can you complete the circuit for testing or do the missing components get in the way?
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  #86
                                  @bjornhallberg
                                  I am trying to activate my local nerd network, to see if anyone could get the components within the next couple of days (we are 10-18 nerds having regular meetups, some of them are in the electronics business). One of the nerds have some resistors and caps in 0402, but not exactly the values I want (1uF cap, and 760R resistor if I remember correct)
                                  for the next batch of boards, I might go for easier depanelizing options, with tabs and so on (I got the gerber panelizing tool from http://blog.thisisnotrocketscience.nl/projects/pcb-design-tools/)
                                  I managed the soldering so far.. I must admit that I had forgotten how small 0402 components are :) But soldering, and double checking everything with a "monocle" to magnify things, it's doable..
                                  Also I have tried to power up the atmel, it seems to be ok, at least I can get the correct device checksum when I use my jtagice3 on it with avrdude. It would just be more fun to have all the correct components mounted, for testing and verification of the board, before I push the next board revision off to China
                                  Is that an old Ferguson that you're renovating? Sorry, but I immediately thought of Frank Erichsen wink
                                  Yeah it's an old fergie TEA-20 from '54, that I'm trying to renovate :) Not everything should be computers / electronics :) (Btw. is Frank, or "bonderøven" as he's called in Denmark, also known in Sweden?)
                                  • tbowmoT tbowmo
                                    @bjornhallberg
                                    bjornhallbergB
                                    bjornhallbergB
                                    bjornhallberg
                                    Yep, bonderøven has been on TV over here for a couple of years now. I think I've seen most episodes. I just love that guy's enthusiasm ... and patience.
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      I succeeded in getting a couple of components more (Only missing a 2.2uF 0603 capacitor, that was out of stock at mouser.)
                                      I have vacation, so in theory I could go to the "man cave" and mount the last couple of components. Only problem is, that I have 2 "tasmanian devils" aged 3 and 5 years running wild at home today, So no possibility to have time for my self ;)
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        #89
                                        A quick christmas status update, finaly got arround to power the first board up, just with basic code (blink an LED to check that it will work).
                                        Used a couple of hours trying to get my LED to blink. all other pins would toggle, but not my LED, until I finaly digged into the datasheet. I had used A6 for the LED, which turns out to be an input pin only, facepalm. So the board already have the first "green wire" patch :)
                                        Next up is to get serial up and running. before i can start testing temperature / humidity sensor, and radio interface.
                                        • tbowmoT tbowmo
                                          RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          @tbowmo Thanks for the update!!
                                          RJ_Make
