  3. 💬 Bed Occupancy Sensor
mpr121capacitiveoccupancybedtouch
21 Posts 12 Posters 12.3k Views 7 Watching
  • TmasterT
    TmasterT
    Tmaster
    wrote on last edited by Tmaster
    Realy cool project. Its very usefull ,but in my opinion,all this wires in a bed will cause problems in home:P how far it detect capacitance? if it was mounted on bed plataform would be acceptable (for wifes). OR use a load cell(20 to 100kgs maybe) on one of the foots of bed plataform
    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
    petewillP 1 Reply Last reply
    • OitzuO
      OitzuO
      Oitzu
      Oh i see its now on hackaday also. http://hackaday.com/2016/04/17/are-you-in-bed/ :clap:
      • TmasterT Tmaster
        petewillP
        petewillP
        petewill
        @Tmaster Sorry, I must have missed your comment. I think it probably detects around .5 inches. Maybe a little more. We have it under a mattress pad so wires are hidden and undisturbed when changing the sheets. I'd be interested in hearing how the load cells go. I vaguely remember reading that they start to lose their ability to detect if they are under constant weight. I'm not sure if that was just for detecting minor changes though. It may still work to pick up a body. :)
        @Oitzu Cool! Thanks for sharing.
        • franzelareF
          franzelareF
          franzelare
          if you run domoticz or an other home automation system, adding a time in bed script could be a next level
          https://www.domoticz.com/forum/viewtopic.php?f=23&t=15502
          • D
            diamantmatch
            i have tried making the MPR talk to arduino, but i could not find the right library for your code.. what lib are you using? the adafruit one just spews out errors..
            • D diamantmatch
              petewillP
              petewillP
              petewill
              @diamantmatch It's the BareConductive library https://github.com/BareConductive/mpr121 (see the comments in the code for more info)
              • N
                N
                Nicolas M.
                @petewill
                Did you try to use the "virtual 13th pin" of the MPR121? It can be used to have the MPR121 automatically combine the values of (for example) the first four pins and was specifically designed to handle proximity detection instead of touch.
                I wonder if this could theoretically cut down on the necessary calculations.
                • N Nicolas M.
                  @petewill
                  petewillP
                  petewillP
                  petewill
                  @Nicolas-M. I never tried it. I looked into it but didn't use it because I wanted to use the same device to monitor both sides of the bed. I have wondered this on occasion as well. It would be worth looking into if you decide to build one.
                  • N
                    N
                    Nicolas M.
                    @petewill Ah okay, understandable. I thought about the pros and cons of using two MPR121, since they are extremely cheap (1-2$?), but it would mean more cables, so it would only be worth it if it improves accuracy. I finished rebuilding your setup a few hours ago but didn't have time yet to test it much, maybe I'll build the "virtual 13th pin"-variant aswell if I find the time.
                    • N Nicolas M.
                      petewillP
                      petewillP
                      petewill
                      @Nicolas-M. Yeah, they are definitely cheap. I can't remember why I wanted to do one. I guess because it was working and there was less to do.
                      One thing I would change is I wouldn't use the copper tape any more. I have found that it gets damaged (cracked/separated) rather easily. I have actually switched to a stranded copper wire (18ga I think) that I have removed from the housing and spread out flat. I make sure it's overlapping itself in somewhat of crisscross pattern. That way if one of the wires breaks it still will make connection with other wires. Hopefully that makes sense.
                      • I
                        I
                        Inso
                        May I ask why you did not "just" install an PIR to detect presence in bed?
                        • I Inso
                          petewillP
                          petewillP
                          petewill
                          @Inso Unless there is another use for a PIR that I'm not aware of, a PIR will detect motion and when I'm sleeping I'm not doing much moving. :) With this sensor it knows when I'm in bed so the lights don't turn on and the blinds don't go up. Hopefully that makes sense.
