  3. HC-SR04 (Distance) only sends data with connected serial converter?
3 Posts 2 Posters 1.3k Views 1 Watching
  • edsteveE
    edsteveE
    edsteve
    Hallo,
    Hardware:
    i have an Arduino pro mini 5V connected to a HC-SR04 sensor and using the standard mysensors code unchanged. It runs on a 3,7V battery with a stepUp Buck converter to 5V (LM2596) which i use in many projects. The data is sent via NRF24L01+ which has it's own converter.
    It works flawless when the USB to Serial adapter (FT232BL) is connected. Every 5 seconds a reading.
    But when i let the sensor "run by itself" i can see that the sensor gets registered in Domoticz, but Domoticz does not receive any data. When i plug in the serial converter. Domoticz gets all the data as it should be.
    I also unplugged the power wires from the serial converter to see if it is a power issue. But same result.
    I do actually get a reading sometimes. Maybe every 2 minutes or so instead of every 5 seconds. But even that has the wrong values (always 0cm)
    Drives me crazy. What is that?
    Thx for thinking with me
    ED
    • edsteveE edsteve
      Hallo,
      Hardware:
      ED
      sundberg84S
      sundberg84S
      @edsteve could it be that Domoticz does not update the value if it's unchanged ? You can monitor the gw log.
      If not I would suspect the booster generate noice that disturbs your radio.
      • edsteveE
        edsteveE
        edsteve
        Thanks for your reply.
        I was dealing with it for 3 hours now. Grml. But as usual i figured it out right after this post. The trigger pin was connected to the wrong Arduino pin (4 instead of 6). Of course i didin't check it, because it still worked with connected serial converter. How strange.
        So i guess this post can be deleted due to waste of space.
        Cheeers
        ED
