  3. Where to get legit nRF24L01+ modules?
counterfeitnrf24l01+nrf24l01+pa+lna
85 Posts 9 Posters 35.1k Views 12 Watching
    how did you setup NRF5 "sniffer" ?
    BTW, my red modules are working really great; the link you provided from aliexpress are really genuine?
    Nca78N d00616D 2 Replies Last reply
      @gohan do you have rectangles/squares or dots on yours ?
        I don't remember, I'll have to look tonight
          d00616D
          d00616D
          d00616
          wrote on last edited by d00616
          #79
          @gohan said in Where to get legit nRF24L01+ modules?:
          At the moment, I reimplement the protocol for NRF5 chips to fix an NRF5 hardware issue. I don't have a "sniffer".
          My red modules are good working clones, but they are clones which violating the protocol. Using clones resulting in sending more packages over the air and never receiving an ACK package from original NRF24. So it looks like a duck, but not quacks like a duck over the air.
          EDIT: Sorry, Cannot identify clones at the moment.
            #80
            There's no reason to continue using nRF24L01's anyway, except for legacy situations. Their only virtue is cheapness, and the nRF51's offer a good substitute for that.
            d00616D 1 Reply Last reply
              d00616D
              d00616D
              d00616
              @NeverDie said in Where to get legit nRF24L01+ modules?:
              ...when https://github.com/mysensors/MySensors/issues/949 is fixed. If not, a node requires an hard reset from time to time.
              • d00616D d00616
                Some news. After playing with NRF5 and the NRF24 protocol. The red EBYTE modules are fakes.
                Over the N of NRF is a dot. I have ordered these modules: https://aliexpress.com/item/Wireless-Module-NRF24L01-original-2-4-Ghz-RF-transceiver-SPI/32712174920.html they have an rectangle over the N and responding line an original NRF24L01. Maybe this helps to identify originals.
                The difference between both modules is in NoACK attribute handling. Fakes always responding with ACK and sending inverse NoACK attributes. So fakes have problems communicate with original modules.
                EDIT: This was an issue at the NRF5 side.
                @d00616 said in Where to get legit nRF24L01+ modules?:
                Here we go again... Nordic is a fabless company. Therefore the laser marking on their genuine models can be different with each batch. There is no known way to tell if a module is genuine or not from the outside of the module.
                • d00616D d00616
                  First I've heard of this. How often is "from time to time"?
                    d00616D
                    d00616D
                    d00616
                    <0,1% of packages. I have three versions of the ESB protocol code. With the published version, the module hangs when PAN#102 is triggered. My second version was a try to fix this issue by adding some timer code. With this fix, the NRF5 looses more packages than before. The version I currently working on looks more stable, is easier to debug, supports the fast ramp up mode partially, but it's not complete yet.
                    • d00616D
                      d00616D
                      d00616
                      Sorry for my NRF24 clone post yesterday. The ACK bit was an issue with the NRF5 platform. I had switched the memory region to handle TX/RX/ACK packages separately. Sometimes the received packages are written in the wrong region. I had seen my testing ACK bit. Now, I have changed my NRF5 code and I can't see no difference between the modules, I have. ACK and timing are exactly at the same level.
