  3. Automatic LED light - high WAF inside :)
16 Posts 4 Posters 4.8k Views 4 Watching
  • ben999B ben999
    Hi guys
    Could you please comment on this :
    bool tripped = digitalRead(PIN_MOTION) == HIGH;
    if ( tripped =! prevTripped ) {     //only send data when there is a change
      send(msgMotion.set(tripped ? "1" : "0")); // Send tripped value to gw
      prevTripped = tripped;
    Goal is to send update to gateway when state of PIR sensor changes
    Trouble is that node sends state of sensor every cycle and floods karaf console...
    Any clue ?
    Also can anyone explain this
    I dont quite understand.... read, store, and compare... all at once?
    Thanks a lot for your help
    B
    B
    billgoolsby
    @ben999,
    As for your last question, this line is simply converting the pin state (either HIGH or LOW) to a boolean. The right side expression evaluates to a boolean that is true when the pin is HIGH. This is assigned to the boolean variable "tripped". This makes it logically easy to use in the following IF statement.
    First question: I'm not sure why it would send every cycle. The logic of the IF statement seems correct, and since prevTripped is global, its state will be preserved between loops.
    ben999B 1 Reply Last reply
    • ben999B ben999
      Hi guys
      A new project came on top of the others : ceiling light
      The wife kinda likes the idea behind MySensors and openHab, as home automation and security system
      But i had to hit hard to get it fully accepted. So here comes the "cat shaped ceiling light" !!!
      (Ok I know, ceiling is not finished yet... it has to be spotless as this kind of light reveals everything...)
      LED strip is glued on the edge of the board, powered via a 12V power supply which is controlled via an OMRON SSR relay
      Some AutoCad and CNC later... :
      This is highly inspired by Aproxx's work
      https://www.openhardware.io/view/77/AC-DC-double-solid-state-relay-module
      What I want it to do :
      • switch on the light when motion (PIR sensor)
      • switch itself off with delay (PIR kind enough to do that as well)
      • measure room light level so as to switch light on only when needed
      • have 3 modes controlled via openHab : fully automatic, always ON, always OFF
      So far i have managed to create a 3-state selector in openhab with this:
      • ".items" file: String HouseMode "House Mode [%s]"
      • ".sitemap" file: Switch item=LightMode mappings=[ON=1, AUTO=2, OFF=1]
      Now I am having some trouble with the sketch...
      I guess I should be using S_CUSTOM and V_CUSTOM (instead of S_BINARY and V_STATUS) as the "LightMode" variable can take up to 3 states...
      How do i then retreive that value?
      int lightMode = message.getInt();
      Thanks for your input and comments :)
      dbemowskD
      dbemowskD
      @ben999 Nice CNC work on the PCB.
      • ben999B ben999
        Sorted :)
        It is probably a bad idea to send data to node while sleeping...
        Complete sketch for the record
        // Enable debug prints
        #define MY_PARENT_ID 0
        #define MY_NODE_ID 19
        // (Only input 2 and 3 generates interrupt!)
        #define PIN_MOTION 2      // Motion sensor input
        #define PIN_RELAY 5       // Omron relay output
        #define MOTION_ID 1       // Id of the motion sensor child
        #define RELAY_ID 2        // Id of the relay child
        int lightMode = 2;         // 0=OFF - 1=ON - 2=auto
        bool prevTripped = 0;          // previous state of motion sensor
        MyMessage msgMotion(MOTION_ID, V_TRIPPED);    // Initialize motion message
          pinMode(PIN_MOTION, INPUT);
          delay(3000);  // wait for motion sensor voltage to stabilize
          pinMode(PIN_RELAY, OUTPUT);     // Then set relay pins in output mode
          digitalWrite(PIN_RELAY, LOW);  // Make sure relays are off when starting up
          sendSketchInfo("Toilet Light", "27.10.2017");
          present(MOTION_ID, S_MOTION);
          present(RELAY_ID, S_CUSTOM);
          if ( lightMode == 0 ) {
          if ( lightMode == 1 ) {
            digitalWrite(PIN_RELAY, HIGH);
          if ( (tripped == 1) && ( lightMode == 2 ) )  {
          if ( (tripped == 0) && ( lightMode == 2 ) )  {
          if (message.type == V_VAR1) {
            lightMode = atoi(message.data);
        Thanks for reading ! Next project !!!
        dbemowskD
        dbemowskD
        @ben999 I would rewrite some of the logic in your code to shorten it up a bit. I would change this:
        To this:
          if ( ( (tripped == 1) && ( lightMode == 2 ) ) ||   lightMode == 1  )  {
          if ( ( (tripped == 0) && ( lightMode == 2 ) ) ||   lightMode == 0  )  {
        • dbemowskD dbemowsk
          To this:
          ben999B
          ben999B
          ben999
          @dbemowsk thanks a lot :) i like that!
          Do you rekon that would "speed" things up? Not that i need more speed to switch that light on but would this simplify and shorten the sketch processing time?
          • B billgoolsby
            @ben999,
            ben999B
            ben999B
            ben999
            @billgoolsby thanks a lot for your comments that make more sense now :)
            Trouble is that if sketch remains as above it doesn't get into the if ( tripped =! prevTripped ) loop (i have put Serial.print here and there and i never get to it)
            On top of that tripped stays locked on HIGH but light is off...
            Any clue? Sketch seems fine to you?
            Thanks for your time :)
              ben999B
              ben999B
              ben999
              @dbemowsk said in Automatic LED light - high WAF inside :):
              I have some neat little tools in my workshop:
              3x1.5m working area
              500x300mm working area
              dbemowskD 1 Reply Last reply
              • ben999B ben999
                3x1.5m working area
                dbemowskD
                dbemowskD
                @ben999 OK, NO FAIR. Is the bottom one a laser cutter/engraver??
                  ben999B
                  ben999B
                  ben999
                  @dbemowsk :D i know i'm lucky to have all those toys handy
                  This is a 2.2kW spindle... other one is 13kW in case i need more :D
                  • ben999B ben999
                    dbemowskD
                    dbemowskD
                    @ben999 .oO{ JEALOUS }Oo.
                    • ben999B ben999
                      ben999B
                      ben999B
                      ben999
                      @ben999 just for the record... =! is wrong. Should have been !=
                      Makes quite a difference :(
                      12.5k
