  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
132 Posts 32 Posters 89.7k Views 34 Watching
  • L LastSamurai
    @TimO Ahh thank you! I am using version 2.2 linked in the first post of this thread though. Where do I get a newer version? Maybe I overlooked it but I am not seeing any newer releases.
    TimO
    @LastSamurai just replace the jar from the link above. I'm doing small changes from time to time.
    L 1 Reply Last reply
    • T TimO
      L
      L
      LastSamurai
      @TimO Thank you again for the help. Everything is now back up and running :+1: With the new jar my node could finally get a new id and after also enabling signing again everything worked as expected.
      Can I see anywhere that you updated the jar file? I am using the current beta of mysensors mostly so I would also need to use an updated version of the openhab plugin.
      • N
        N
        Nicklas Starkel
        @TimO , is this binding supported via mysensors MQTT gateway?
        In previous bending inormation you had some text indicating that you would implement it. But all that is gone.
        So I'm thinking you either implemented it, or aborted that feature :)
        • N Nicklas Starkel
          TimO
          @Nicklas-Starkel It happens, that MQTT support is sadly still on the to do list. There were some changes in the Smarthome MQTT library and we need to adopt them now.
          Here's the Issue: https://github.com/tobof/openhab2-addons/issues/98
          N 1 Reply Last reply
          • T TimO
            N
            N
            Nicklas Starkel
            @TimO, cool that you are stil on it, even if it's on the "todo-list".
            Kudos and keep up the great work :)
            • gahlawathomeG
              gahlawathomeG
              gahlawathome
              @TimO
              Can we use this binding for MQTT once the PR is available in OpenHAB?
              It is a separate mqtt generic binding in ESH for things discovery but I cannot make out if this will solve the dependency issue or not.
              https://github.com/eclipse/smarthome/pull/3876
              • L
                L
                LastSamurai
                @TimO My sketches are sending the nodes remaining battery power to the controller via a V_VOLTAGE. Openhab 2 with your binding doesn't seem to be able to read these values. Is this an error (possibly on my side) or does the not yet support this?
                • L LastSamurai
                  TimO
                  @LastSamurai Did you connect a channel / item for V_VOLTAGE? If the sensor is not represented by the sketch you need to connect it manually.
                  • gahlawathomeG gahlawathome
                    @TimO
                    TimO
                    @gahlawathome I'm currently looking into the new MQTT implementation in smartphone. It should work without the PR above. The PR will bring us a new option to connect a MQTT binding with OpenHAB!
                    • T TimO
                      L
                      L
                      LastSamurai
                      wrote on last edited by LastSamurai
                      #74
                      @TimO I am not sure what you mean.
                      My sketch sends a presentation:
                      and in openhab I added these (tried both sensor kinds)
                      // things
                      customSensor abc [nodeId=26, childId=1]
                      multimeter def [nodeId=17, childId=1]
                      // and items
                      Number 	voltageSensorWZ ... { channel="mysensors:multimeter:gwSerial:def:volt" }
                      Is there anything i am missing here?
                      • L LastSamurai
                        // things
                        // and items
                        TimO
                        @LastSamurai
                        The channel is not correct:
                        channel="mysensors:multimeter:gwSerial:voltageSensorWZ:volt"
                        It's confusing, but that's the way OpenHAB2 handles channels. :confused:
                        • T TimO
                          @LastSamurai
                          L
                          L
                          LastSamurai
                          #76
                          @TimO Thanks for your help though I am afraid you mixed something up there. The channel linking to the item itself doesn't really make sense ;)
                          Not 100% sure why it did not work earlier for me but I now got it to work like this:
                          // thing
                          multimeter		voltTHWohnzimmer	[nodeId=1, childId=2]
                          // item
                          Number 	voltageSensorWZ 		"Spannung [%3f mV]" 		<poweroutlet_eu> 	(grVolt, grWZ)	{ channel="mysensors:multimeter:gwSerial:voltTHWohnzimmer:volt" }
                          My error in the code above seems to have been that I defined most as customSensor instead of multimeter.
                          • gerritvG
                            gerritvG
                            gerritv
                            @TimO said in openHAB 2.2 binding:
                            @LastSamurai
                            Is the pattern:
                            <binding name>:<mysensors type>:<gateway id>:<thing name>:<data name> ?
                            • gerritvG
                              gerritvG
                              gerritv
                              wrote on last edited by gerritv
                              #78
                              Just to let you know that I am very happy with this binding.
                              One thing for others to be aware of:
                              If you use PaperUI for configuring etc, make sure you leave Simple Mode off if you expect to use Groups later on. Simple mode adds the items (including the VAR1-5 :-() automatically but they are not 'managed'. This means you will get 404 and 405 errors on trying to edit them later on.
                              My solution was to let the binding autodiscover and add the Things. Then add 1 Item manually so that the \\192.168.0.123\openHAB-share\openhab2-userdata\jsondb\org.eclipse.smarthome.core.items.Item.json
                              file gets created and filled with an example to clone. I then added the various sensors using Name of pattern <binding name><sensorname><nodeid>_<dataname>, e.g. "mysensors_light_level_node4_last_update": { "class": "org.eclipse.smarthome.core.items.ManagedItemProvider$PersistedItem", "value": { "groupNames": [ "gLastUpdated" ], "itemType": "DateTime", "tags": [], "label": "Last", "category": "calendar" } },
                              You must stop Openhab before editing the file (else you will lose your edits) but once it starts up again you will see the Items listed in PaperUI (and VSCode if you use that). You can then add the Channel/Item links for each Thing.
                              • F
                                F
                                fredswed
                                Thanks for some great work @TimO ! Version 2.2 now works smoothly with my simple OpenHAB setup (2.2 snapshot).
                                One thing I noticed is that the gateway thing configuration page says "Disable network sanity check" even though the logic has been reversed in v2.2.
                                So the UI needs to be similarly changed to "Enable startup check" instead.
                                While I'm at it, could you please also clarify (in the UI) what "Send delay" is? Please also add that timing is in ms. If I understand things correctly it could say "Minimum time between messages sent to the gateway (ms)"
                                Also, the comment for "Imperial/Metric selection" could use some clarification. Preferably change the label to "Imperial units" and the explanation to "Use imperial units (default is metric)."
                                And finally it would be great to add add that the time is given in "...(minutes)" for the Network sanity check interval.
                                • L
                                  L
                                  LastSamurai
                                  I have just updated to the stable openHAB 2.2 Version and everything seemed to be working just fine in the beginning but after the next restart I got this error:
                                  10:31:19.727 [WARN ] [fig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/binding/binding.xml' in module 'org.openhab.binding.mysensors' could not be parsed: The XmlConfigDescriptionProvider must not be null!
                                  It seems like I can still control my devices just fine but I just wanted to make sure that this doesn't cause errors down the line. So @TimO any idea where this error is coming from?
                                  • mythbaiM
                                    mythbaiM
                                    mythbai
                                    After upgrade OH to 2.2 stable release. (2.2_01). I'm having the same issue that zwave binding not working. After Mysensors binding is installed and gateway configured. There is only one serial port visiable in PaperUI, which is /dev/ttyUSB0 that is configured for the serial gateway. I'm using org.openhab.binding.mysensors-2.2.0-SNAPSHOT-serial-fix.jar.
                                    Also the old 2.1 snapshot version doesn't work either. anyone else experience this issue?
                                    mythbaiM 1 Reply Last reply
                                    • jocke4uJ
                                      jocke4uJ
                                      jocke4u
                                      I have issues with MySensors and specifically Energy Sensors where they request latest value.
                                      See this thread for details: https://forum.mysensors.org/topic/8833/power-sensors-stopped-working
                                      Any idea how to solve it?
                                      • L
                                        L
                                        lesockz
                                        iam using "openHAB 2.2.0-1 (Release Build)" as openhabian on a PI3.
                                        i've installed "org.openhab.binding.mysensors-2.2.0-SNAPSHOT.jar" as explained in the instructions.
                                        configured the thing "MySensors Serial Gateway" to use "/dev/ttyACM0" with Baudrate "38400" because i'm using a pro micro with 8Mhz which isn't capable of 115200 (as far as i know).
                                        the Items got discovered fine.
                                        Atm i have only one item with
                                        #define CHILD_ID_TEMP 0
                                        unsigned long SLEEP_TIME = 3 * 1000; // Sleep time between reads (in milliseconds)
                                        MyMessage tempMsg(CHILD_ID_TEMP, S_TEMP);
                                        Presentation:
                                          sendSketchInfo("Temp/Hum/Pre Sensor", "1.2");
                                        and Loop:
                                          unsigned long currentTime = millis();
                                          temperature++;//bme.readTemperature();
                                            lastSend = currentTime;
                                            send(tempMsg.set(temperature, 2));
                                            lastTemp = temperature;
                                          sleep(SLEEP_TIME);
                                        This is my debug from "openhab-cli showlogs"
                                        2018-01-07 13:59:17.676 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;109.00
                                        2018-01-07 13:59:17.680 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                        2018-01-07 13:59:17.683 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                                        2018-01-07 13:59:17.687 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                                        And this from Log Viewer
                                        2018-01-07 14:00:18.836 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                        2018-01-07 14:00:18.841 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                                        2018-01-07 14:00:18.846 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                                        2018-01-07 14:00:27.561 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:117.00
                                        2018-01-07 14:00:27.566 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;117.00
                                        2018-01-07 14:00:27.572 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                        2018-01-07 14:00:27.577 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                                        2018-01-07 14:00:27.582 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                                        2018-01-07 14:00:36.301 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:118.00
                                        2018-01-07 14:00:36.308 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;118.00
                                        2018-01-07 14:00:36.311 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                        2018-01-07 14:00:36.315 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                                        2018-01-07 14:00:36.318 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                                        2018-01-07 14:00:45.034 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:119.00
                                        2018-01-07 14:00:45.037 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;119.00
                                        2018-01-07 14:00:45.039 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                        2018-01-07 14:00:45.042 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                                        2018-01-07 14:00:45.045 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                                        So from log i can see Temp is counting up. but in "Paper Ui"
                                        i always get "Temperature -NaN °C" or "Temperature 0 °C"
                                        Please correct me if this is the wrong place for this question.
                                        Greets Andi
                                        • mythbaiM mythbai
                                          mythbaiM
                                          mythbaiM
                                          mythbai
                                          @mythbai said in openHAB 2.2 binding:
                                          Up my own post. Not many users are using Zwave dongle and Mysensors at the same time? I feel this forum or trend is dead... This problem is driving me crazy, render all my mysensors useless. I'm trying to build a ethernet gateway now...
                                          T 2 Replies Last reply
