  3. Software signing suddenly stop working
28 Posts 3 Posters 6.5k Views 4 Watching
  • S Offline
    sineverba
    wrote on last edited by sineverba
    Hi to all,
    I have a RPI2 as Controller, with an UNO as Gateway connected via USB, version 2.1.1, with a NRF amplified.
    I have 3 nodes in home.
    2 are temp / hum battery, no signing at all.
    1 is the heater control, with a relay attached for the heater.
    This node is feeded with a Samsung 5V/2A.
    All network did work for last 6 month. Tonight, suddenly, the heater node lost communication, or better, did not receive command for the relay.
    I did attach a FT232 and I did see on serial "SIGN FAIL". A quick research on forum, I did comment the MY_SIGNING_REQUEST_SIGNATURES
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x3B,0xF4,0xF4,0xDF,0x1E,0x97,0xB1,0x2D,0xEC}}}
    on both gateway and nodes and.... all work like a charme.
    The node is an Atmega328 on breadboard @8MHZ, with amplified NRF, + screen + relay, as I did say.
    Now, for the moment it will be without security, but, just to understand, if someone on the neighborhood would "play" with my node, he could do it?
    I don't need security for a heater, but I would like only to have the WHITELISTING feature.
    IN next days I will investigate what could have done this issues, after about 6 month of small others issues but, of sure, no issues about the signing.
    Another question, I did update several time ago the library from Arduino update. Do you hint to delete totally from the folder, re-download and reinstall? Or the library on the official repository is the same?
    Thank you for your effort.
    A 1 Reply Last reply
    • S sineverba
      Hi to all,
      A Offline
      A Offline
      Anticimex
      @sineverba Hi, it is hard to tell what has gone wrong with the signed messages without any logs to look at. My best guess would be that you have a NACK problem.
      As for the whitelisting feature, no, you cannot "only" have whitelisting. It is based on the signing feature and need it enabled in order to work.
      • brendanlB Offline
        brendanlB Offline
        brendanl
        @sineverba said in Software signing suddenly stop working:
        Interestingly I'm working through a very similar issue myself just now. The garage door opener just stopped working a few days ago.
        I've pulled the Pro Mini out and onto a breadboard and have been doing the following this evening:
        • Updated it to 2.1.1 from 2.0.0 beta (no improvements)
        • Re applied the Security Personalizer / soft HMAC Key with the 2.1.1 core (no difference, nor was I expecting that)
        • Added #define MY_DEBUG_VERBOSE_SIGNING
        • Added #define MY_SIGNING_SOFT_RANDOMSEED_PIN A0 (I never had this line, but it made no difference)
        • Added a capacitor across the NRF24 (no difference)
        • Added additional debug statements to MyTransport.cpp but haven't discovered anything yet.
        • Disabled MY_SIGNING_SOFT (immediately fixes it, but I don't want that)
        My experience is that the messages either never get received (no trace output) or the output ends at "Transmitted nonce". Randomly, it will work.
        It used to work just fine and I'm reluctant to drop the signing. So I'm definitely interested in how you get along and I'll update too if I get my end sorted.
        S 1 Reply Last reply
        • brendanlB brendanl
          sineverba
          @brendanl as PHP developer, It is INCREDIBLE that a perfect working software, WITHOUT updates, suddenly crash. But It is. For now, I did disable the signing. Do you have inserted other nodes in the network? Changed some radio? I don know whats the failure. I did redownload library from github and tonight I Will reinstallare. I Will update the thread ASAP.
          • A Offline
            A Offline
            Anticimex
            Signing has an absolute requirement that the radio link works flawlessly. It will trow away or fail messages if any part of the exchange fails to reach the destination. So if you get any NACKs in the log, then those NACKs have to be resolved before signing can be expected to work.
            • A Anticimex
              sineverba
              @Anticimex I did see Your similar answer on another thread. I am in accord with you, but my / our nodes was working flawless from month.... I Will try also swapping radios, maybe a power failure that has broken them? But no Power failure in about 6 month in my home....
              • S sineverba
                A Offline
                A Offline
                Anticimex
                @sineverba The log will show if your messages come through or not (you need them from both the node and the GW to verify that). It can be a power issue, or a noise issue, or a neighbour buying some radio equipment that disturb your comms, or birds just crossing at a bad time. Hard to say, but I am inclined to blame RF for this problem and not signing (for this very reason).
                And as I have said, in many threads (and also in the documentation) the fact that it "works without signing" does not automatically mean signing is not working. It is normally just because with signing enabled, the RF link is put on stress due to the messages being much bigger.
                • A Anticimex
                  sineverba
                  @Anticimex ok, I Will investigate more and more.
                  Question: if I leave the Heather without signing, or a generic relay, someone "malicious" how could "play" with my relay? Need to have a portable controller and gateway and sniff when I poweron or poweroff the relay itself tto have the node in his controller?
                  • S sineverba
                    A Offline
                    A Offline
                    Anticimex
                    @sineverba With enough knowledge, only a gateway is needed. You can just use a terminal to send commands to the gateway. If your node ID is known and your radio address, then anyone could just send commands to it. They will need to know what command your node reacts to, but that can be obtained from sniffing the traffic (assuming you don't encrypt your communications).
                    • A Anticimex
                      sineverba
                      @Anticimex If i live at 4th floor of a Palace and the family at 3rd use MySensor, on same Channel also (!), Is there the possibility that their Heather commands could be read and interpretated from mine ? (Or viceversa).... Thank you!
                      • S sineverba
                        A Offline
                        A Offline
                        Anticimex
                        @sineverba That is up to you and how you validate the sender of the messages you receive and accept in your node. If you accept everything, then you accept everything ;)
                        • A Anticimex
                          sineverba
                          @Anticimex so, we return to the whitelisting :-( ...
                          • S sineverba
                            A Offline
                            A Offline
                            Anticimex
                            @sineverba Not necessarily. You can validate that the message is from "some gateway", and that it is specifically of the type you accept.
                            You can also enable encryption.
                            But essentially, if you want "security" you need signing. That is kind of the point of that feature ;)
                            • A Anticimex
                              sineverba
                              @Anticimex
                              I'm re-studying the API and specifically the signature / signing section.
                              I did not understand something. I don't want open a new thread, ask here. If necessary, I will open a new one.
                              My questions (and thank you in advance for your time and time for all readers!)
                              From this page: https://www.mysensors.org/apidocs-beta/group__SigningSettingGrpPub.html#gaf75e26bdb90edd1230100ef160786e78
                              1. MY_SIGNING_REQUEST_SIGNATURES
                                It says "If used for a gateway, gateway will by default require signatures from ALL nodes".
                                I did enable this on the gateway (Arduino UNO).
                                Q: In my network I have 2 nodes that transmit temp, hum and battery (atmega328). No signing at all in the sketch(es). Why they works without the SIGNING?
                              2. MY_SIGNING_NODE_WHITELISTING
                                I do not understand the explain. In effect, in my relay node (the only one of 3 nodes that did have the signing software enabled) I did have also:
                              What's a verifyng node cited on the explain? Another one node of my network is acting as a bridge beetween both?
                              1. You did mention that I could sniff the address of trasmitting (of the gateway). I did not find nothing on the library... Could you help me to perform this "sniff"? This is my receive function atm:
                               * Receive function from gateway
                               * @since 1.0
                                if ( !message.isAck() ) {
                                  if ( message.type == V_STATUS) {
                                    if (  message.getCommand() == 1 ) {
                                      bool received_state = message.getBool();
                                      Serial.print("We did receive a new value. Received_state value is ");
                                      Serial.println(received_state);
                                      if ( received_state == 1) {
                                        digitalWrite(PIN_RELAY , RELAY_ON);
                                        digitalWrite(PIN_RELAY , RELAY_OFF);
                              A 2 Replies Last reply
                              • S sineverba
                                @Anticimex
                                 * @since 1.0
                                A Offline
                                A Offline
                                Anticimex
                                @sineverba
                                1. I am not sure. I assume you run the 2.2.0-rc.1 version on all nodes and gw? The documentation you read is for that branch (development branch).
                                2. The verifying node is the node that verifies the signatures. That is, the node that require signatures. It can be both ends if both require signatures (node and GW)
                                3. No, I meant "someone" could sniff. The library itself does not offer sniffing APIs.
                                • S sineverba
                                  @Anticimex
                                   * @since 1.0
                                  A Offline
                                  A Offline
                                  Anticimex
                                  @sineverba actually, reading your first post, it would appear that you run the official release (2.1.1). The signing requirements work differently there, and the documentation is also different as you can see here: https://www.mysensors.org/apidocs/index.html as opposed to here: https://www.mysensors.org/apidocs-beta/index.html
                                  • A Anticimex
                                    @sineverba
                                    sineverba
                                    @Anticimex No, I'm running the 2.1.1 on all nodes and gw.
                                    In this moment I did re-enable the signature and signing software section on the gateway (but not in nodes, no nodes have signing enabled). All works. I can confirm.
                                    For the 2 (whitelisting) I did enable only on the node that require signature, i.e. the relay node. Not in gw, not in no others nodes.
                                    For the 3, maybe I was not clear. I did mean if I did have the possibility, on receive function, as following pseudo code:
                                    if (message.getSenderSerial() == 0X01,0XAA, 0XBB) {
                                        Serial.println("We did receive this message from our gateway... we can proceed");
                                    • S sineverba
                                      A Offline
                                      A Offline
                                      Anticimex
                                      • S sineverba
                                        A Offline
                                        A Offline
                                        Anticimex
                                        @sineverba your config seem correct.
                                        • S Offline
                                          sineverba
                                          A small update.
                                          1 - I did delete the library and re-downloaded from Github
                                          2 - I did clear the EEPROM of gateway
                                          3 - I did clear the EEPROM of a new Atmega328 (for relay / actuactor)
                                          4 - I did reinstall the Gateway sketch and the sketch for the relay heater, with signing.
                                          ..... it works......
                                          Yes, too many changes all together..... And fortunately I did receive today the PCBs for it, so in next days I will solder it on a firm base and not on breadboard.....
                                          After 30 min, no working anymore...... :( :( Fake alarm.... maybe some trouble with breadboard, maybe oxyde.... I will test in some day on PCB.
