  3. How to get relay state?
5 Posts 3 Posters 2.2k Views 1 Watching
  • C
    C
    C.r.a.z.y.
    repeater started, id 100
    send: 100-100-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
    send: 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 100-100-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
    send: 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 100-100-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    send: 100-100-0-0 s=2,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    send: 100-100-0-0 s=3,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    I have 3 relays and i want to make a logic something like this; if 3.relay is on than 1. relay is off
    How can i get relay status in orginal sketch?
    if (message.type==V_LIGHT) {
    // Change relay state
    // Store state in eeprom
    • daulagariD
      daulagariD
      daulagari
      On http://www.mysensors.org/build/relay you will find apart from the Relay also a RelayWithButtonActuator Example.
      Do you have some kind of feedback from the relay indicating it's status? If so, connect that to the button input and done!
      C 1 Reply Last reply
      • daulagariD daulagari
        C
        C
        C.r.a.z.y.
        @daulagari Thank you. i am trying to learn "message.xxxxx" but it is hard for me.
        How can i get 1-2-3 variables from "message.xxxxx"? So i can find which relay get a command.
        http://www.mysensors.org/build/sensor_api#the-full-api this link is very useful but very hard for me...
        +++ i have some trouble with your link ; http://forum.mysensors.org/topic/738/relaywithbuttonactuator-example-with-touch-sensor/7
        • C C.r.a.z.y.
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @C.r.a.z.y.
          something like:
          if (message.sensor == CHILD_ID)
            if (message.type == V_VAR2)
            //etc....
            @C.r.a.z.y.
            something like:
              //etc....
            C
            C
            C.r.a.z.y.
            @BulldogLowell That's it! Thank you :+1:
            if (message.sensor==1 && message.getBool()==true)
