  3. The gateway mqtt restarts when the node is absent
17 Posts 5 Posters 4.0k Views 5 Watching
  • M Offline
    M Offline
    miclane
    I have a malfunction on an MQTT ethernet gateway.
    When I publish from the controller to activate a relay type node, if the node is not powered on, the gateway restarts.
    Below the gateway trace :
    0;255;3;0;9;Message arrived on topic: mhs4-in0/205/1/1/0/2
    0;255;3;0;9;!TSF:MSG:SEND,0-0-205-205,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    If the node is powered on, the gateway does not rebel and the message is sent to the node.
    Is there an explanation? a fix?
    Thank you.
    • rozpruwaczR Offline
      rozpruwaczR Offline
      rozpruwacz
      @miclane said in The gateway mqtt restarts when the node is absent:
      what is the hardware for the gateway ?
      • M Offline
        M Offline
        miclane
        Arduino UNO R3 + Ethernet shield W5100 + NRF24L01+
        Thank you.
        • rejoe2R Offline
          rejoe2R Offline
          rejoe2
          In case your' using Arduino IDE:
          What verion of the board definition are you using? (see board manager). Try a rather new one or one <=1.6.11, if that doesn't help.
            rozpruwaczR Offline
            rozpruwacz
            maybe your power supply is not able to provide enough current ? How you power it ? Do you use NRF24L01 with amplifier ? If yes than connecting nrf to 3.3v rail from the arduino mey be not a good idea, it can provide maximum of 150mA.
            • M Offline
              M Offline
              miclane
              Arduino IDE : 1.8.2
              API MySensors : 2. 1. 1
              I rephrase my question:
              When the remote node is powered on, the gateway receives the MQTT message and transmits it to the node. It's OK.
              When the remote node is not powered on, the gateway receives the message MQTT but reboots immediately.
              It would seem that the remote node not powered up disturbs the gateway.
              Thank you.
                rozpruwaczR Offline
                rozpruwacz
                Yeah, and what seems to be is almost never what it actually is ;)
                  rozpruwaczR Offline
                  rozpruwacz
                  Oh, and my suspicion is that the gateway send much more packets when node is not responding which make it consume more power and this couses the voltage to drop and restarts the gateway.
                  rejoe2R 1 Reply Last reply
                  • rozpruwaczR rozpruwacz
                    rejoe2R Offline
                    rejoe2R Offline
                    rejoe2
                    @rozpruwacz said in The gateway mqtt restarts when the node is absent:
                    This sounds also logic to me.
                    Wrt. to the Point Board-Def:
                    1.8.2 is the IDE Version, but not the relevant Board Def. version. As already mentionned, to get this info you have to look inside the board manager (should be in tools menue).
                    • M Offline
                      M Offline
                      miclane
                      Maybe that's the explanation ...
                      My gateway is mains powered with 9V and 500mA power.
                      Nobody found this problem?
                      It is true that a node relay type should normally be always powered if you want to control ...
                      I will see if I can test with a more powerful diet.
                      Thank you.
                      • M Offline
                        M Offline
                        miclane
                        Board def :
                        BN: Carte inconnue
                        VID: 1A86
                        PID: 7523
                        SN: Envoyez un croquis pour l'obtenir
                        • M miclane
                          Board def :
                          BN: Carte inconnue
                          VID: 1A86
                          PID: 7523
                          rejoe2R Offline
                          rejoe2R Offline
                          rejoe2
                          Board def :
                          BN: Carte inconnue
                          VID: 1A86
                          PID: 7523
                          This is also not what I ment. Please click "Tools > Board > Board Manager" and then look for the Uno (or whatever you have chosen as target for compiling). Pictures you may find here: https://learn.sparkfun.com/pages/CustomBoardsArduino
                          • M Offline
                            M Offline
                            miclane
                            Arduino AVR Boards Built-In by Arduino version 1.6.18
                            • M miclane
                              zboblamontZ Offline
                              zboblamontZ Offline
                              zboblamont
                              @miclane ![alt text](0_1512066961355_upload-eea51e95-1285-485f-842e-1e70998b00b5 image url)
                              • M Offline
                                M Offline
                                miclane
                                Arduino/Genuino Uno :blush:
                                • M Offline
                                  M Offline
                                  miclane
                                  The 2.2.0-rc.1 version in development seems to solve the problem.
                                  See also the message : https://forum.mysensors.org/topic/6684/serial-gateway-restarting/30
                                  Can you explain the change in the new version?
                                  Thank you.
                                  • M Offline
                                    M Offline
                                    Manuel Bardea
                                    I had the gateway reboot problem since 2.1.1. After initial startup, the gateway would keep rebooting after receiving messages from nodes. After a while it seems to stabilize.
                                    I tried 2.2.0-rc.1 as you suggested and I don't see that problem any more. Thank you!
                                    12.0k
