  3. Supercap Solar Powered Mysensors nodes as cheap as possible
98 Posts 6 Posters 34.3k Views 8 Watching
    #70
    Three supercaps? Sounds like you're leaving the zone of "as cheap as possible." I'd also be leary of a solar design where falling below "x" voltage leaves the system in a state it can't recover from without human intervention. Murphy's Law. Stuff happens.
      Well, I said 3 because I have 3 and I paid 3.35€ for 2, so it is not that expensive. The problem is that I would need to add something that would wait for the voltage to reach 1V after it has dropped below 0.8V before giving power to the booster: that is where a charge controller may come handy. Unfortunately I have no sufficient knowledge on how to solve this problem, so for now the code and 3 supercaps would have to do :D
        #72
        @gohan You can solve that using a voltage detector. 0.2v hysteresis would not be uncommon. So, it would cut the current to your boost converter when the voltage drops below 0.8v, and it wouldn't allow it to come back on again until your supercap voltage reaches 1.0v.
          do you have an example I could take a look? I never used them
            @gohan Not really, but the datasheets for voltage detector chips would have example circuits.
              #75
              They're commonly used in brownout detectors and also circuits that do automatic resets if the voltage drops below a particular threshold. Not sure whether Aliexpress has premade circuits you can just buy, which seems to be your preference. Maybe. I haven't looked for that.
                #76
                @gohan said in Supercap Solar Powered Mysensors nodes as cheap as possible:
                I'm just remembering now that I used a voltage detector in this project, where in the comments I gave you a detailed walk-thru explanation for how it worked:
                https://www.openhardware.io/view/396/Simple-Solar-Supercap-Charger#tabs-instructions
                The design files include a schematic.
                  I believe I found another problem: the discharge I am seeing in the supercaps, I am suspecting it is due to the self discharge as it is not affected by the sleep time and the adding of the second supercapacitor.
                  As usual the Chinese stuff it is just worth the money you pay for it.
                    @gohan What exactly is it that you're noticing?
                      wrote on last edited by gohan
                      #79
                      Looking at how quickly the voltage drops over time, I'm seeing no big difference between sending data every 10/30/60 minutes and even adding a second supercapacitor so I'm assuming they are just junk
                      I'm seriously considering ditching the supercaps and go with a LiFePo4 battery and leaving just the mcp1700 to keep the battery at 3.3v
                        @gohan Maybe before giving up entirely, perhaps you want to try a quality supercap in place of the shoddy one?
                          #81
                          Do you have any suggestion on something of decent quality and not too high price? I mean something of at least 100F but that doesn't cost like 10$
                          mfalkviddM NeverDieN 2 Replies Last reply
                            @gohan do you really need 100F? How much energy does your node consume? Maybe it is easier to get the energy consumption down than to find a cheap huge capacitor wih low self-discharge?
                              Well it probably doesn't need that much, but I plan to add more sensors and I need to compensate for the winter days when it's cloudy and the daylight is shorter. Of course I could expose the solar panel to direct sunlight to optimize the charging but it would be exposed to harsher weather conditions and the sun will cause the temperature reading to be higher.
                                #84
                                https://www.digikey.com/products/en/capacitors/electric-double-layer-capacitors-edlc-supercapacitors/61?k=avx+supercap&k=&pkeyword=avx+supercap&pv2049=u100F&mnonly=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
                                AVX is a good brand. At least worth a shot to test your idea. If it doesn't meet your expectations, then it's not the supercap's fault. If it turns out to be overkill, you can downgrade from there. Or just start with the higheswt capacity AVX supercap that you think is affordable and make your give-up decision after first testing with that.
                                gohanG NeverDieN 2 Replies Last reply
                                  #85
                                  @mfalkvidd said in Supercap Solar Powered Mysensors nodes as cheap as possible:
                                  I agree, but I think he just wants to quickly test his proof-of-concept first without thinking about it too hard. Kinda a first-fit rather than best-fit search pattern. We've all done it, I'm sure.
                                    #86
                                    @neverdie 8$ it is not bad but still 6x the initial price I was thinking. Also 8$ is the cost of 3 or 4 LiFePo4 AA batteries that are less temperature sensitive than lipo but can still hold a lot more energy than a supercapacitor and have the right 3.3v working voltage avoiding the need for a voltage regulator/booster . I'll think about it
                                      #87
                                      @neverdie said in Supercap Solar Powered Mysensors nodes as cheap as possible:
                                      Or just start with the highest capacity AVX supercap that you think is affordable
                                        I always like to stay on the safe side and plan ahead. Now I need to find out quickly if the solar panel is actually able to provide enough power to keep the node running even with short daylight ( I am thinking about using the LiFePO4 battery charged at 3.1V and see if it can reach the 3.3V or if it drops below 3V); meanwhile I'll try to do a runtime test on the supercaps and try to see how long I can power a node without sleep and make an estimate for a target capacity of a good quality supercap
                                          The LiFePO4 battery setup was unable to charge the battery (maybe because I didn't study how to charge those batteries). I am now back to the 5V supercaps but with the HW radio to see how it works and I noticed the TX power dropped from 40% to 0% so the power amplifier is actually doing its job
