  3. [SOLVED]ESP8266_MQTT gate RFM69 not communicate with node
6 Posts 4 Posters 1.7k Views 4 Watching
  • W
    W
    wanvo
    wrote on last edited by wanvo
    Hi guys.
    I loaded the following code into my gate
    //#define MY_BAUD_RATE 9600
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    //#define MY_RFM69_FREQUENCY   RF69_868MHZ
    #define MY_RFM69_NEW_DRIVER
    #define MY_DEBUG_VERBOSE_RFM69
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    // Set WIFI SSID and password
    //#define MY_ESP8266_SSID "OrPiZero"
    //#define MY_ESP8266_PASSWORD "orangepi"
    #define MY_ESP8266_SSID "wanvo"
    #define MY_ESP8266_PASSWORD "merkulovanastya"
    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    // MQTT broker ip address.
    //#define MY_CONTROLLER_IP_ADDRESS 10, 0, 0, 1
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 107
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <ESP8266WiFi.h>
        Serial.setDebugOutput(true);
    And the gate does not try to search for nodes. This is what I get from the serial debugger
    MCO:BGN:INIT GW,CP=RPNGE---,VER=2.2.0-rc.2
    238 TSF:LRT:OK
    240 TSM:INIT
    241 TSF:WUR:MS=0
    242 RFM69:INIT
    243 RFM69:INIT:PIN,CS=15,IQP=2,IQN=2
    247 RFM69:PTX:LEVEL=5 dBm
    250 TSM:INIT:TSP OK
    251 TSM:INIT:GW MODE
    253 TSM:READY:ID=0,PAR=0,DIS=0
    256 MCO:REG:NOT NEEDED
    scandone
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with wanvo, channel 7
    dhcp client start...
    761 .ip:192.168.0.106,mask:255.255.255.0,gw:192.168.0.1
    1261 .1261 IP: 192.168.0.106
    1263 MCO:BGN:STP
    1265 MCO:BGN:INIT OK,TSP=1
    1267 IP: 192.168.0.106
    1269 Attempting MQTT connection...
    2275 MQTT connected
    2277 Sending message on topic: mygateway1-out/0/255/0/0/18
    pm open,type:2 0
    Noda is on, but does not see the gate.
    Tell me, what is the reason for this behavior of the gate?
    • W wanvo
      Hi guys.
      238 TSF:LRT:OK
      240 TSM:INIT
      241 TSF:WUR:MS=0
      242 RFM69:INIT
      250 TSM:INIT:TSP OK
      scandone
      f 0, scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 5
      cnt
      1263 MCO:BGN:STP
      2275 MQTT connected
      pm open,type:2 0
      Welcome to the MySensors community @wanvo !
      A gateway will never scan for nodes. The output you posted is looks normal.
      Could you post the output of your node?
      • W
        W
        wanvo
        My Node out
         __  __       ____
                |___/                      2.2.0-rc.2
        18 MCO:BGN:INIT NODE,CP=RPNNA---,VER=2.2.0-rc.2
        28 TSM:INIT
        28 TSF:WUR:MS=0
        32 TSM:INIT:TSP OK
        34 TSM:INIT:STATID=1
        36 TSF:SID:OK,ID=1
        38 TSM:FPAR
        1038 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        3045 !TSM:FPAR:NO REPLY
        3047 TSM:FPAR
        4050 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6060 !TSM:FPAR:NO REPLY
        6062 TSM:FPAR
        7065 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        9072 !TSM:FPAR:NO REPLY
        9074 TSM:FPAR
        10076 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        12083 !TSM:FPAR:FAIL
        12085 TSM:FAIL:CNT=1
        12087 TSM:FAIL:DIS
        12089 TSF:TDI:TSL
        22093 TSM:FAIL:RE-INIT
        22095 TSM:INIT
        22097 TSM:INIT:TSP OK
        22099 TSM:INIT:STATID=1
        22104 TSF:SID:OK,ID=1
        22106 TSM:FPAR
        23109 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        25116 !TSM:FPAR:NO REPLY
        25118 TSM:FPAR
        26120 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        28127 !TSM:FPAR:NO REPLY
        I checked this node with the gate OrangePiZero MQTT
        and the RF69 module on this gate was the same as on the ESP8266. Everything worked well.
          Double check the wiring as the gateway is not receiving anything
          • W wanvo
            My Node out
             __  __       ____
                    |___/                      2.2.0-rc.2
            28 TSM:INIT
            28 TSF:WUR:MS=0
            32 TSM:INIT:TSP OK
            36 TSF:SID:OK,ID=1
            38 TSM:FPAR
            3047 TSM:FPAR
            6062 TSM:FPAR
            9074 TSM:FPAR
            12087 TSM:FAIL:DIS
            12089 TSF:TDI:TSL
            22095 TSM:INIT
            22106 TSM:FPAR
            25118 TSM:FPAR
            manutremo
            @wanvo I agree with gohan, check the wiring in the node.
            Don't take this as 100% sure but just as a hint - I think the fact that the node is showing TSP OK points in the direction that the IRQ wire might not be connected properly. I think that if the ones failing are the power wires or the SPI interface wires, you'd see a TSP fail message. Nothing wrong with checking all of them of course.
            • W
              W
              wanvo
              Thanks to all.
              The problem is solved.
              I forgot to add pin definitions to the sketch.
              #define MY_RF69_IRQ_PIN D1
              #define MY_RF69_SPI_CS D8 // NSS. Use MY_RFM69_CS_PIN for the development branch.```
