  3. SecurityPersonalizer will not compile
6 Posts 2 Posters 1.5k Views 2 Watching
  • rzyliusR
    rzyliusR
    rzylius
    hi,
    I am having trouble to compile security personalizer sketch for Sensebender GW
    https://github.com/mysensors/MySensors/tree/development/examples/SecurityPersonalizer
    I receive error log. any advise?
    regards, rimantas
    Arduino: 1.8.5 (Linux), Board: "Sensebender Gateway"
    /root/Arduino/SecurityPersonalizer_v11/SecurityPersonalizer_v11.ino: In function 'void write_eeprom_checksum()':
    SecurityPersonalizer_v11:697: error: 'EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS' was not declared in this scope
      hwWriteConfigBlock((void*)&hash[0], (void*)EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS, 1);
    /root/Arduino/SecurityPersonalizer_v11/SecurityPersonalizer_v11.ino: In function 'void probe_and_print_peripherals()':
    SecurityPersonalizer_v11:1327: error: 'unique_id_t' was not declared in this scope
      unique_id_t uniqueID;
    SecurityPersonalizer_v11:1327: error: expected ';' before 'uniqueID'
    SecurityPersonalizer_v11:1352: error: 'uniqueID' was not declared in this scope
      if (hwUniqueID(&uniqueID)) {
    SecurityPersonalizer_v11:1352: error: 'hwUniqueID' was not declared in this scope
    exit status 1
    • rzyliusR rzylius
      hi,
      regards, rimantas
      exit status 1
      @rzylius which version of the MySensors library do you have installed? The sketch needs to match the library version (use the 2.1.1 sketch with MySensors 2.1.1, or the development sketch with the development version of MySensors).
      • mfalkviddM
        The sketch compiles fine for me:
        Using board 'mysensors_gw_native' from platform in folder: C:\Users\Micke\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5
        Using core 'arduino' from platform in folder: C:\Users\Micke\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.17
        Using library MySensors at version 2.2.0-rc.2 in folder: R:\Documents\Arduino\libraries\MySensors
        Using library Wire at version 1.0 in folder: C:\Users\Micke\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.17\libraries\Wire
        Sketch uses 20764 bytes (7%) of program storage space. Maximum is 262144 bytes.
        (Arduino IDE 1.8.5)
        rzyliusR 1 Reply Last reply
          (Arduino IDE 1.8.5)
          rzyliusR
          rzyliusR
          rzylius
          @mfalkvidd I tested now on my windows machine with fresh install of arduino185. Mysenors library 2.1.1 , mysensors SAMD boards.
          the same outcome
          Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Sensebender Gateway"
          C:\Users\rzylius\Documents\Arduino\SecurityPersonalizer\SecurityPersonalizer.ino: In function 'void write_eeprom_checksum()':
          SecurityPersonalizer:697: error: 'EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS' was not declared in this scope
          C:\Users\rzylius\Documents\Arduino\SecurityPersonalizer\SecurityPersonalizer.ino: In function 'void probe_and_print_peripherals()':
          SecurityPersonalizer:1327: error: 'unique_id_t' was not declared in this scope
          SecurityPersonalizer:1327: error: expected ';' before 'uniqueID'
          SecurityPersonalizer:1352: error: 'uniqueID' was not declared in this scope
          SecurityPersonalizer:1352: error: 'hwUniqueID' was not declared in this scope
          exit status 1
          • rzyliusR rzylius
            the same outcome
            exit status 1
            @rzylius you opened the security personalizer sketch from File->Examples->MySensors ?
            Could you post the sketch?
            My suspicion is that you are still using the development version of the sketch.
              rzyliusR
              rzyliusR
              rzylius
              @mfalkvidd , yes, I see. As I wrote in the first post I was using https://github.com/mysensors/MySensors/tree/development/examples/SecurityPersonalizer code.
              I checked with the Personizer code in the Library examples - it does compile, thanks.
              What I find a bit confusing - in the sketch in exampla library you have to make two keys - USER_SOFT_KEY and USER_KEY (when you do not use hw hashing, and when you do).
              I have mixed configurations. Should those keys be the same in my network for mixed configuration to work?
              thanks for help and sorry for confusion
