  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
132 Posts 32 Posters 89.7k Views 34 Watching
  • T TimO
    @LastSamurai
    The channel is not correct:
    channel="mysensors:multimeter:gwSerial:voltageSensorWZ:volt"
    It's confusing, but that's the way OpenHAB2 handles channels. :confused:
    L
    L
    LastSamurai
    wrote on last edited by LastSamurai
    #76
    @TimO Thanks for your help though I am afraid you mixed something up there. The channel linking to the item itself doesn't really make sense ;)
    Not 100% sure why it did not work earlier for me but I now got it to work like this:
    // thing
    multimeter		voltTHWohnzimmer	[nodeId=1, childId=2]
    // item
    Number 	voltageSensorWZ 		"Spannung [%3f mV]" 		<poweroutlet_eu> 	(grVolt, grWZ)	{ channel="mysensors:multimeter:gwSerial:voltTHWohnzimmer:volt" }
    My error in the code above seems to have been that I defined most as customSensor instead of multimeter.
    • gerritvG
      gerritvG
      gerritv
      @TimO said in openHAB 2.2 binding:
      @LastSamurai
      Is the pattern:
      <binding name>:<mysensors type>:<gateway id>:<thing name>:<data name> ?
      • gerritvG
        gerritvG
        gerritv
        wrote on last edited by gerritv
        #78
        Just to let you know that I am very happy with this binding.
        One thing for others to be aware of:
        If you use PaperUI for configuring etc, make sure you leave Simple Mode off if you expect to use Groups later on. Simple mode adds the items (including the VAR1-5 :-() automatically but they are not 'managed'. This means you will get 404 and 405 errors on trying to edit them later on.
        My solution was to let the binding autodiscover and add the Things. Then add 1 Item manually so that the \\192.168.0.123\openHAB-share\openhab2-userdata\jsondb\org.eclipse.smarthome.core.items.Item.json
        file gets created and filled with an example to clone. I then added the various sensors using Name of pattern <binding name><sensorname><nodeid>_<dataname>, e.g. "mysensors_light_level_node4_last_update": { "class": "org.eclipse.smarthome.core.items.ManagedItemProvider$PersistedItem", "value": { "groupNames": [ "gLastUpdated" ], "itemType": "DateTime", "tags": [], "label": "Last", "category": "calendar" } },
        You must stop Openhab before editing the file (else you will lose your edits) but once it starts up again you will see the Items listed in PaperUI (and VSCode if you use that). You can then add the Channel/Item links for each Thing.
        • F
          F
          fredswed
          Thanks for some great work @TimO ! Version 2.2 now works smoothly with my simple OpenHAB setup (2.2 snapshot).
          One thing I noticed is that the gateway thing configuration page says "Disable network sanity check" even though the logic has been reversed in v2.2.
          So the UI needs to be similarly changed to "Enable startup check" instead.
          While I'm at it, could you please also clarify (in the UI) what "Send delay" is? Please also add that timing is in ms. If I understand things correctly it could say "Minimum time between messages sent to the gateway (ms)"
          Also, the comment for "Imperial/Metric selection" could use some clarification. Preferably change the label to "Imperial units" and the explanation to "Use imperial units (default is metric)."
          And finally it would be great to add add that the time is given in "...(minutes)" for the Network sanity check interval.
          • L
            L
            LastSamurai
            I have just updated to the stable openHAB 2.2 Version and everything seemed to be working just fine in the beginning but after the next restart I got this error:
            10:31:19.727 [WARN ] [fig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/binding/binding.xml' in module 'org.openhab.binding.mysensors' could not be parsed: The XmlConfigDescriptionProvider must not be null!
            It seems like I can still control my devices just fine but I just wanted to make sure that this doesn't cause errors down the line. So @TimO any idea where this error is coming from?
            • mythbaiM
              mythbaiM
              mythbai
              After upgrade OH to 2.2 stable release. (2.2_01). I'm having the same issue that zwave binding not working. After Mysensors binding is installed and gateway configured. There is only one serial port visiable in PaperUI, which is /dev/ttyUSB0 that is configured for the serial gateway. I'm using org.openhab.binding.mysensors-2.2.0-SNAPSHOT-serial-fix.jar.
              Also the old 2.1 snapshot version doesn't work either. anyone else experience this issue?
              mythbaiM 1 Reply Last reply
              • jocke4uJ
                jocke4uJ
                jocke4u
                I have issues with MySensors and specifically Energy Sensors where they request latest value.
                See this thread for details: https://forum.mysensors.org/topic/8833/power-sensors-stopped-working
                Any idea how to solve it?
                • L
                  L
                  lesockz
                  iam using "openHAB 2.2.0-1 (Release Build)" as openhabian on a PI3.
                  i've installed "org.openhab.binding.mysensors-2.2.0-SNAPSHOT.jar" as explained in the instructions.
                  configured the thing "MySensors Serial Gateway" to use "/dev/ttyACM0" with Baudrate "38400" because i'm using a pro micro with 8Mhz which isn't capable of 115200 (as far as i know).
                  the Items got discovered fine.
                  Atm i have only one item with
                  #define CHILD_ID_TEMP 0
                  unsigned long SLEEP_TIME = 3 * 1000; // Sleep time between reads (in milliseconds)
                  MyMessage tempMsg(CHILD_ID_TEMP, S_TEMP);
                  Presentation:
                    sendSketchInfo("Temp/Hum/Pre Sensor", "1.2");
                  and Loop:
                    unsigned long currentTime = millis();
                    temperature++;//bme.readTemperature();
                      lastSend = currentTime;
                      send(tempMsg.set(temperature, 2));
                      lastTemp = temperature;
                    sleep(SLEEP_TIME);
                  This is my debug from "openhab-cli showlogs"
                  2018-01-07 13:59:17.676 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;109.00
                  2018-01-07 13:59:17.680 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-01-07 13:59:17.683 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                  2018-01-07 13:59:17.687 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                  And this from Log Viewer
                  2018-01-07 14:00:18.836 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-01-07 14:00:18.841 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                  2018-01-07 14:00:18.846 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                  2018-01-07 14:00:27.561 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:117.00
                  2018-01-07 14:00:27.566 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;117.00
                  2018-01-07 14:00:27.572 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-01-07 14:00:27.577 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                  2018-01-07 14:00:27.582 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                  2018-01-07 14:00:36.301 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:118.00
                  2018-01-07 14:00:36.308 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;118.00
                  2018-01-07 14:00:36.311 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-01-07 14:00:36.315 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                  2018-01-07 14:00:36.318 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                  2018-01-07 14:00:45.034 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:119.00
                  2018-01-07 14:00:45.037 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;119.00
                  2018-01-07 14:00:45.039 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-01-07 14:00:45.042 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
                  2018-01-07 14:00:45.045 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
                  So from log i can see Temp is counting up. but in "Paper Ui"
                  i always get "Temperature -NaN °C" or "Temperature 0 °C"
                  Please correct me if this is the wrong place for this question.
                  Greets Andi
                  • mythbaiM mythbai
                    mythbaiM
                    mythbaiM
                    mythbai
                    @mythbai said in openHAB 2.2 binding:
                    Up my own post. Not many users are using Zwave dongle and Mysensors at the same time? I feel this forum or trend is dead... This problem is driving me crazy, render all my mysensors useless. I'm trying to build a ethernet gateway now...
                    T 2 Replies Last reply
                    • mythbaiM mythbai
                      TimO
                      Hey @mythbai !
                      Could you please download and install the most recent version of the binding? I've not changed anything at the serial code, but while we're trying to figure out the problem, we should be on the same base of code. :-)
                      I too have two serial devices connected to my OpenHAB box, one serial MySensors gateway and one Ebus-Adapter to Ebusd.
                      You may need to execute:
                      feature:install esh-io-transport-mqtt
                      Because the most current version of the binding now supports MQTT gateways.
                      • L lesockz
                        Presentation:
                        and Loop:
                          sleep(SLEEP_TIME);
                        Greets Andi
                        TimO
                        Hello @lesockz !
                        Well your node is sending V_RAIN instead of V_TEMP, so OpenHAB is not able to work with that.
                        Try:
                        MyMessage tempMsg(CHILD_ID_TEMP, V_TEMP);
                        For presentation S_TEMP (== 6) is used, while for set messages V_TEMP (==0) is used.
                        • mythbaiM mythbai
                          TimO
                          wrote on last edited by TimO
                          #87
                          @mythbai While the code for the serial connection in the binding was unchanged for a while it definatly issn't working now together with zwave binding.
                          Some time ago I've prepared a change of the serial library the binding is using. A few first tests looked promising but I didn't find the time to test it. So lets give it a new try: could you please test this binding: OH2 Binding with Serial Refactoring
                          Please remove the old binding with bundle:list, bundle:remove ID before installing the new one.
                          • jocke4uJ
                            jocke4uJ
                            jocke4u
                            I am moving the topic here as more appropriate :) (old ref)
                            I have OH v2.2 and latest MySensors 2.2.0 binding and my power sensors have stopped working.
                            After some investigation it seems they cannot receive the old pulse count value and by that cannot start working.
                            MySensors GW running 2.1.1 and the one power sensor I am testing also 2.1.1 (the rest 1.5.x)
                            The debug (serial monitor) of the sensor shows that
                            3 TSM:INIT
                            4 TSF:WUR:MS=0
                            11 TSM:INIT:TSP OK
                            13 TSM:INIT:STATID=5
                            14 TSF:SID:OK,ID=5
                            16 TSM:FPAR
                            52 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            2060 !TSM:FPAR:NO REPLY
                            2062 TSM:FPAR
                            2098 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            2983 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            2989 TSF:MSG:FPAR OK,ID=0,D=1
                            4106 TSM:FPAR:OK
                            4107 TSM:ID
                            4108 TSM:ID:OK
                            4110 TSM:UPL
                            4147 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            6154 TSM:UPL
                            6159 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
                            6168 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            6173 TSF:MSG:PONG RECV,HP=1
                            6175 TSM:UPL:OK
                            6177 TSM:READY:ID=5,PAR=0,DIS=1
                            6182 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            6189 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            6232 !TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
                            6243 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
                            6259 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                            6305 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=NACK:Heater Energy
                            6349 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=NACK:2.0
                            6391 !TSF:MSG:SEND,5-5-0-0,s=0,c=0,t=13,pt=0,l=0,sg=0,ft=2,st=NACK:
                            6397 MCO:REG:REQ
                            6435 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=NACK:2
                            8476 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
                            10486 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=OK:2
                            10493 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                            10499 MCO:PIM:NODE REG=1
                            10501 MCO:BGN:STP
                            10528 TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                            Got Pulse
                            10534 MCO:BGN:INIT OK,TSP=1
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            No count received. Try requesting it again
                            30570 !TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=NACK:
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            Got Pulse
                            50546 TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=1,st=OK:
                            Got Pulse
                            The sketch looks like this:
                             * Version 1.0 - Henrik EKblad
                             * This sketch provides an example how to implement a distance sensor using HC-SR04
                             * Use this sensor to measure KWH and Watt of your house meeter
                             * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                             * The sensor starts by fetching current KWH value from gateway.
                             * Reports both KWH and Watt back to gateway.
                             * Unfortunately millis() won't increment when the Arduino is in
                             * sleepmode. So we cannot make this sensor sleep if we also want
                             * to calculate/report watt-number.
                             * http://www.mysensors.org/build/pulse_power
                            // Enable debug prints
                            #define MY_NODE_ID 5
                            #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                            #define CHILD_ID 0              // Id of the sensor child
                            unsigned long SEND_FREQUENCY =
                                20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                            double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                            bool pcReceived = false;
                            unsigned long oldPulseCount = 0;
                            unsigned long oldWatt = 0;
                            double oldKwh;
                            unsigned long lastSend;
                            MyMessage wattMsg(CHILD_ID,V_WATT);
                            MyMessage kwhMsg(CHILD_ID,V_KWH);
                            MyMessage pcMsg(CHILD_ID,V_VAR1);
                              request(CHILD_ID, V_VAR1);
                              pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                              attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                              lastSend=millis();
                              sendSketchInfo("Heater Energy", "2.0");
                              present(CHILD_ID, S_POWER);
                              unsigned long now = millis();
                              if (pcReceived && sendTime) {
                                if (watt != oldWatt) {
                                  if (watt<((unsigned long)MAX_WATT)) {
                                  Serial.print("Watt:");
                                  Serial.println(watt);
                                  oldWatt = watt;
                                // Pulse cout has changed
                                if (pulseCount != oldPulseCount) {
                                  send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                                  double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                                  oldPulseCount = pulseCount;
                                  if (kwh != oldKwh) {
                                    send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                                    oldKwh = kwh;
                                lastSend = now;
                              } else if (sendTime && !pcReceived) {
                                // No count received. Try requesting it again
                                Serial.println("No count received. Try requesting it again");
                                lastSend=now;
                              Serial.print("MessageType:");
                              Serial.println(message.type);
                              Serial.print("Message:");
                              Serial.println(message.getLong());
                              if (message.type==V_VAR1) {
                                pulseCount = oldPulseCount = message.getLong();
                                Serial.print("Received last pulse count from gw:");
                                Serial.println(pulseCount);
                                pcReceived = true;
                            void onPulse()
                              Serial.println("Got Pulse");
                              unsigned long interval = newBlink-lastBlink;
                              if (interval<10000L) { // Sometimes we get interrupt on RISING
                                return;
                              watt = (3600000000.0 /interval) / ppwh;
                              lastBlink = newBlink;
                              pulseCount++;
                            Today I realized that I likely need to have item(s) created in OH to save the values - so created Var1 (and then added one after another with no success). Currently it looks like:
                            Number CellarAirHeaterSensorWatt   "Airheater Watt" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:watt", mqtt=">[rabbitmq:/myhouse/airpump/sensor/power:state:*:Power,sensor=${itemName},location=airpump watt=${state} ]" }
                            Number CellarAirHeaterSensorKwh    "Airheater Kwh" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:kwh", mqtt=">[rabbitmq:/myhouse/airpump/sensor/power:state:*:Power,sensor=${itemName},location=airpump kwh=${state} ]" }
                            Number CellarAirHeaterSensorVar   "Airheater Var" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:var" }
                            Number CellarAirHeaterSensorVar1   "Airheater Var1" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:var1" }
                            Number CellarAirHeaterSensorVA   "Airheater VA" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:va" }
                            Still no success!
                            Do you have any idea what's wrong?
                            • T TimO
                              mythbaiM
                              mythbaiM
                              mythbai
                              @timo said in openHAB 2.2 binding:
                              @TimO Thank you very much! Here is what I got with the new jar:
                              Initial bundle:uninstall, and replace jar works. But after server reboot, the MySensor binding is not loading due to some "Multiexception" on framework level (sorry didn't capture that log).
                              I tried to restart binding in console:
                              openhab> bundle:restart 233
                              Error executing command: Error restarting bundles:
                                      Unable to start bundle 233: Could not resolve module: org.openhab.binding.mysensors [233]
                                Unresolved requirement: Import-Package: org.eclipse.smarthome.io.transport.mqtt
                              This is an easy fix by "feature:install openhab-transport-mqtt". And after that bundle works! (why do I have to install mqtt transport here .... )
                              2). After fix above, did a server reboot. Got MySensors thing discovery related exceptions, but both zwave and mysensors binding loaded, and things got online. The fix actually works!!! just with some minor glitch:
                              09:04:38.710 [ERROR] [org.openhab.binding.mysensors        ] - [org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService(221)] Error during instantiation of the implementation object
                              java.lang.InstantiationException: org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService
                                      at java.lang.Class.newInstance(Class.java:427) [?:?]
                                      at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:237) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
                                      at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
                                      at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
                                      at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1714) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
                                      at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
                                      at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
                                      at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
                                      at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
                                      at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
                                      at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
                                      at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
                                      at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
                                      at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
                                      at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
                                      at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
                                      at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
                                      at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
                                      at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
                                      at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
                                      at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
                                      at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
                                      at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
                                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
                                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
                                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
                                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
                                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
                                      at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
                              Caused by: java.lang.NoSuchMethodException: org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService.<init>()
                                      at java.lang.Class.getConstructor0(Class.java:3082) ~[?:?]
                                      at java.lang.Class.newInstance(Class.java:412) ~[?:?]
                                      ... 70 more
                              09:04:39.069 [WARN ] [org.openhab.binding.mysensors        ] - FrameworkEvent WARNING - org.openhab.binding.mysensors
                              org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
                                      at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) [?:?]
                              It's a good start, I now have all my sensors working now!
                              • mythbaiM mythbai
                                        ... 70 more
                                TimO
                                @mythbai Thank you for reporting back! I'm glad it is working now.
                                The transport-mqtt feature is now needed because the support for MQTT GW is now part of the binding and the fix I've provided to you is based on the current code base.
                                The exception is completely unrelated to your problem and will do no harm. It only occures on startup and will soon be fixed!
                                • jocke4uJ jocke4u
                                  3 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  11 TSM:INIT:TSP OK
                                  14 TSF:SID:OK,ID=5
                                  16 TSM:FPAR
                                  2062 TSM:FPAR
                                  4106 TSM:FPAR:OK
                                  4107 TSM:ID
                                  4108 TSM:ID:OK
                                  4110 TSM:UPL
                                  6154 TSM:UPL
                                  6175 TSM:UPL:OK
                                  6397 MCO:REG:REQ
                                  10501 MCO:BGN:STP
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  Got Pulse
                                  double oldKwh;
                                    lastSend=millis();
                                        oldWatt = watt;
                                          oldKwh = kwh;
                                      lastSend = now;
                                      lastSend=now;
                                      pcReceived = true;
                                  void onPulse()
                                      return;
                                    pulseCount++;
                                  Still no success!
                                  TimO
                                  #91
                                  @jocke4u The request needs to be handled with rules because it is not allowed to access the value of an item via the binding API :smirk:.
                                  Please post the request (from the OpenHAB log, enable DEBUG with log:set DEBUG org.openhab.binding.mysensors if not already done in the karaf console) and we'll figure out the rule.
                                  NickBuilderN jocke4uJ 2 Replies Last reply
                                  • T TimO
                                    NickBuilderN
                                    NickBuilderN
                                    NickBuilder
                                    wrote on last edited by NickBuilder
                                    #92
                                    @timo regarding the issue with the pulse power node, the same as @jocke4u. I'm using a version of the same sketch and also the latest snapshot jar.
                                    This is the feedback in my openhab.log while looking att the debug level messages from the binding.
                                    15:59:15.829 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
                                    15:59:15.834 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
                                    15:59:15.839 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
                                    15:59:15.844 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 50
                                    15:59:15.849 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
                                    15:59:15.854 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
                                    15:59:15.859 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
                                    15:59:15.864 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 50
                                    15:59:15.869 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
                                    15:59:15.874 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
                                    15:59:15.879 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
                                    As you can see the messages are quite frequent making it quite tedious for me to extract the relevant log messages. I'm no expert in browsing and searching text files from the command line.
                                    I guess because I'm using a version of the standard sketch my node does not wait for a response to the request before starting to count. I'm not sure how the node can neglect the response. Anyhow I restarted my node and now it tried to SET a new count instead.
                                    2018-01-10 16:26:22.341 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                                    2018-01-10 16:26:22.571 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                                    2018-01-10 16:26:22.791 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                                    2018-01-10 16:26:23.011 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                                    2018-01-10 16:26:23.230 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                                    Hopefully this is useful feedback.
                                    jocke4uJ 1 Reply Last reply
                                    • T TimO
                                      jocke4uJ
                                      jocke4uJ
                                      jocke4u
                                      Hi @timo ,
                                      Here is the log when restarting the sensor:
                                      17:27:58.562 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;0;0;17;2.1.1
                                      17:27:58.573 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Presentation Message received
                                      17:27:58.583 [WARN ] [ors.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                                      17:27:58.593 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;6;0
                                      17:27:58.603 [DEBUG] [ors.internal.gateway.MySensorsGateway] - I_CONFIG request received from M, answering: (is imperial?)false
                                      17:27:58.614 [DEBUG] [orsAbstractConnection$MySensorsWriter] - Sending to MySensors: 5;255;3;0;6;M
                                      17:27:58.674 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;11;Heater Energy
                                      17:27:58.682 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;12;2.0
                                      17:27:58.690 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;0;0;0;13;
                                      17:27:58.698 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Presentation Message received
                                      17:27:58.705 [WARN ] [ors.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                                      17:27:58.719 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;0;2;0;24;
                                      17:27:58.727 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 5 found in gateway
                                      17:27:58.735 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 0 found in node 5
                                      17:27:58.743 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
                                      • NickBuilderN NickBuilder
                                        jocke4uJ
                                        jocke4uJ
                                        jocke4u
                                        @nickbuilder Check the code here and there is a SEND_FREQUENCY of 20 sec - would reduce the load quite a lot :)
                                        • T
                                          TimO
                                          @jocke4u & @NickBuilder :
                                          Thank you! This will help me to find a solution. For reference, here is the corresponding issue on github: https://github.com/tobof/openhab2-addons/issues/69
