  3. Atmega 328p memory
Atmega 328p memory
38 Posts 7 Posters 9.6k Views 7 Watching
  • dbemowskD dbemowsk
    @neverdie Will the nRF52s work on my nRF24 network?
    @dbemowsk said in Atmega 328p memory:
    You mean is it backward compatible? Yes, if you use the mysensors code base. You can thank @d00616 for that. :) Otherwise it wouldn't be.
    • dbemowskD
      dbemowskD
      So looking at a dev board like this one to test things, one thing that I do not see is any analog inputs. I am also wondering about an I2C connection. I am also assuming that the black connector is the programming header.
        @dbemowsk Most of the GPIO pins can be assigned to be whatever you want. For instance, only one pin can serve as RESET (pin 21), but it can be re-assigned to work as an analog pin if you prefer to use it that way. Likewise, pins can be re-assigned to serve as I2C if you prefer that. All this gives you more freedom in the trace layouts. i.e. it's a good thing.
        dbemowskD 1 Reply Last reply
          dbemowskD
          dbemowskD
          @neverdie So they are not strictly data lines... That is nice. So what you are saying is that if I wire them to the headers on my board, I can just wire the header pins to the closest GPIO lines and then just reference them to what they are in the sketch. Can any of them be SPI bus lines also?
            #21
            @dbemowsk There may be some caveats in the datasheet, but basically yes.
            Good luck!
            • dbemowskD
              dbemowskD
              I figured I could do my testing with one of the dev boards, and if everything works I can just design a board using one of the surface mount modules. Thanks for all the feedback.
                #23
                For instance, I would suggest not using the NFC pins if you can avoid it. They can be redefined, but they aren't 100% equivalent to the other pins.
                  dbemowskD
                  dbemowskD
                  @neverdie With the number of pins, I am sure I can avoid some without a problem.
                    #25
                    @dbemowsk That's the spirit! You'll know soon enough if you step on something you shouldn't.
                    • dbemowskD
                      dbemowskD
                      WIth a 32 bit processor, 64kB of ram and 512kB of flash, it should have more than enough speed and space for what I want to do. Heck, I could probably fit some onboard sensors like temp and humidity and possibly power monitoring if I can figure out something with my power supply board.
                        #27
                        @dbemowsk In practical terms, it's even better than that, because the compiled code is more dense.
                          dbemowskD
                          dbemowskD
                          @neverdie So with all of this, would I need to upgrade my gateway to 2.1 or 2.2? I am currently on 2.0.
                            #29
                            @dbemowsk Forget those. You need to run the most current developers release. It's the safest choice. Perhaps there's a more precise answer, but....
                              dbemowskD
                              dbemowskD
                              @neverdie I always hate upgrading the gateway because it ends up being, do the upgrade and HOPE everything that I have on my network plays well with it. I usually just pull the old pro mini and save it. Then flash a new one with the updated version. That way if I have to fall back I can.
                                #31
                                Or just set up a parallel network to test on until you're comfortable with it. That's what I do. That way you don't drop the ball with whatever currently works. Hardware is cheaper than your time, and you can recycle it endlessly.
                                  dbemowskD
                                  dbemowskD
                                  @neverdie Great idea. I would just need another FTDI adapter and set up another MySensors instance on my Vera. If I have to order the nRF52, I can order an extra FTDI at the same time. Then I can take my time porting over things to the new gateway and phase out the old one as time and resources permit.
                                  Nca78N 1 Reply Last reply
                                  • dbemowskD
                                    dbemowskD
                                    This is why I LOVE this forum....
                                      #34
                                      Since you're the "new guy," be sure to document your progress as best you can. That will help other "new guys" follow in your footsteps. The more new guys the better. That's what I did with the Bluetooth Actiion! thread, even though, ironically, it ended up having nothing to do with bluetooth per se. But who knew? Where you end up isn't always the direction you were heading originally.
                                        dbemowskD
                                        dbemowskD
                                        @neverdie Well, I am not necessarily new to MySensors, but new to this end of it. I can document and post.....
                                        You know I haven't checked out the bluetooth thread, well, because I thought it was about bluetooth. Looks like I have some reading to do.
                                          It's worth a read. :)
