  3. MySensors - Get Temperature value from another node through the Gateway
36 Posts 7 Posters 9.8k Views 6 Watching
  • J
    J
    Joe13
    wrote on last edited by Joe13
    #23
    @rejoe2 i got to understand quite some things from all what you have shared and thanks for that. just a bit more confusion left.
    so i have node 1N/child id 1C to send the temp value to the LCD node 4N / child id 4C, so is the below correct.
    send(1N.setDestination(4).setSensor(4C).set(temperature, 1));
    And if node 1N / child id 1C is to send the temp value to GW(DOMOTICZ), is the below correct and how can node 4/child 4C (LCD) retreive this value from GW.
    MyMessage pcMsg(1C,V_VAR1);
    send(pcMsg.set(TEMP from this sensor))
    rejoe2R 1 Reply Last reply
    • J Joe13
      rejoe2R
      rejoe2R
      rejoe2
      wrote on last edited by rejoe2
      #24
      @joe13 Your naming convention ist a bit confusing.
      In general, for sending info to the controller, you can use the "short" send() command in the form they are included in the examples from the Build section.
      The additional parts between the points (setDestination() and setSensor()) just change the default values (setDestination usually is "0" for the GW; setSensor() is typically defined in the ...Msg() in each sketches header section (in your example: pcMsg()). V_VAR1 btw seems not to be the right type for this kind of message (Temp).
      You may have a look at the "Temperature" sketch: This is a good official example how to use the setSensor() variable dynamically.
      Hope this helps to light out the remaining questions, it's quite hard for me to explain all these things. I myself learned about these mechanisms by studiing the examples and doing some (...) tests, but I'm not an educated programmer, so I am not able to lead you to the right keywords for theoretical backgroud.
      J 1 Reply Last reply
      • rejoe2R rejoe2
        J
        J
        Joe13
        @rejoe2 Completely understand and thanks for your time on all this. Probably i am not getting something very basic here.
        this is the code that i am using to send the data to GW. i juse put in a constant num to send for VAR 1
        MyMessage pcMsg(0,V_VAR1);
        send(pcMsg.set(50));
        and in my LCD node, which doesnt have any physical sensor, trying to get that VAR1 value like below
        request(0, V_VAR1);
          if (message.type==V_VAR1) {
             Serial.println(message.getLong());
        but the Serial monitor always shows 0 and just trying to figure out why. I am quite sure that it is probably a really minor change that needs to be done
        Requested temp from gw VAR1223055 TSF:MSG:READ,0-0-1,s=0,c=2,t=24,pt=0,l=0,sg=0:
        Incoming change for sensor:0, New status: 0
        rejoe2R K 2 Replies Last reply
        • J Joe13
          request(0, V_VAR1);
          rejoe2R
          rejoe2R
          rejoe2
          @joe13 As you are doing the data transfer through the controller: How did you transfer the info from Node A, V_VAR1@Child X to Node B, V_VAR1@Child Y? If you are issuing request(), you are asking the controller to send the later info.
          How to manage that is not a MySensors question - it's controller specific. @FHEM, one would use typically a "notify"-function to copy incoming info from one node to the other.
          • J Joe13
            request(0, V_VAR1);
            K
            K
            kimot
            @joe13
            First, you send to controller command to store V_VAR1 for node X ( your temp node )
            Secondly you ask controller for V_VAR1 of node Z ( different node ! - your LCD)
            And there is nothing stored, so it returns 0.
            You must write some scripts in controller to write correct value for correct V_VAR.
            For example if temperature from node X changed ( or periodically every minute etc )
            copy this temperature to V_VAR1 of your LCD node Z.
            How you "copy" this, depends on controller sw ability.
            Then, if LCD node asks controller for V_VAR1, it obtain what you want.
            • K
              K
              kimot
              wrote on last edited by kimot
              #28
              Here are types, which can be requested from Domoticz for example:
              else if (message_type == MT_Req)
              		//Request a variable
              		std::string tmpstr;
              		switch (sub_type)
              		case V_STATUS:
              		case V_PERCENTAGE:
              		case V_RGB:
              		case V_RGBW:
              			if (GetSwitchValue(node_id, child_sensor_id, sub_type, tmpstr))
              				SendNodeCommand(node_id, child_sensor_id, message_type, sub_type, tmpstr);
              		case V_VAR1:
              		case V_VAR2:
              		case V_VAR3:
              		case V_VAR4:
              		case V_VAR5:
              			//send back a previous stored custom variable
              			tmpstr = "";
              			GetVar(node_id, child_sensor_id, sub_type, tmpstr);
              			//SendNodeSetCommand(node_id, child_sensor_id, message_type, (_eSetType)sub_type, tmpstr, true, 1000);
              		case V_TEXT:
              				//Get Text sensor value from the database
              				bool bExits = false;
              				tmpstr = GetTextSensorText(node_id, child_sensor_id, bExits);
              		default:
              			while (1==0);
              		while (1==0);
              	else {
              		//Unhandled message type
              		while (1==0);
              There is V_TEXT too.
              I do not find like handle V_VAR1 in Domoticz, but if create TEXT node with V_TEXT, then I am able store temperature from different node into this V_TEXT of another node, which can be requested by MySensors.
              • J
                J
                Joe13
                #29
                Thanks for all the info. I have not yet started scripting in the Controller. But what you guys have mentioned above makes sense, that passing value from Node A to VAR1 needs to be transferred to Node B VAR1 through the controller. Let me play around with all the info provided above. Probably looks like i would have to do node-node. But my understanding has improved now.
                @kimot is that request code that you mentioned to be part of the MySensors code in the node or is that a Domoticz input?
                • J
                  J
                  Joe13
                  #30
                  As an update.
                  Finally after wrapping my head around the topic and knowing that you cant just send a value from one node in a VAR1 and expect it to just retain that value and get it in another node, i used the node - node communication and it worked!!!.
                  so my send sketch is
                  send(pcMsg.setDestination(1).setSensor(101).set(temperature,1));
                  and receive sketch is
                     request(0, V_VAR1);
                     if (message.sensor==101) {
                      Serial.print("\n");
                      Serial.println(message.getFloat());
                  I am able to get the value from the second node. But was just wondering why '0' is used in the request(0, V_VAR1) call when the value is being directly sent from the 1st node to the 2nd node
                  • J Joe13
                    As an update.
                       request(0, V_VAR1);
                        Serial.print("\n");
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @joe13 The request() call in your loop() is no longer neccessary. Receiving what is sent from another node is handled without that...
                    • rejoe2R rejoe2
                      J
                      J
                      Joe13
                      @rejoe2 thanks works perfectly now.
                      • I
                        I
                        iahim67
                        wrote on last edited by iahim67
                        #33
                        Hi @Joe13, I managed to request information from the Domoticz controller and put it on a LCD (LCD2004A in my case). My Arduino code below, not very polished nor optimized as I am not a programmer :smile: but it works nicely so far. This code running on the Arduino Nano will create 4 text devices on the Domoticz side: LCD1_LINE1, LCD1_LINE2, LCD1_LINE3 and LCD1_LINE4 then it will display what ever Domoticz will put (change) in these text devices. At the end of the Arduino sketch there is a DzVents code that will count both Mysensors devices (except text devices) and Domoticz devices (all) and will place this information in the text device LCD1_LINE3 which will be displayed on my LCD accordingly - on the third line. You can create DzVents (or LUA) code that will place in these text devices virtually anything available in Domoticz, temperature included of course.
                        Second DzVents code at the end of my Arduino code will display on the first line on my LCD the temperature set on a virtual TERMOSTAT device and the current temperature measured with a cheap thermistor on the same node as the LCD device.
                        Comment this line if you use the default radion channel: #define MY_RF24_CHANNEL 83
                        Hope it helps ...
                          LCD2004A 20x4
                            - LCD pin 1 --> GND
                            - LCD pin 2 --> +5V
                            - LCD pin 3 --> (1K - 10K) POTI
                            - LCD pin 5 --> GND
                            - LCD pin 15 --> to +5V in series with 100 OHM (Backlight "+")
                            - LCD pin 16 --> GND (Backlight "-")
                            - LCD function:  RS, E, D4, D5, D6, D7
                            - LCD2004A pins: 4 , 6 ,11 ,12, 13, 14
                            - NANO pins: 3, 4, 5, 6, 7, 8
                            Thermistor: 4K7 / B57164K0472J000 in series with 4K7 resistor
                            TH pin1 to GND
                            TH pin2 to pin2 of the series resistor and together to A0 on the Arduino side
                            Series resistor pin1 to +5V
                            _nominal_resistor adjusted to 4660 (compared to Fluke TK80 thermocouple module + Fluke 87 multimeter)
                            to get the same temperature as the Fluke thermocouple @ around 25 Celsius - each Thermistor requires individual "calibration"
                        #define MY_NODE_ID 240
                        #define MY_REPEATER_FEATURE
                        #define DEBUG 1
                        // Node specific
                        #define SKETCH_NAME "LCD2004A_1_Nano"
                        #define SKETCH_VERSION "1.0_2.2.0"
                        #define SENSOR_DESCRIPTION "LCD1_MySensors"
                        #define LCD_TH "LCD1_TH"
                        #define LCD_LINE1 "LCD1_LINE1"
                        #define LCD_LINE2 "LCD1_LINE2"
                        #define LCD_LINE3 "LCD1_LINE3"
                        #define LCD_LINE4 "LCD1_LINE4"
                        #define LCD_TH_CHILD_ID 241
                        #define LCD_LINE1_CHILD_ID 242
                        #define LCD_LINE2_CHILD_ID 243
                        #define LCD_LINE3_CHILD_ID 244
                        #define LCD_LINE4_CHILD_ID 245
                        // Node specific
                        #include "LiquidCrystal.h"
                        LiquidCrystal lcd(3, 4, 5, 6, 7, 8);
                        int _nominal_resistor = 4660;
                        int _nominal_temperature = 25;
                        int _b_coefficient = 3950;
                        int _series_resistor = 4697;
                        int _pin = 0;
                        String line1 = "line1               ";
                        String line2 = "line2               ";
                        String line3 = "line3               ";
                        String line4 = "line4               ";
                        bool line1received = false;
                        bool line2received = false;
                        bool line3received = false;
                        bool line4received = false;
                        MyMessage msgTemp(LCD_TH_CHILD_ID, V_TEMP);
                        MyMessage msgLine1(LCD_LINE1_CHILD_ID, V_TEXT);
                        MyMessage msgLine2(LCD_LINE2_CHILD_ID, V_TEXT);
                        MyMessage msgLine3(LCD_LINE3_CHILD_ID, V_TEXT);
                        MyMessage msgLine4(LCD_LINE1_CHILD_ID, V_TEXT);
                          // set up the LCD's number of columns and rows:
                          lcd.begin(20, 4);
                          lcd.clear();
                          lcd.home();
                          LCD_test();
                          present(LCD_TH_CHILD_ID, S_TEMP, LCD_TH);
                          present(LCD_LINE1_CHILD_ID, S_INFO, LCD_LINE1);
                          present(LCD_LINE2_CHILD_ID, S_INFO, LCD_LINE2);
                          present(LCD_LINE3_CHILD_ID, S_INFO, LCD_LINE3);
                          present(LCD_LINE4_CHILD_ID, S_INFO, LCD_LINE4);
                          tempReport();
                          if (!line1received) {
                            request(LCD_LINE1_CHILD_ID, V_TEXT);
                        #if DEBUG == 1
                            Serial.println("Requested line1 from gw !");
                            wait(5000, 2, V_TEXT); // wait for 5s or until a message of type V_TEXT is received
                          if (!line2received) {
                            request(LCD_LINE2_CHILD_ID, V_TEXT);
                        #if DEBUG == 1
                          if (!line3received) {
                            request(LCD_LINE3_CHILD_ID, V_TEXT);
                        #if DEBUG == 1
                          if (!line4received) {
                            request(LCD_LINE4_CHILD_ID, V_TEXT);
                        #if DEBUG == 1
                          wait(15000);
                        // Temperature report
                        void tempReport()
                          wait(100);
                          // read the voltage across the thermistor
                          float adc = analogRead(_pin);
                          // set TH_PIN LOW
                          //digitalWrite(TH_PIN, LOW);
                          // calculate the temperature
                          float reading = (1023 / adc)  - 1;
                          reading = _series_resistor / reading;
                          float temperature;
                          temperature = reading / _nominal_resistor;     // (R/Ro)
                          temperature = log(temperature);                  // ln(R/Ro)
                          temperature /= _b_coefficient;                   // 1/B * ln(R/Ro)
                          temperature += 1.0 / (_nominal_temperature + 273.15); // + (1/To)
                          temperature = 1.0 / temperature;                 // Invert
                          temperature -= 273.15;                         // convert to C
                        #if DEBUG == 1
                          Serial.print(F("THER I="));
                          Serial.print(LCD_TH_CHILD_ID);
                          Serial.print(F(" V="));
                          Serial.print(adc);
                          Serial.print(F(" T="));
                          // Send temperature to the controller
                          int ID = message.sensor;
                          if (ID == LCD_LINE1_CHILD_ID) {
                            // Receive line1
                            if (message.type == V_TEXT) {
                              line1 = message.getString();
                        #if DEBUG == 1
                              Serial.print("Sensor: ");
                              Serial.println(ID);
                              Serial.print("Received line1 from gw: ");
                              Serial.println(line1);
                              line1received = true;
                              printline1();
                          if (ID == LCD_LINE2_CHILD_ID) {
                            // Receive line2
                              line2 = message.getString();
                        #if DEBUG == 1
                              Serial.println(ID);
                              Serial.print("Received line2 from gw: ");
                              Serial.println(line2);
                              line2received = true;
                              printline2();
                          if (ID == LCD_LINE3_CHILD_ID) {
                            // Receive line3
                              line3 = message.getString();
                        #if DEBUG == 1
                              Serial.println(ID);
                              Serial.print("Received line3 from gw: ");
                              Serial.println(line3);
                              line3received = true;
                              printline3();
                          if (ID == LCD_LINE4_CHILD_ID) {
                            // Receive line4
                              line4 = message.getString();
                        #if DEBUG == 1
                              Serial.println(ID);
                              Serial.print("Received line4 from gw: ");
                              Serial.println(line4);
                              line4received = true;
                              printline4();
                        // Print line1
                        void printline1() {
                          lcd.setCursor(0, 0);
                          lcd.print(line1.substring(0, 20));
                        // Print line2
                        void printline2() {
                          lcd.setCursor(0, 1);
                          lcd.print(line2.substring(0, 20));
                        // Print line3
                        void printline3() {
                          lcd.setCursor(0, 2);
                          lcd.print(line3.substring(0, 20));
                        // Print line4
                        void printline4() {
                          lcd.setCursor(0, 3);
                          lcd.print(line4.substring(0, 20));
                        // LCD test
                        void LCD_test(void)
                          // show some output
                          lcd.print("hello world, line 1!");
                          lcd.print("hello world, line 2!");
                          lcd.print("hello world, line 3!");
                          lcd.print("hello world, line 4!");
                        On the Domoticz side, this DzVents 2.4.x code will display MySensors devices and Domoticz devices on line 3 of the LCD.
                        Replace MySensorsGW_CH83 with whatever you see in Setup/Devices under the Hardware column for your MySensors devices (i.e. not Domoticz dummy devices ... etc.)
                        return {
                          on = {
                              timer = {'every minute'}
                          execute = function(domoticz)
                              count_mys = domoticz.devices().reduce(function(mys, device)
                                    if (device.hardwareName == 'MySensorsGW_CH83') and (device.deviceSubType ~= 'Text') then
                                        mys = mys + 1 -- increase the accumulator
                                        --domoticz.log(device.hardwareName)
                                    end
                                    return mys -- return count of MySensors devices
                                end, 0)
                                count_domo = domoticz.devices().reduce(function(domo, device)
                                    domo = domo + 1 -- increase the accumulator
                                    --domoticz.log(device.name)
                                    --domoticz.log(device.idx .. " @ " .. device.name)
                                return domo -- return count of Domoticz devices
                                end, 0)
                                domoticz.log("MySDom count " .. count_mys .. "/" .. count_domo)
                                domoticz.devices('LCD1_LINE3').updateText("MySDom count " .. count_mys .. "/" .. count_domo .. "    ")
                          end
                         return {
                            on = {
                                devices = {
                                    'LCD1_TH',
                                    'TERMOSTAT'
                            execute = function(domoticz, LCD1_TH)
                                domoticz.log(LCD1_TH.name)
                                domoticz.log(LCD1_TH.state)
                                domoticz.devices().forEach(function(device)
                                    if (device.name == 'TERMOSTAT') then
                                        domoticz.log(device.state)
                                        domoticz.devices('LCD1_LINE1').updateText("SET " .. device.state .. " ACT " .. LCD1_TH.state .. "`C ")
                                    end
                                end)
                            end
                        • I iahim67
                          Hope it helps ...
                            LCD2004A 20x4
                              - LCD pin 1 --> GND
                              - LCD pin 2 --> +5V
                              - LCD pin 5 --> GND
                              TH pin1 to GND
                          #define DEBUG 1
                          // Node specific
                          // Node specific
                          int _pin = 0;
                            lcd.begin(20, 4);
                            lcd.clear();
                            lcd.home();
                            LCD_test();
                            tempReport();
                          #if DEBUG == 1
                          #if DEBUG == 1
                          #if DEBUG == 1
                          #if DEBUG == 1
                            wait(15000);
                          void tempReport()
                            wait(100);
                            // set TH_PIN LOW
                            float temperature;
                          #if DEBUG == 1
                            Serial.print(adc);
                              // Receive line1
                          #if DEBUG == 1
                                Serial.println(ID);
                                printline1();
                              // Receive line2
                          #if DEBUG == 1
                                Serial.println(ID);
                                printline2();
                              // Receive line3
                          #if DEBUG == 1
                                Serial.println(ID);
                                printline3();
                              // Receive line4
                          #if DEBUG == 1
                                Serial.println(ID);
                                printline4();
                          // Print line1
                          void printline1() {
                          // Print line2
                          void printline2() {
                          // Print line3
                          void printline3() {
                          // Print line4
                          void printline4() {
                          // LCD test
                          void LCD_test(void)
                            // show some output
                          return {
                            on = {
                                      end
                                  end, 0)
                                  end, 0)
                            end
                           return {
                              on = {
                                  devices = {
                                      'LCD1_TH',
                                      'TERMOSTAT'
                                      end
                                  end)
                              end
                          J
                          J
                          Joe13
                          #34
                          @iahim67 Thanks for this. I will definitely give it a try and provide a feedback on this. I am still new to this, but your code is well commented to provide a good guide
                          • J
                            J
                            Joe13
                            @iahim67 . Got tied up some stuffs. I gave DzVents a try as I am totally new to it. Ran some basic stuffs and works perfectly. Will gather some more time and do a full run on this
                            • I
                              I
                              iahim67
                              #36
                              @Joe13, I am new to DzVents too ... but it is a great opportunity to learn:smile:
                              Have a look into the Domoticz installation folder, can't remember now exactly where but there is a sub-folder with interesting examples, when you start reading these examples you may have a better overall understanding of how DzVents works.
                              Their wiki is also very usefull:
                              https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting
                              Have fun @Joe13 ...
