  2. Feature Requests
  3. Would You Like Support For ESP8266 'Nodes'?
Scheduled Pinned Locked Moved Feature Requests
34 Posts 6 Posters 9.1k Views 5 Watching
  • K
    K
    kimot
    But why gateways for ESP8266?
    Each ESP8266 node can communicate with controller without gateway.
    My ESP8266 nodes sends data to Domoticz like this:
    SendToHTTP xxx.xxx.xxx.xxx,8080,/json.htm?type=command&param=switchlight&idx=26&switchcmd=On
    And from Domoticz to ESP8266 for example:
    http://xxx.xxx.xxx.zzz/control?cmd=event,modeSet=10
    No gateways, gateway timeouts etc.
      as a metter of fact you could also use MQTT, but without any clarification from @AffordableTech it is hard to say
      AffordableTechA 1 Reply Last reply
        AffordableTechA
        AffordableTechA
        AffordableTech
        Hi @gohan and others,
        Thanks for your comments, here is further clarification on my particular config / needs...
        Firstly, I appreciate the reminder about the new BlueTooth modules, I'd forgotten about them to be honest. However, at the current price of AUD$69 per node vs AUD$6 for an ESP, the ESP wins, unless its battery powered and the task requires so much on-air time that a battery powered ESP device is impractical, then the $69 price could be justified. In time I;m sure the price will come down, but I think BlueTooth will always be more expensive that WiFi.
        I wrote my own 'controller' (an extension of my older custom security system) and decided to go with MySensors because its data strings / protocol are very flexible and efficient, and saw no sense having the nodes and the controller convert an efficient protocol to and from MQTT for transmission, so the controller parses and generates MySensors formatted data.
        In the beginning, I had a dozen nodes transmitting via RF to an Ethernet gateway, but after the ESP devices came onto the market, I've been wanting to use them, but if you have to add a radio to each one, I may as well use and Arduino. The problem being, MySensors 'sensor nodes' can only communicate via RS232 or RF in its 'native' data format. To communicate over Ethernet, the data must be in MQTT packets, then you have to setup an MQTT server somewhere etc, and data has to be converted back and forth between the 'native' format and MQTT. Add to that, the MQTT 'bits' are another source of potential problems, degrading the reliability of the MySensors network, which is otherwise very reliable. If I'm going to add another piece of hardware/software to the process, it should offer some benefits, rather than just being a 'necessary evil', which is how I see MQTT when applied to a MySensors network. This has been a critical shortcoming of MySensors for a while now...
        A Very Typical Example:
        *I want a MySensors node in my car that automatically arms and disarms my security system (and switches lights etc) when I leave and return. I tried to do it, but RF24 and BlueTooth were unreliable due to the distance and metal in the car, whereas, I have great WiFi access where its parked.
        To achieve my goal, I'll need a battery powered, weatherproof repeater node outside, or at best, an ESP in the car, with a matching 'ESP with RF24', in the house and write custom code for them to communicate with each other, then the inside ESP will transmit a message to the MySensors network. Like so many other things, its 'possible', but a painless and totally unnecessary 'kludge'. Why shouldn't I be able to simply flash an ESP NodeMCU with code for a 'switch node' and stick it in my car - job done - it then talks direct to my MySensors gateway? Yes, I know, an MQTT node, plus a Raspberry Pi, plus Mosquito, blah blah... This isn't the eighty's, that's the sort of thing I had to do back then.*
        Gateways use an Ethernet transport, so the code is all there, but its setup as a 'gateway transport' and not a 'node transport'. It seems such a waste for nodes to communicate on any transport other than RF, the really good MySensors protocol / packet structure has to be translated into a much less efficient protocol, and back again. Why shouldn't nodes be able to at least talk to the gateway over Ethernet? And, when you consider part of the brilliant design of MySensors is that each node can act as a forwarder, an 'Ethernet node transport' would allow inter node traffic, greatly improving the range.
        Suddenly, a small groups of nodes in one location could interact with nodes in another location anywhere (over a secure TCP/IP link). My home controller could then receive notifications from sensors at the office monitoring vital equipment. Likewise, when I 'arm' my home system by clicking the 'Off To The Office' button on my controller, the office MySensors network would turn on power to the coffee machine, so my hot morning cuppa is ready when I get there. Yes this 'is possible' now, but it's not 'native' to MySensors and requires custom work-arounds, often different for each person, depending on their particular setup.
        The whole purpose of MySensors / Home Automation is to make life easier, my home system is pretty helpful now, thanks to the very reliable MySensors project. For example, I tap a 'Bath' button on my controller (or phone) and the bathroom towel warmer is turned on, and depending on the current temp, the room heater may be turned on as well, and finally, the water heater thermostat is given a 10 min nudge to bring the water to 'piping hot', rather than normal 'hot' for routine hand washing etc. (that little water heater 'smart' saves me enough each year on my power bill, to pay for all my home automation equipment costs).
        Reading through the forum from the beginning, I've see many users stumble over why they have have to add an MQTT client, then setup something called a pie with mosquitoes? Likewise, users keep asking why they have to add a radio to an ESP, when the ESP and the gateway both already 'talk' Ethernet? It's just such an obvious 'hole' in the MySensors transport.
        I feel the lack of Ethernet on nodes is truly crippling MySensors, adding an Ethernet 'node transport' would open up so many possibilities, that currently require each individual to kludge together their own solution, you just select MY_RADIO_WIFI and presto! Those that don't like exposing their HA to WiFi, simply don't have to, but I'm willing to bet it would become very popular if enabled, particular with newcomers.
        My apologies for the length of this post, but I feel strongly about this and hope I've explained why.
        Regards,
        Paul
          Mqtt is pretty much an industry lightweight standard and it is easier to setup the nodes (only need broker address and topic) instead if you want to use a custom ip protocol you need to create the whole stack for communication. If want to turn on and off the security system automatically, you can always look at the problem from a different perspective, like using smartphone and like Domoticz apps where you can create rules based on GPS positioning; you can also use a smartband that if it is detected inside the house the security goes off. There are many ways to approach a problem
            AffordableTechA
            AffordableTechA
            AffordableTech
            wrote on last edited by AffordableTech
            Hi @gohan,
            I agree with you, there are many solutions to my 'node in the car' example, I can come up with all sorts of ways around the problem, but none will ever be as good as having a fully integrated node. My point is that users shouldn't have to resort to implementing work-arounds. If we were talking about some obscure requirement, I could understand, but the lack of native Ethernet access by nodes is something that has come up from users in the forum many times.
            I've used MySensors as a teaching aide and several times I've had to try and explain to a new user who sees his gateway is connected to ethernet, and naturally expects his wifi node to talk to it, and just can't understand (believe) he has to setup a complete MQTT server. Several of those have abandoned MySensors and taken up alternate solutions which I know are inferior, but 'appear' better to newbies during the initial learning curve.
            What I'm trying to establish by my post is a straight answer to the likelihood of an Ethernet 'node transport' being implemented in MySensors. Adding MQTT to my controller is no big deal, but I would prefer to see MySensors enhanced because I firmly believe it is the most flexible and reliable HA protocol. Based on what I see, there appears to be no interest in implementing it within the main core of MySensors developers, but rather than assume, I'd prefer to ask.
            I chose not to use MQTT from the beginning, having decades experience with it and seeing the problems caused by its bandwidth inefficiency. The last thing I want to do, at a time when data is growing exponentially, is bog my network down with MQTT on all my new nodes.
            isRegards,
            Paul
              There are already other working solutions for esp8266 nodes that can integrate with controllers; mysensors is covering other transports methods (NRF24, RFM69, RFM95, RS485).
              • AffordableTechA AffordableTech
                Hi @gohan,
                isRegards,
                Paul
                @affordabletech said in Would You Like Support For ESP8266 'Nodes'?:
                I don't want to hijack your thread, but are we talking about the same MQTT here? (https://en.m.wikipedia.org/wiki/MQTT)
                MQTT is an ISO standard, that specifically targets small bandwidth applications.
                I have yet to see another IoT 'standard' that is as flexible as MQTT...
                • K kimot
                  Sorry, I do not understood what you want.
                  Want you your ESP2866 node communicate with your ESP8266wifi to ethernet gateway and ethernet gateway with controller?
                  I think, better is, when each node with ESP8266 send messages directly to controller and controller to this node ( on its IP ).
                  It is easier and with more comfort than using Mysensors with gateways etc.
                  AffordableTechA
                  AffordableTechA
                  AffordableTech
                  @kimot said in Would You Like Support For ESP8266 'Nodes'?:
                  Yes, I've had to do that for a couple of ESP8266 nodes I added recently, but the problem with that work-around is that those nodes are not really part of the network. They are 'isolated' because they bypass the gateway and cannot talk / interact with other nodes, so you no longer have an 'integrated home automation network' and it can quickly become a 'disjointed collection of random nodes'.
                  A lot of thought was put into the design of my system so that many of my nodes communicate direct with each other; if nodes have to depend on the controller to do their job, the system doesn't work if the controller is temporarily off-line. For example, every minute, my power monitoring node transmits total kWHr usage direct to the node in my large display panel, which displays my total power bill $'s so far this month. Most of my room lights are PIR controlled, so my outside store-room node has a PIR sensor and light relay (with manual switch also), but the PIR 'node' is smart enough to trigger a warning inside, if the PIR detects movement when my 'network' knows I'm in the house - my 'nodes' are smart enough to know which room I was last detected in, and I can't be in two places at the same time, nor can I be magically transported (yet) from one room to a non-adjacent room. So if I'm in the bathroom, and the front door opens or movement is detected in 'non adjacent' room, something is really wrong and a message 'beep twice' is sent direct to my internal siren node to alert me (unless I've told the network I have guests of cause). It's the little 'smarts' in each node that make my home automation system so personal and beneficial, that's why I am dead against 'isolated' dumb nodes. Having a PIR node send a message to the controller, then the controller send a message to the light 'relay' is dumb, the PIR node needs to talk direct to its associated relay node, which also receives regular updates, 'direct' from my outside LUX light sensor, so the 'relay node' is smart enough to know if it is appropriate to turn the light on or not.
                  Some people may say the controller should do this, and yes, my controller has various rules, but I prefer to add 'some' basic intelligence to the nodes so they are not dependant on the controller, simply because all my nodes are powered by a central solar charged 12V battery store, or have their own battery. However, my controller is a Windows machine because I wanted a reasonably powerful controller for data logging, statistical data, and graphs etc, so its powered from the mains. My automation/security system can function 'as normal' for over 24 hours without the controller or mains power. Each node is capable of doing its job and buffering its data while the controller is off-line, e.g. a 240V (or 12V) light will still come on when I walk into a room etc. This means I don't have to worry about my controller being off-line for maintenance, or a blackout etc, no loss of functionality or data.
                  Hopefully, you will see why I don't like 'isolated' nodes or 'work-arounds' that cannot be fully integrated, as the whole purpose of home automation is to integrate devices in the home.
                  Regards,
                  Paul
                  K 1 Reply Last reply
                    I see your point, but if you want to keep things small and simple I guess the best solution is to use the NRF5x chips as they can talk over the NRF24 network and thus having all the benefits of the mysensors network.
                      AffordableTechA
                      AffordableTechA
                      AffordableTech
                      Hi @gohan ,
                      Yes, I really like the 5x Bluetooth devices, particularly the beacon aspects, but until the prices drop a fair bit, they will be out of my 'affordable' range for general nodes.
                      Paul
                      • AffordableTechA
                        AffordableTechA
                        AffordableTech
                        @yveaux said in Would You Like Support For ESP8266 'Nodes'?:
                        Nagh, I appreciate all opinions, that what I'm here for.
                        I agree about the MQTT flexibility, and normally I would be the 1st one to insist on going with an established standard, but MQTT flexibility comes at the expense of bandwidth efficiency. As you pointed out, its for low volume messaging, and when I did some projected bandwidth calculations three years ago, and the numbers scared me off MQTT. Besides that, I think the underlying architecture of MySensors protocol is simply brilliant, its the perfect balance between flexibility and efficiency. As far as I know its been able to handle every requirement that has been asked of it over the years, and while it's been expanded. the basic protocol remains the same.
                        My power monitoring node currently transmits four channels of two floats (Current Watts and Cumulitive kWHr units) every ten seconds, and I'm about to increase that to eight channels. Add to that reasonably frequent security system status reports from eleven zone sensors, and about eight temperature/humidity/light type sensors and the traffic volume is already getting pretty high. During the night, for health reasons, I want to monitor my pulse, blood pressure and oxygen levels for real time data collection, which I would like to pass through the MySensors network simply because its all automatically logged, the data is automatically backed up etc, otherwise I'd have to duplicate those facilities for the medical data, so it makes sense to me.
                        While I'm unable to look at the actual RF data, just looking at the serial debug data, I can see there are already missing readings (collisions?)from my power monitor. If I increase it to eight power channels, I believe the RF network will be oversaturated. So I can't even think about the medical data, but an ethernet transport option would solve the current needs and cater for some future growth.
                        I've been told "the focus of MySensors is on RF and RS-485 communications", whereas I always thought MySensors was about an 'open and practical Home Automation', rather than one particular technology. Over the years I've detected an anti-ethernet / anti ESP sentiment in the forum for some reason. The whole reason I brought up this subject was after reading yet another post where a newbie wanting to use the ESP8266 without an RF device was simply told to go elsewhere. If that's the official view, then I'm concerned for the future of MySensors as I believe the current RF technology isn't able to meet the current user's expectations, much the future needs as the 'connected home' becomes a reality (for more than the technical oriented). All my friends are asking me about home automation, and I think when the latest generation of smart appliances hit the market, home automation will take off.
                        So, 'having been told', my choice now is do I create my own quick and dirty ethernet node transport, which will mean I will no longer be running a standard MySensors release and 'my version' will most probably fall behind, or do I go back to square one and look for a product / protocol that will cater for the future? It's going to be a difficult choice, and although I think ethernet will 'have to be incorporated' eventually, my needs for more bandwidth mean I have to find a solution now rather that in a year or two.
                        Regards,
                        Paul
                        YveauxY scalzS 2 Replies Last reply
                          If you have collisions or nacks on your nodes, you can still manage retries in code for the most important sensors.
                            Regards,
                            Paul
                            Sorry if you got that impression. I personally did the MySensors esp8266 port long time ago. Initially as a cheap and simple wifi gateway. Cabled ethernet gateways have been supported from the start. Over the years there has been very little interest in ethernet sensor nodes on the MySensors forum.
                            Recently the option of local sensors for gateways was added, turning an esp8266 into a sensor gateway. Not exactly what you are looking for, but close IMHO.
                            Then the question of ethernet sensor nodes. Within the MySensors software framework there currently is no ethernet transport layer. This is certainly doable, but the core team lacks resources to implement it. We are more than willing to include it in the stack if someone adds decent support for it and offers to maintain it.
                            • AffordableTechA
                              AffordableTechA
                              AffordableTech
                              @gohan
                              I watched man go to the moon when we hardly had calculators, so I know very well "anything is possible", but what's 'practical' is a very different matter. My objectives are 'results' based and not tied to any particular brand or technology. If my current traffic is causing problems, I have no interest in patching it up or work-around (as I think is obvious). If I'm putting more data into the transport that it can handle, I see only two 'proper' solutions, less data or a bigger pipe. Anything else would be short-sighted in my opinion, I subscribe to the 'do it once, do it right school' of thought, but I understand everybody tackles problems their own way.
                              My confusion was over the future direction of MySensors and I believe that's been answered very clearly. I misunderstood the focus of MySensors to be for open and effective home automation, and that's why I couldn't understand why people keen on the ESP8266 were told to go somewhere else, but now that you have told me the focus is primarily on RF and RS485, I understand and realise my mistake.
                              While I feel focusing primarily on one particular transport may prove detrimental for the future of MySensors, that's simply my opinion based my inability to appreciate the value of specialising on RF24/69 etc, worth no more or less than any other opinion.
                              So please understand, I'm not having a go at you, I was confused by the anti ESP8266 sentiment, but that was when I didn't realise I was in an 'RF24 Shop' so to speak. If I was selling RF24 and you came in promoting ESP, I would have told you to go elsewhere, so it was my misunderstanding.
                              Thanks for taking the time to respond and clarify,
                              Paul
                                Since it is a community driven project, I see it as it has evolved according to the most common needs. I don't think there is any anti ESP8266 sentiment, it is just there hasn't been a strong interest for it for the purpose of the project.
                                Of course, as @Yveaux said, if there are people willing to help extend the project functionalities they will be more than welcome
                                  Regards,
                                  Paul
                                  which post was it ??
                                  when you say people use espeasy because esp nodes not available in mysensors (in your other post), I have another theory for this. and I read it on many forum. Lot of people, maybe not all sure, but a lot, use espeasy because it's easy to use, with some basic feature, for non programmer.
                                  I agree, and think Yveaux answer was a good one.. there is no anti, just time missing with lot of enthousiasm as always.
                                  So what makes you reply this ??
                                  I can understand it's frustrating that there is actually no clear solution to your problem. But like it has been already said:
                                  • gateway as node (i know it's not sexy)
                                  • espeasy, tasmota, custom mqtt code etc..
                                    and when there will be support in future (who knows), migrate or not..
                                  • or like Yveaux said, feel free to help. because so far it's not in top priority I think. as it's "convenient" for the moment to use mqtt.
                                  Last little note. You can find nrf5x node for a lot cheaper than 65$! Take a look at in the forum for aliexpress links. and you can use ESB proprietary mode (nrf24 compatible).
                                  I know you want to use your esp chips, I'm kidding :)
                                  i'm just sayin, it's "equivalent" in price. Nope I'm not anti. I use esp82xx, and esp32. nrf52, rfm69 etc..
                                  one sure thing, is i wouldn't like wifi nodes everywhere, critical nodes on wifi etc..
                                  I hope people investing in this have a dedicated network for their ha.. without nonsecured cheap camera!
                                  • AffordableTechA
                                    AffordableTechA
                                    AffordableTech
                                    @gohan
                                    I understand limited resources all too well, I guess because ESP nodes was something I started chasing a couple years ago when the chip first became available, other forum users requesting the same stood out to me and the story was always the same use MQTT and more recently go try something else (which I read as 'Go Away!!'). A few months ago I attended a meeting at computer club in a different state and the topic of discussion was 'how can we make MySensors nodes without adding a radio'. However, looking back now, I realise I never made 'feature request' simply because I perceived a lack of interest when I saw others being told no.. no.. no.., I now wonder how many others gave up without asking formally? Of cause I don't know what makes 'enough interest' and I agree, there has to be sufficient demand.
                                    As mentioned in another post, I seriously looked into the code with the view of writing it myself, but I could see the time needed to understand the 'internal layout and concepts' sufficiently, to implement a new transport without breaking any existing code, would be far greater than the time to write the actual routines required, and just too much for me to take on. I'm really passionate about MySensors and that's why it bothers me to hear others frustrated with it and realising I may have to start over with a different solution or (more likely) start from scratch and 'grow' my own node software to get what I need.
                                    This afternoon I came up with an idea how I might be able to achieve what I want, without having to modify the core code. I'll be looking further into that tomorrow and will get back to you if I still think my idea is possible.
                                    Regards,
                                    Paul
                                    gohanG 1 Reply Last reply
                                      @gohan
                                      Regards,
                                      Paul
                                      If somebody is needing a functionality like you said of course it will get a response to look at something else since mysensors is lacking it and there are other working alternatives available right now. If you want to develop that functionality now it is going to take a long time and most of the people can't wait 1 or 2 years for it to become available. It is good to open a topic and have an open discussion and see if someone else is interested.
                                        Regards,
                                        Paul
                                        K
                                        K
                                        kimot
                                        @affordabletech
                                        And now have you got network, where RF nodes can directly communicate with RS485 nodes without controller?
                                        I think no.
                                        • AffordableTechA
                                          AffordableTechA
                                          AffordableTech
                                          @scalz said in Would You Like Support For ESP8266 'Nodes'?:
                                          The post just before mine: https://forum.mysensors.org/topic/6935/esp8266-as-mysensors-nodes-instead-of-arduino-nrf24l01/4
                                          That's news to me, no idea where I stated that? I can only recall mentioning EspEasy when I stated a MySensors user wanting ESP nodes was told to try EspEasy (read it for yourself in the link above). Somewhere I did say the difficulty of having to use the MQTT workaround and having to setup a computer with Mosquito was causing people to abandon MySensors, which I know to be a fact and can substantiate. Personally, I can't see any reason why someone would use EspEasy, and I'd certainly discourage anyone considering it.
                                          Regarding the AliExpress suggestion, I appreciate the tip. Not understanding the differences between the various 5x, I'm reluctant to buy something without knowing it's suitable for MySensors. The only device that I've seen that I could confirm would run MySensors core was the RedBear board and another $69 module on eBay. If you have a specific AliExpress chip number or module reference, I'd appreciate that.
                                          Cheers,
                                          Paul
