  3. [security] Migrating from library version 2.1 to 2.2
48 Posts 7 Posters 15.7k Views 9 Watching
  • alowhumA alowhum
    Hey @Anticimex, thanks for the reply.
    The simple version is really great, don't get me wrong. Absolutely great usability!
    The reason I would like a non-signing option is that it saves a lot of ram. By only using encryption it should be possible to continue using Arduino Nano's as nodes.
    I tried using the MY_SIGNING_SIMPLE_PASSWD option on my Nano's, and the result was that most of my sketches became too big or unstable.
    There just isn't enough space/ram for both hardcore security and sensor libraries.
    Thanks for explaining that I might be able to 'criple' the MY_SIGNING_SIMPLE_PASSWD option. I would suggest that this 'crippling' could perhaps become a feature in itself called "MY_ENCRYPTION_SIMPLE_PASSWD (without the signing).
    sineverba
    @alowhum
    I did have same issues, with new version, when was in testing stage.
    Try at the top of sketch add these:
    #define MY_DISABLE_SIGNAL_REPORT
    You save a lot of space. All my nodes are on ATMEGA328 and no space issues. Max node with signing + encryption + relay + temp uses 67% of space
    • S sineverba
      @alowhum
      AnticimexA
      AnticimexA
      Anticimex
      @sineverba there is also a documentation section on this: https://www.mysensors.org/apidocs/group__memorysavings.html
      • S sineverba
        @alowhum
        AnticimexA
        AnticimexA
        Anticimex
        @sineverba I also believe the signal report flag is reversed nowadays, and is an opt-in feature and not an opt-out feature, using MY_SIGNAL_REPORT_ENABLED which defaults to "off". Hence it is not listed in the memory savings section of the documentation, but the documentation of MY_SIGNAL_REPORT_ENABLED does warn that it adds about 1k of flash use.
        S 1 Reply Last reply
        • AnticimexA Anticimex
          sineverba
          @anticimex Ah, I did not know, cause I'm in 2.2.0 rc2 (when something works... don't touch it! :D )
          • alowhumA alowhum
            I can't ask for much more than that. Thanks man!
            AnticimexA
            AnticimexA
            Anticimex
            @alowhum check the development branch. Simple password system has been reworked. Also, documentation is updated.
            alowhumA 1 Reply Last reply
              alowhumA
              alowhumA
              alowhum
              @anticimex Awesome!
              So I had a look at the new code, and is this a fair summary?:
              • Simple encryption and simple signing are now two separate functions you can call at the top of your script by adding a line with a password: MY_ENCRYPTION_SIMPLE_PASSWD and MY_SIGNING_SIMPLE_PASSWD.
              • You can also just put "MY_SECURITY_SIMPLE_PASSWD" at the top of your script, and that will do both in one go. This used to be called the MY_SIGNING_SIMPLE_PASSWD option, which also did both.
              MY_SIGNING_SIMPLE_PASSWD is now
              called MY_SECURITY_SIMPLE_PASSWD.
              MY_SIGNING_SIMPLE_PASSWD only affects signing,
              and a new flag, MY_ENCRYPTION_SIMPLE_PASSWD
              only affects encryption.
              MY_SECURITY_SIMPLE_PASSWD enable both these flags.
              This is simply wonderful.
              • More choice and flexibility for the end user.
              • Get some simple security on your existing Arduino hardware.
              Thank you so much for this.
              AnticimexA D 2 Replies Last reply
              • alowhumA alowhum
                @anticimex Awesome!
                AnticimexA
                AnticimexA
                Anticimex
                @alowhum you are welcome. Just remember that simple in this context also mean weak. Storing the secrets in the sketch is a huge security implication on targets that does not support readout protection. Atmga328p among others.
                  alowhumA
                  alowhumA
                  alowhum
                  @anticimex I understand. But if my neighbour has access to the nodes inside my house, then I have a bigger security problem :-)
                  AnticimexA 1 Reply Last reply
                  • alowhumA alowhum
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @alowhum right, but if you update your sketches OTA, he can potentially sniff your key OTA as well and then he does not need to enter your house ;)
                    alowhumA alexsh1A 2 Replies Last reply
                      alowhumA
                      alowhumA
                      alowhum
                      @anticimex Heh, then I will invite him/her over for tea congratulate them. And then apply some verbal security :-P
                      Can Arduino nano's be updated OTA?
                      • alowhumA alowhum
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @alowhum afaik all MySensors capable nodes can be updated OTA with the appropriate bootloader programmed.
                          alowhumA
                          alowhumA
                          alowhum
                          @anticimex Wow, I didn't know that! I've gotta look into that! cool!
                          • alowhumA alowhum
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @alowhum in general where are two options, DualOptiboot which require an external spi flash but is radio agnostic, or the mysbooloader which have no requirements on external components but might need to be recompiled to match your radio settings.
                            gohanG 1 Reply Last reply
                              @anticimex I haven't found dual optiboot for all mysensors boards, but maybe there is a way to make it work and I'm not expert on this
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @gohan hence my comment "in general", and in this sence I believe the board in question is "Can Arduino nano's be updated OTA?" and a nano is atmega328p based, and I believe it supports both bootloader variants. Of course there are some devices that might not support both, or perhaps even any of them, but as most of this discussion relates to resource limited nodes, I think only atmega328p based devices are considered.
                                • alowhumA alowhum
                                  @anticimex Awesome!
                                  DavidZH
                                  @alowhum said in [security] Migrating from library version 2.1 to 2.2:
                                  @anticimex Awesome!
                                  I want to follow upon this: I use RFM69 for transport, they have an encryption engine in hardware. Will there be any difference in time to process the message between using:
                                  • MY_SECURITY_SIMPLE_PASSWORD with soft encryption done on the ATmega or
                                  • MY_SIGNING_SIMPLE_PASSWORD and encryption on the RFM or
                                  • just MY_SIGNING_SIMPLE_PASSWORD.
                                  If I'm not mistaken a signed message is the full 32 byes anyway, so the actual "airtime" will not change, but maybe the processing time before that will.
                                  And yes, I am aware of the implications in total system security. But none of my nodes are accessible from the outside of my house. I am not worried about someone reading the contents of my sketch.
                                  • D DavidZH
                                    @anticimex Awesome!
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @davidzh If you enable any form of encryption feature, RFM69 will always use the hardware to implement it. So there is no "soft encryption" on RFM69.
                                    D 1 Reply Last reply
                                      DavidZH
                                      @anticimex
                                      Ok clear. Thank you.
                                      • B
                                        B
                                        bilbolodz
                                        I've a lot devices with very hard physical access to them. I'm using OTA to change firmware so please describe how to implement "new 2.2 checksum feature" into existing sketch using OTA.
                                        • B bilbolodz
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @bilbolodz Not sure what you mean. Then you have to send personalization sketch OTA and that is really not recommended unless you can do that in a secure way. And the personalizer is not designed to use any radios so you cannot expect to be able to FOTA over a new sketch after personalization. You will have to "bring in" your devices if you want to redo personalization.
