  3. Home Assistant
  4. MySensors ethernet 2.2.0 problem with control node switches
12 Posts 3 Posters 3.7k Views 3 Watching
  • pepsonP
    pepsonP
    pepson
    ok corrected
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      You need to feedback and send the changed state to home assistant, after writing the new state to the pin, in the receive function. Otherwise home assistant thinks that the message to change state did not reach the node, and returns to the old state.
      pepsonP 1 Reply Last reply
        pepsonP
        pepsonP
        pepson
        wrote on last edited by pepson
        @martinhjelmare
        Can you explaine me more. Sorry i am begginer user and i dont know how ? Please
        Or please correct it in my sketch...please
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          Add the following line in the receive function eg after the call to digitalWrite.
          send(msg.set(state));
          • pepsonP
            pepsonP
            pepson
            Hi
            Ok i add this and now sketch look like:
               Relay with button sketch
            #define MY_RADIO_RFM69
            #define MY_IS_RFM69HW
            #define RFM69_868MH
            #define MY_RFM69_NEW_DRIVER
            //#define MY_NODE_ID 203                       // Node id defaults to AUTO (tries to fetch id from controller)
            #define RELAY_ON 1
            #define RELAY_OFF 0
            Bounce debouncer = Bounce();
            int oldValue = 0;
            bool uplinkAvailable = true;
            bool state = false;
            bool requestState;
            bool firstStart = true;
            unsigned long oldTime = 0;
            unsigned long newTime = 0;
            void setup(){
              debouncer.interval(5);
            void presentation()  {
              sendSketchInfo("1xRelay & Button", "2.2.0");
              present(CHILD_ID, S_BINARY);
            void loop(){
                  uplinkCheckTime = millis();
                 else{
                  Serial.println(requestState);
              debouncer.update();
                requestTime();
                  oldTime = newTime;
              oldValue = value;
            void uplinkCheck() {
                requestTime();
                  oldTime = newTime;
              if (firstStart){
                oldTime = time;
                newTime = time;
              else{
              newTime = time;
              Serial.println(time);
            Now works ok but another problem. Ex When i enable relay and then reboot my RPI with Home Assistant and under reboot i manual change state relay by put pin to GND, then after run RPI with Home Assistant , it come back to previus state relay. Again set my relay as ENABLE.
            Is any chance to change it to after start HA he check state relay and setup in home assistant actual phisicaly state relay... not remembered before reboot ?
            And next problem... When node has relay ENABLE and power lost, then power come back relay again to ENABLE. But i want to RELAY always after power lost and power come back to relay go to DISABLE.
              Set the relay state in setup function?
                pepsonP
                pepsonP
                pepson
                @gohan
                Can you explaine me more because I am beginner and I don't know how?
                It is in "void setup" ?
                And what is command for setup state?
                  add
                  send(msg.set(RELAY_OFF), false);           // notify controller to show off state
                  at end of setup function and see if you get the result you want
                    add
                    pepsonP
                    pepsonP
                    pepson
                    @gohan
                    But it is for only show state off or also physical change state relay to off?
                    void setup(){
                    This is OK code?
                    • pepsonP
                      pepsonP
                      pepson
                      @gohan said in MySensors ethernet 2.2.0 problem with control node switches:
                      ok looks that is ok but please give me a time i test it more.
