  3. OpenHAB
  4. Beginner totally lost during installation of serial gateway
6 Posts 5 Posters 3.5k Views 5 Watching
  • J Offline
    J Offline
    Julian Kröhl
    Hello guys,
    I'm totally lost during the installation process and I really hope you can guide me the way.
    Honestly, I read several installation guides and several tutorials but none of them seem to work - maybe I'm doing something very "common" stuff wrong, because I'm not a Linux guy.
    I first followed the instructions to build 2 Arduinos with nRF radio chips.
    One will be my gateway, one will be my "sensor" guy.
    The gateway is attached via USB-cable directly to my Raspi, hosting Openhab2.
    The communication between Sensor-Arduino and Gateway seem to work, at least I get stable output from the Arduino-Com-Console.
    What I want to do now is to "introduce" my Gateway to openhab2 - and I'm completely lost now :(
    I tried the guide "https://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway", added the item to my sitemap and it states "-", so no data available.
    I tried to check the logs of openhab2 but they seem to be not updated for one month (even after several restarts) - my other items I control with Openhab2 are working (Z-Wave-Stick controlled).
    So the first step I fail at is
    "Start up openHAB with "/opt/openhab/start.sh". You should see something like:
    2015-04-02 20:05:30.731 [INFO ] [runtime.busevents ] - Arduino state updated to 0;0;3;0;14;Gateway startup complete."
    What do I have to do exactly after I connected the Arduino gateway via USB?
    BR,
    kreisch
    • J Julian Kröhl
      Hello guys,
      BR,
      kreisch
      T Offline
      T Offline
      TimO
      @julian-kröhl oh, you have found a really old thread. :smile:
      I suggest you to go with the binding or with the MQTT gateway.
      J 1 Reply Last reply
      • T TimO
        J Offline
        J Offline
        Julian Kröhl
        @timo
        Thanks, I will go on with the mqtt bridge but to be honest, the Entry for a beginner is huge - and I am from it sector, so no complete noob, only regarding to Linux ;)
        alexsh1A 1 Reply Last reply
        • J Julian Kröhl
          @timo
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @julian-kröhl Firstly, are you familiar with OpenHab? If not, I'd suggest you pick a different controller, like Domoticz. OpenHab is much more advanced and more difficult to set-up for a beginner. Secondly, you have to do it step by step:
          1. Setup a controller
          2. Connect the GW to the controller and make sure the controller is recognising it. - this is the step you have to concentrate right now.
          3. Only now start your sensor and make sure the sensor is talking to the GW.
          • JPLJ Offline
            JPLJ Offline
            JPL
            wrote on last edited by JPL
            Follow this one and aks questions back: https://forum.mysensors.org/topic/6694/openhab-2-2-mysensors-serial-gateway-how-to-install.
            This is the one I have used and more or less it works. I have intermitent disconnections, but I am not fully sure if it is due to a bad radio link...
            After following the full tutorial of the link above, I noticed I was not being able to connect. I would suggest you skip the part about downloading MySensors.git. This will install an alternative driver that I found not needed.
            It is important to give OpenHab access permissions to the binding:
            cd /usr/share/openhab2/addons/
            sudo wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.2.0-SNAPSHOT.jar
            sudo chown openhab:openhab org.openhab.binding.mysensors-2.2.0-SNAPSHOT.jar
            And to the USB connection:
            sudo usermod -a -G dialout openhab
            sudo usermod -a -G tty openhab
            In my configuration, I have a thing named "gw1" (this name you can change to whatever you like) defined for the gateway:
            Bridge mysensors:bridge-ser:gw1 [ serialPort="/dev/ttyUSB0", sendDelay=200, startupCheckEnabled=false, networkSanCheckEnabled=false ] {
              // define things connected to that bridge here
            As you can see, I am using directly ttyUSB0 to communicate to the serial gateway. You can check the right port by using the Arduino IDE in the Raspberry Pi and the serial monitor.
            • F Offline
              F Offline
              FlipFlap3
              No need to have a 2nd arduino connected through usb. Just attach a nrf chip directly to your pi
