  3. MyController.org
  4. [Solved] FOTA Not Working
Scheduled Pinned Locked Moved MyController.org
21 Posts 4 Posters 5.5k Views 4 Watching
  • SoloamS
    SoloamS
    Soloam
    Can It be my version of the Arduino AVR Boards? I have 1.6.21, and the same occurs on 1.6.20.
    Thank You
    • SoloamS
      SoloamS
      Soloam
      Ok, at this point I can't access by FTDI to the 8Mhz, all the other frequencies ar working... I only tested the FOTA with the 8Mhz, so I'll teste it again today with the 1Mhz and post back the results.
      • SoloamS
        SoloamS
        Soloam
        I can confirm that FOTA is working on all frequency, except 8Mhz... I can't get it working on FOTA or FTDI on the 8Mhz version of MYSBootloader!
        Can any one help me with this?
        Thank you
        tekkaT 1 Reply Last reply
        • SoloamS Soloam
          Thank you
          tekkaT
          tekkaT
          tekka
          @soloam I assume 115200 baud@8Mhz could be an issue, decreasing it to 57600 may help (i.e. in mysbootloader & boards.txt settings)
          • SoloamS
            SoloamS
            Soloam
            @tekka said in FOTA Not Working:
            57600
            hello @tekka I tested out with:
            57600
            38400
            19200
            9600
            4800
            2400
            None worked, strange that is working on the 16Mhz and 1Mhz, and only the 8Mhz is giving problems... exactly the one that I wanted to use... lol
            Thank You
            gohanG tekkaT 2 Replies Last reply
            • SoloamS Soloam
              57600
              57600
              38400
              19200
              9600
              4800
              2400
              Thank You
              @soloam said in FOTA Not Working:
              Murphy's law :sweat_smile:
              • SoloamS Soloam
                57600
                57600
                38400
                19200
                9600
                4800
                2400
                Thank You
                tekkaT
                tekkaT
                tekka
                @soloam When you tested the different baud settings, did you also change it in mysbootloader and recompiled it?
                • SoloamS
                  SoloamS
                  Soloam
                  Do you mean over here @tekka?
                  /* set the UART baud rate defaults */
                  #ifndef BAUD_RATE
                  	#if F_CPU >= 8000000L
                  		#define BAUD_RATE   115200L
                  	#elif F_CPU >= 1000000L
                  		#define BAUD_RATE   9600L   // 19200 also supported, but with significant error
                  	#elif F_CPU >= 128000L
                  		#define BAUD_RATE   4800L   // Good for 128kHz internal RC
                  		#define BAUD_RATE 1200L     // Good even at 32768Hz
                  No, I will try it... Can I do it in "Atom"? any special settings?
                  Thank You
                  • SoloamS Soloam
                    #ifndef BAUD_RATE
                    Thank You
                    tekkaT
                    tekkaT
                    tekka
                    @soloam Yes, that's the correct location (if BAUD_RATE is not set via compiler settings).
                    Sorry, but I have no experience with Atom.
                    • SoloamS
                      SoloamS
                      Soloam
                      @tekka it worked :) Thank you for your assist, it was my first time doing this... so... :)
                      I made the change to HW.h to
                      #ifndef BAUD_RATE
                      	#if F_CPU >= 16000000L
                      	#elif F_CPU >= 8000000L
                      		#define BAUD_RATE   57600L
                      Compilled the new bootloader, and replaced it on the Arduino IDE folder... Flashed the new 8Mhz Bootloader to my node and now FTDI works... When I get home I'll test out FOTA and post back the results.
                      Will you change the GitHub Repo to take into account this change? Or is this a local problem only to me? Do you want me to submit change the code and hex file and submit a change request?
                      Thank You
                      • SoloamS Soloam
                        #ifndef BAUD_RATE
                        Thank You
                        tekkaT
                        tekkaT
                        tekka
                        @soloam well done! Yes, please go ahead and submit a PR with the necessary changes. I will review it later this week.
                        SoloamS 1 Reply Last reply
                        • tekkaT tekka
                          SoloamS
                          SoloamS
                          Soloam
                          @tekka FOTA and FTDI now working on 8Mhz Bootloader... PR submited!
                          Thank you for your help
                          • SoloamS
                            SoloamS
                            Soloam
                            Just to end and close the topic, @tekka great work on the Bootloader and @jkandasa great work on MyController... Thank you
