  3. MyController.org
  4. [Solved] FOTA Not Working
Scheduled Pinned Locked Moved MyController.org
21 Posts 4 Posters 5.6k Views 4 Watching
  • SoloamS
    SoloamS
    Soloam
    @tekka , I think I'm getting to the root (or not) of what might be the problem... I stated that I was not able to upload sketches by FTDI, but now I can see that on some ATMEGA I can, and others I can't... I flashed the bootloader to all in series, all in the same way (some where fresh installs, other not, but I can't track witch ones are what). Some ATMEGA I can upload the sketch by FTDI (when I get home I will try the FOTA, and I hope that on the ones that I can upload by FTDI that the FOTA will work), but on others I can't and I get:
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
    This seems the error that I get when I try to upload a sketch in the wrong frequency, but I double checked and all the ATMEGAS have the same fuses (the ones in the image above) and all where flashed in the same way.
    Thank You
    • SoloamS
      SoloamS
      Soloam
      wrote on last edited by Soloam
      I tried to flash the several Bootloader into one of the ATMEGA that was not working, the results are strange:
      FTDI Access:
      • Arduino UNO Bootloader: OK
      • ATMEGA on a Breadboard (8Mhz Internal Clock) OK
      • MysBootloader 16Mhz OK
      • MysBootloader 8Mhz NOK
      • MysBootloader 1Mhz OK
      I would assume that the problem was something on the config, but that would not explain way it works on some ATMEGA, and on others not... Can it be defective units (ATMEGA)? Only not working the 8Mhz??
      My boards.txt from github Dev brantch... I only had to change 3 lines to make it work... in Linux at lest we need this on the sketch folder (MYSBL.upload.tool=arduino:avrdude, MYSBL.bootloader.tool=arduino:avrdude, MYSBL.build.core=arduino:arduino, MYSBL.build.variant=arduino:standard)
      ## Add these lines to your boards.txt file in the Arduino installation directory
      ## Arduino Pro or Pro Mini (3V3 & 5V, 1 - 16 MHz) w/ ATmega328 MYSBootloader
      menu.frequency=Frequency
      MYSBL.name=ATmega328 with MYSBootloader 1.3.0
      MYSBL.upload.protocol=arduino
      MYSBL.upload.maximum_size=30720
      MYSBL.upload.maximum_data_size=2048
      MYSBL.build.mcu=atmega328p
      MYSBL.build.board=AVR_UNO
      MYSBL.menu.frequency.MYSBL16=16MHz XTAL
      MYSBL.menu.frequency.MYSBL16.build.f_cpu=16000000L
      MYSBL.menu.frequency.MYSBL16.upload.speed=115200
      MYSBL.menu.frequency.MYSBL16.bootloader.low_fuses=0xFF
      MYSBL.menu.frequency.MYSBL16.bootloader.high_fuses=0xD2
      MYSBL.menu.frequency.MYSBL16.bootloader.extended_fuses=0x06
      MYSBL.menu.frequency.MYSBL16.bootloader.unlock_bits=0x3F
      MYSBL.menu.frequency.MYSBL16.bootloader.lock_bits=0x0F
      MYSBL.menu.frequency.MYSBL16.bootloader.file=MySensors/MYSBootloader_16MHz.hex
      MYSBL.menu.frequency.MYSBL8=8MHz RC
      MYSBL.menu.frequency.MYSBL8.build.f_cpu=8000000L
      MYSBL.menu.frequency.MYSBL8.upload.speed=115200
      MYSBL.menu.frequency.MYSBL8.bootloader.low_fuses=0xE2
      MYSBL.menu.frequency.MYSBL8.bootloader.high_fuses=0xD2
      MYSBL.menu.frequency.MYSBL8.bootloader.extended_fuses=0x06
      MYSBL.menu.frequency.MYSBL8.bootloader.unlock_bits=0x3F
      MYSBL.menu.frequency.MYSBL8.bootloader.lock_bits=0x0F
      MYSBL.menu.frequency.MYSBL8.bootloader.file=MySensors/MYSBootloader_8MHz.hex
      MYSBL.menu.frequency.MYSBL1=1MHz RC
      MYSBL.menu.frequency.MYSBL1.build.f_cpu=1000000L
      MYSBL.menu.frequency.MYSBL1.upload.speed=9600
      MYSBL.menu.frequency.MYSBL1.bootloader.low_fuses=0x62
      MYSBL.menu.frequency.MYSBL1.bootloader.high_fuses=0xD2
      MYSBL.menu.frequency.MYSBL1.bootloader.extended_fuses=0x06
      MYSBL.menu.frequency.MYSBL1.bootloader.unlock_bits=0x3F
      MYSBL.menu.frequency.MYSBL1.bootloader.lock_bits=0x0F
      MYSBL.menu.frequency.MYSBL1.bootloader.file=MySensors/MYSBootloader_1MHz.hex
      • SoloamS
        SoloamS
        Soloam
        The complete Log on trying to load the sketch with the FTDI to the ATMEGA! I don't know if not working with the FTDI has anyting related with not being able to flash with the MyController, but it's strange... Just giving all info as possible to try to get some help on the problem.
        Arduino: 1.8.5 (Linux), Board: "ATmega328 with MYSBootloader 1.3.0, 8MHz RC"
        Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
        Sketch uses 13290 bytes (43%) of program storage space. Maximum is 30720 bytes.
        Global variables use 714 bytes (34%) of dynamic memory, leaving 1334 bytes for local variables. Maximum is 2048 bytes.
        /opt/arduino-1.8.5/hardware/tools/avr/bin/avrdude -C/opt/arduino-1.8.5/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/arduino_build_550364/LightActuator.ino.hex:i
        avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
                 System wide configuration file is "/opt/arduino-1.8.5/hardware/tools/avr/etc/avrdude.conf"
                 User configuration file is "/home/diogo/.avrduderc"
                 Using Port                    : /dev/ttyUSB0
                 Overriding Baud Rate          : 115200
        avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
        avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
        avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
        avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
        avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
        avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
        avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
        avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
        avrdude done.  Thank you.
        Thank You
        • SoloamS
          SoloamS
          Soloam
          Can It be my version of the Arduino AVR Boards? I have 1.6.21, and the same occurs on 1.6.20.
          Thank You
          • SoloamS
            SoloamS
            Soloam
            Ok, at this point I can't access by FTDI to the 8Mhz, all the other frequencies ar working... I only tested the FOTA with the 8Mhz, so I'll teste it again today with the 1Mhz and post back the results.
            • SoloamS
              SoloamS
              Soloam
              I can confirm that FOTA is working on all frequency, except 8Mhz... I can't get it working on FOTA or FTDI on the 8Mhz version of MYSBootloader!
              Can any one help me with this?
              Thank you
              tekkaT 1 Reply Last reply
              • SoloamS Soloam
                Thank you
                tekkaT
                tekkaT
                tekka
                @soloam I assume 115200 baud@8Mhz could be an issue, decreasing it to 57600 may help (i.e. in mysbootloader & boards.txt settings)
                • SoloamS
                  SoloamS
                  Soloam
                  @tekka said in FOTA Not Working:
                  57600
                  hello @tekka I tested out with:
                  57600
                  38400
                  19200
                  9600
                  4800
                  2400
                  None worked, strange that is working on the 16Mhz and 1Mhz, and only the 8Mhz is giving problems... exactly the one that I wanted to use... lol
                  Thank You
                  gohanG tekkaT 2 Replies Last reply
                  • SoloamS Soloam
                    57600
                    57600
                    38400
                    19200
                    9600
                    4800
                    2400
                    Thank You
                    @soloam said in FOTA Not Working:
                    Murphy's law :sweat_smile:
                    • SoloamS Soloam
                      57600
                      57600
                      38400
                      19200
                      9600
                      4800
                      2400
                      Thank You
                      tekkaT
                      tekkaT
                      tekka
                      @soloam When you tested the different baud settings, did you also change it in mysbootloader and recompiled it?
                      • SoloamS
                        SoloamS
                        Soloam
                        Do you mean over here @tekka?
                        /* set the UART baud rate defaults */
                        #ifndef BAUD_RATE
                        	#if F_CPU >= 8000000L
                        		#define BAUD_RATE   115200L
                        	#elif F_CPU >= 1000000L
                        		#define BAUD_RATE   9600L   // 19200 also supported, but with significant error
                        	#elif F_CPU >= 128000L
                        		#define BAUD_RATE   4800L   // Good for 128kHz internal RC
                        		#define BAUD_RATE 1200L     // Good even at 32768Hz
                        No, I will try it... Can I do it in "Atom"? any special settings?
                        Thank You
                        • SoloamS Soloam
                          #ifndef BAUD_RATE
                          Thank You
                          tekkaT
                          tekkaT
                          tekka
                          @soloam Yes, that's the correct location (if BAUD_RATE is not set via compiler settings).
                          Sorry, but I have no experience with Atom.
                          • SoloamS
                            SoloamS
                            Soloam
                            @tekka it worked :) Thank you for your assist, it was my first time doing this... so... :)
                            I made the change to HW.h to
                            #ifndef BAUD_RATE
                            	#if F_CPU >= 16000000L
                            	#elif F_CPU >= 8000000L
                            		#define BAUD_RATE   57600L
                            Compilled the new bootloader, and replaced it on the Arduino IDE folder... Flashed the new 8Mhz Bootloader to my node and now FTDI works... When I get home I'll test out FOTA and post back the results.
                            Will you change the GitHub Repo to take into account this change? Or is this a local problem only to me? Do you want me to submit change the code and hex file and submit a change request?
                            Thank You
                            • SoloamS Soloam
                              #ifndef BAUD_RATE
                              Thank You
                              tekkaT
                              tekkaT
                              tekka
                              @soloam well done! Yes, please go ahead and submit a PR with the necessary changes. I will review it later this week.
                              SoloamS 1 Reply Last reply
                              • tekkaT tekka
                                SoloamS
                                SoloamS
                                Soloam
                                @tekka FOTA and FTDI now working on 8Mhz Bootloader... PR submited!
                                Thank you for your help
                                • SoloamS
                                  SoloamS
                                  Soloam
                                  Just to end and close the topic, @tekka great work on the Bootloader and @jkandasa great work on MyController... Thank you
