  3. Please help! Arduino UNO + RFM69HW (TSM:INIT:TSP FAIL)
23 Posts 4 Posters 5.0k Views 3 Watching
    That is the voltage regulator like the one on the arduino that supplies the 3.3v pin, but the Arduino is using 5v also on the other GPIO pins and that usually could kill the RFM69 that should operate at 3.5V max on data pins
    vladimirV 1 Reply Last reply
      vladimirV
      vladimirV
      vladimir
      @gohan what regulator can you advise? Can you show an example?
        search for "logic level shifter"
        • vladimirV vladimir
          @vladimir the shopping guide at https://www.mysensors.org/build/connect_radio lists a logic level shifter.
            vladimirV
            vladimirV
            vladimir
            @gohan thank you very much for your help! :raised_hands:
              vladimirV
              vladimirV
              vladimir
              @mfalkvidd thank you very much for your help! :+1: :v:
                I hope you didn't fry the rfm69, so in case you are still having problems with the level shifter connected try with another module
                  vladimirV
                  vladimirV
                  vladimir
                  @gohan I'm afraid that they suffered greatly during my experiments. I'll try with the new ones. Can you tell me how to connect the converter?
                  • mfalkviddM
                    https://learn.sparkfun.com/tutorials/bi-directional-logic-level-converter-hookup-guide and https://learn.adafruit.com/neopixel-levelshifter/shifting-levels are pretty extensive guides
                      vladimirV
                      vladimirV
                      vladimir
                      @mfalkvidd Thank you! I hope I can figure it out. To regret, my knowledge of English is not very great. As I understand it, the connection scheme will be the most similar to this:
                      I'm right?
                        I'm right?
                        @vladimir yes, that looks great (except for the brown cable that doesn't go through the level shifter)
                          vladimirV
                          vladimirV
                          vladimir
                          @mfalkvidd So I do not like the converter for 4 channels?
                          Here this is indicated by the link you gave me above
                          It will take 5? More precisely 8-channel version?
                            @vladimir you will need to shift all signals. You can use multiple 4x boards, or a bigger board.
                            Edit: maybe miso and dio0 don't need to be shifted, since the Arduino only reads from it. But I am not 100% sure.
                              vladimirV
                              vladimirV
                              vladimir
                              @mfalkvidd Thank you! :raised_hands: I'll try tomorrow.
                                4ch is enough as the brown cable is the interrupt signal so it's just an input on the arduino
                                  vladimirV
                                  vladimirV
                                  vladimir
                                  @gohan @mfalkvidd Tell me please, can I connect the converter like this? If not, please explain why.
                                  Let me remind you, in the example was like this:
                                    No you can't, because 3.3v are needed to power the level shifter and the radio module. Level shifter is not a voltage regulator.
                                      vladimirV
                                      vladimirV
                                      vladimir
                                      @gohan Thanks for clarifying!
