  3. Please help! Arduino UNO + RFM69HW (TSM:INIT:TSP FAIL)
23 Posts 4 Posters 5.0k Views 3 Watching
  • mfalkviddM
    https://learn.sparkfun.com/tutorials/bi-directional-logic-level-converter-hookup-guide and https://learn.adafruit.com/neopixel-levelshifter/shifting-levels are pretty extensive guides
    vladimirV 1 Reply Last reply
      vladimirV
      vladimirV
      vladimir
      @mfalkvidd Thank you! I hope I can figure it out. To regret, my knowledge of English is not very great. As I understand it, the connection scheme will be the most similar to this:
      I'm right?
      • vladimirV vladimir
        I'm right?
        @vladimir yes, that looks great (except for the brown cable that doesn't go through the level shifter)
          vladimirV
          vladimirV
          vladimir
          @mfalkvidd So I do not like the converter for 4 channels?
          Here this is indicated by the link you gave me above
          It will take 5? More precisely 8-channel version?
            @vladimir you will need to shift all signals. You can use multiple 4x boards, or a bigger board.
            Edit: maybe miso and dio0 don't need to be shifted, since the Arduino only reads from it. But I am not 100% sure.
              vladimirV
              vladimirV
              vladimir
              @mfalkvidd Thank you! :raised_hands: I'll try tomorrow.
                4ch is enough as the brown cable is the interrupt signal so it's just an input on the arduino
                  vladimirV
                  vladimirV
                  vladimir
                  @gohan @mfalkvidd Tell me please, can I connect the converter like this? If not, please explain why.
                  Let me remind you, in the example was like this:
                    No you can't, because 3.3v are needed to power the level shifter and the radio module. Level shifter is not a voltage regulator.
                      vladimirV
                      vladimirV
                      vladimir
                      @gohan Thanks for clarifying!
