  3. Please help! Arduino UNO + RFM69HW (TSM:INIT:TSP FAIL)
23 Posts 4 Posters 5.0k Views 3 Watching
    That is the voltage regulator like the one on the arduino that supplies the 3.3v pin, but the Arduino is using 5v also on the other GPIO pins and that usually could kill the RFM69 that should operate at 3.5V max on data pins
    vladimirV
    vladimirV
    vladimir
    @gohan what regulator can you advise? Can you show an example?
      search for "logic level shifter"
      vladimirV 1 Reply Last reply
      • vladimirV vladimir
        @vladimir the shopping guide at https://www.mysensors.org/build/connect_radio lists a logic level shifter.
          vladimirV
          vladimirV
          vladimir
          @gohan thank you very much for your help! :raised_hands:
            vladimirV
            vladimirV
            vladimir
            @mfalkvidd thank you very much for your help! :+1: :v:
              I hope you didn't fry the rfm69, so in case you are still having problems with the level shifter connected try with another module
                vladimirV
                vladimirV
                vladimir
                @gohan I'm afraid that they suffered greatly during my experiments. I'll try with the new ones. Can you tell me how to connect the converter?
                • mfalkviddM
                  https://learn.sparkfun.com/tutorials/bi-directional-logic-level-converter-hookup-guide and https://learn.adafruit.com/neopixel-levelshifter/shifting-levels are pretty extensive guides
                    vladimirV
                    vladimirV
                    vladimir
                    @mfalkvidd Thank you! I hope I can figure it out. To regret, my knowledge of English is not very great. As I understand it, the connection scheme will be the most similar to this:
                    I'm right?
                      I'm right?
                      @vladimir yes, that looks great (except for the brown cable that doesn't go through the level shifter)
                        vladimirV
                        vladimirV
                        vladimir
                        @mfalkvidd So I do not like the converter for 4 channels?
                        Here this is indicated by the link you gave me above
                        It will take 5? More precisely 8-channel version?
                          @vladimir you will need to shift all signals. You can use multiple 4x boards, or a bigger board.
                          Edit: maybe miso and dio0 don't need to be shifted, since the Arduino only reads from it. But I am not 100% sure.
                            vladimirV
                            vladimirV
                            vladimir
                            @mfalkvidd Thank you! :raised_hands: I'll try tomorrow.
                              4ch is enough as the brown cable is the interrupt signal so it's just an input on the arduino
                                vladimirV
                                vladimirV
                                vladimir
                                @gohan @mfalkvidd Tell me please, can I connect the converter like this? If not, please explain why.
                                Let me remind you, in the example was like this:
                                  No you can't, because 3.3v are needed to power the level shifter and the radio module. Level shifter is not a voltage regulator.
                                    vladimirV
                                    vladimirV
                                    vladimir
                                    @gohan Thanks for clarifying!
