  3. BH1750 library hangs
20 Posts 2 Posters 5.1k Views 2 Watching
  • alexsh1A alexsh1
    @joão-gouveia OK, if i2c wiring is fine, load up i2c scanner and see if you can read the sensor address.
    J
    J
    João Gouveia
    @alexsh1 I ran this example: https://playground.arduino.cc/Main/I2cScanner (I'm not sure if this is what you meant).
    It seems to hang on Wire.endTransmition() it prints the string "Scanning..." but nothing else.
    alexsh1A 1 Reply Last reply
    • J João Gouveia
      alexsh1A
      alexsh1A
      alexsh1
      @joão-gouveia Yes, that's what I meant. OK, here we go - this is an i2c problem. I am shooting a bit in the dark here - how about trying to change your power source? Maybe a different 3.3V FTDI adapter.
      J 1 Reply Last reply
      • alexsh1A alexsh1
        J
        J
        João Gouveia
        @alexsh1 Hm that seems reasonable. The FTDI board I have seems to be a bit funky it gives a lot of errors when I am trying to upload sometimes. Could that be related? I am not sure if it is the FTDI or the mini pro itself though.
        I don't have another type with me though.
        • J João Gouveia
          alexsh1A
          alexsh1A
          alexsh1
          @joão-gouveia A good a reliable power source is a key unless you what to spend hours troubleshooting. Yes, FTDI could be the reason when used as a power source.
          Another thing to try is to load an example sketch for BH1750, disconnect the FTDI adapter and use 2xAA batteries to power up your schematic. Then you can check your controller for a log. Unfortunately, you cannot check the log on the node.
          • alexsh1A alexsh1
            J
            J
            João Gouveia
            @alexsh1 I think I will try to get a more reliable FTDI since this one seems to give me some troubles. It also isn't properly detected on my PC sometimes. Is there a reliable one I could get from, for example, aliexpress, you recommend? My knowledge on these is close to zero, hahaha. Thanks. :)
            • J João Gouveia
              alexsh1A
              alexsh1A
              alexsh1
              @joão-gouveia I would highly recommend Adafruit FTDI :
              https://www.adafruit.com/product/284
              Expensive, yes, but I modified with two switches - 3.3V-5V power and 3.3v-5V logic level.
              Alternatively, you can try a few cheap Aliexpress ones like this one (make sure it is a genuine FTDI chip):
              https://www.aliexpress.com/item/1PCS-FT232RL-Serial-adapter-Module-USB-to-TTL-3-3V-5V-Mini-USB-TTL/32326225256.html?ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10344_10130_10068_10324_10342_10547_10325_10343_10340_10548_10341_10697_10696_10192_10190_10084_10083_10618_10307_10301_10303_10059_10184_10534_100031_10103_441_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_5&algo_expid=1d05e7ee-d1d0-4628-b1ab-56fd947c7eb0-2&algo_pvid=1d05e7ee-d1d0-4628-b1ab-56fd947c7eb0&transAbTest=ae803_2&priceBeautifyAB=0
              J 2 Replies Last reply
              • alexsh1A alexsh1
                J
                J
                João Gouveia
                @alexsh1 Thanks I will check it out and give it a try! :) I'll let you know the results
                • alexsh1A alexsh1
                  J
                  J
                  João Gouveia
                  @alexsh1 I just realized my full blown stupidity. The breadboard I am using has the buses connected half way and I was convinced they were fully connected. So the light sensor was not getting power, obviously. :man-facepalming: :man-facepalming: :man-facepalming: :man-facepalming: :sweat_smile: :sweat_smile: :sweat_smile: :sweat_smile:
                  It works now.
                  • J João Gouveia
                    It works now.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @joão-gouveia The problem is very often much simpler than we think :-)
                    • alexsh1A alexsh1
                      J
                      J
                      João Gouveia
                      @alexsh1 Very true :) Anyways, thanks for the tips!
