π¬ Advanced Gateway Options
Okay we are on the same page,this is good Do you have a Vera Controller?
I am using a Vera Plus and a Vera3.Now in the Plus the plugin says it is connected to my GW using port even thou my sketch says to use a different port.
Here is latest pin mapping for my 88266 v3IO index ESP8266 pin IO index ESP8266 pin 0 [*] GPIO16 7 GPIO13 1 GPIO5 8 GPIO15 2 GPIO4 9 GPIO3 3 GPIO0 10 GPIO1 4 GPIO2 11 GPIO9 5 GPIO14 12 GPIO10 6 GPIO12 here is my sketch is yours the same (except for ip addresses) and if you use a Vera how is your plugin configured. Also I am using the latest U17 mysensors software
The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* * * REVISION HISTORY * Version 1.0 - Henrik EKblad * Contribution by a-lurker and Anticimex, * Contribution by Norbert Truchsess <norbert.truchsess@t-online.de> * Contribution by Ivo Pullens (ESP8266 support) * * DESCRIPTION * The EthernetGateway sends data received from sensors to the WiFi link. * The gateway also accepts input on ethernet interface, which is then sent out to the radio network. * * VERA CONFIGURATION: * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin. * E.g. If you want to use the defualt values in this sketch enter: 192.168.254.66:5003 * * LED purposes: * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used. * - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved * - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly * - ERR (red) - fast blink on error during transmission error or recieve crc error * * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions. * nRF24L01+ ESP8266 * VCC VCC * CE GPIO4 D2 // GPIO 4 * CSN/CS GPIO15 D8// GPIO 15 * SCK GPIO14 D5 //GPIO 14 * MISO GPIO12 D7 // GPIO 13 * MOSI GPIO13 D6// GPIO 12 * GND GND * * Not all ESP8266 modules have all pins available on their external interface. * This code has been tested on an ESP-12 module. * The ESP8266 requires a certain pin configuration to download code, and another one to run code: * - Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch') * - Connect GPIO15 via 10K pulldown resistor to GND * - Connect CH_PD via 10K resistor to VCC * - Connect GPIO2 via 10K resistor to VCC * - Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch') * * Inclusion mode button: * - Connect GPIO2 via switch to GND ('inclusion switch') D4 GPIO 2 * * Make sure to fill in your ssid and WiFi password below for ssid & pass. */ // Enable debug prints to serial monitor #define MY_DEBUG // Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h #define MY_BAUD_RATE 115200 // Enables and select radio type (if attached) #define MY_RADIO_NRF24 #define MY_GATEWAY_ESP8266 #define MY_ESP8266_SSID "name" #define MY_ESP8266_PASSWORD "password" // Enable UDP communication #define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below // Set the hostname for the WiFi Client. This is the hostname // it will pass to the DHCP server if not static. #define MY_ESP8266_HOSTNAME "sensor-gateway" // Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP) // #define MY_IP_ADDRESS 192.168.xxx.xxx // If using static ip you can define Gateway and Subnet address as well //#define MY_IP_GATEWAY_ADDRESS 192.168.xxx.xxx //#define MY_IP_SUBNET_ADDRESS 255,255,255,0 // The port to keep open on node server mode #define MY_PORT 3480 // 5003 // How many clients should be able to connect to this gateway (default 1) #define MY_GATEWAY_MAX_CLIENTS 2 // Controller ip address. Enables client mode (default is "server" mode). // Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere. #define MY_CONTROLLER_IP_ADDRESS 192, 168, 254, xxx // Vera Plus address 192.168.254.068 Vera3 Address // Enable inclusion mode #define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway // #define MY_INCLUSION_BUTTON_FEATURE // Set inclusion mode duration (in seconds) #define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button #define MY_INCLUSION_MODE_BUTTON_PIN 2 //D4 also Builtin LED // Set blinking period #define MY_DEFAULT_LED_BLINK_PERIOD 300 // Flash leds on rx/tx/err // Led pins used if blinking feature is enabled above #define MY_DEFAULT_ERR_LED_PIN 3 // Red Error led pin //D9_____________This does not work #define MY_DEFAULT_ERR_LED_PIN 10 // Red Error led pin //D12 ******* This works #define MY_DEFAULT_RX_LED_PIN 1 // Green Receive led pin // D10_____________ This does not work #define MY_DEFAULT_RX_LED_PIN 9 // Green Receive led pin // D11*******This works #define MY_DEFAULT_TX_LED_PIN 5 // Blue Transmit LED // D1 #if defined(MY_USE_UDP) #include <WiFiUdp.h> #endif #include <ESP8266WiFi.h> #include <MySensors.h> void setup() { // Setup locally attached sensors } void presentation() { // Present locally attached sensors here } void loop() { // Send locally attached sensors data here }It will not work for me with this configuration.
but if I use the ****** Configuration it worksand here is output of working configuration:
532 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1 582 GWT:TIN:CONNECTING... 584 GWT:TIN:IP=192.168.254.125 587 MCO:BGN:STP 588 MCO:BGN:INIT OK,TSP=1 633 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 3441 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 3896 TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=3,l=2,sg=0:4424 4121 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:0 4556 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1 5755 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 8763 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 9875 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0 pm open,type:2 0 10877 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 14047 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:0 14086 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 14717 TSF:MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1574 15999 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 19408 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 20422 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1 21121 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 24732 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 25940 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:0 29373 TSF:MSG:READ,1-1-0,s=1,c=1,t=23,pt=3,l=2,sg=0:736 34999 TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=3,l=2,sg=0:4413 42034 TSF:MSG:READ,24-24-0,s=24,c=1,t=16,pt=0,l=1,sg=0:0 45115 TSF:MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1586 59511 TSF:MSG:READ,1-1-0,s=1,c=1,t=23,pt=3,l=2,sg=0:739 66107 TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=3,l=2,sg=0:4428 75513 TSF:MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1604 80151 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1 80291 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0 83273 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 87705 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 88597 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 89649 TSF:MSG:READ,1-1-0,s=1,c=1,t=23,pt=3,l=2,sg=0:740 89684 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0 92827 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 93918 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 94376 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0 97207 TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=3,l=2,sg=0:4458 97949 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 99071 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0 99240 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 103071 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 103698 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:0 103766 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0 104129 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1 104562 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0 105911 TSF:MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1617 108193 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0 Now I do not know if the 0 (READ,9-6-0) means it is not sending it anywhere but you can see it is reading my sensors output (MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1586) output message from my LUX sensorWhat firmware is in your 8266?
I do not know if this helps but I can tell you the "inclusion" still does not work
Waiting for your reply
Thanks -
PLEASE, if you post code, post it as a code block. It is MUCH easier to read. Edit your post, highlight the code and click on the </> icon. If you are pasting code into a new message, click the </> icon and then paste. The code gets surrounded by "```" (without quotes) at the beginning and end. Make sure you click out of your code block when finishing your message.
You are very correct, and I thank you. One day I will learn to use this forum correctly, that could be when I can build a gw that actually works? LOL
Also why does my Plugin in Vera say it is using plugin "Version 1.5" if I am using the latest software from the GitHub site, which I would say is to use the 2.2 library -
Thanks@mntlvr I use Domoticz, not Vera. So I can't answer any questions about that controller.
But here is my code for the ESP8266 Gateway. I am using 2.2.0 library.
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h #define MY_BAUD_RATE 9600 // Enables and select radio type (if attached) #define MY_RADIO_NRF24 // Set the frequency to channel 110 (2,510MHz), to prevent interference of WiFi channel 14 (-2,495MHz) #define MY_RF24_CHANNEL 110 // ESP8266 Gateway #define MY_GATEWAY_ESP8266 // WiFi settings #define MY_ESP8266_SSID "wifi" #define MY_ESP8266_PASSWORD "password" // Set the hostname for the WiFi Client. This is the hostname // it will pass to the DHCP server if not static. #define MY_ESP8266_HOSTNAME "MySensor_GW" // The port to keep open on node server mode #define MY_PORT 5003 // How many clients should be able to connect to this gateway (default 1) #define MY_GATEWAY_MAX_CLIENTS 2 // Enable inclusion mode #define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway #define MY_INCLUSION_BUTTON_FEATURE // Set inclusion mode duration (in seconds) #define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button #define MY_INCLUSION_MODE_BUTTON_PIN D4 // Set blinking period (in milliseconds) #define MY_DEFAULT_LED_BLINK_PERIOD 300 // Flash leds on rx/tx/err // Led pins used if blinking feature is enabled above // Internal onboard LED is PIN 16 #define MY_DEFAULT_ERR_LED_PIN D10 // Error led pin (Red) #define MY_DEFAULT_RX_LED_PIN D9 // Receive led pin (Yellow) #define MY_DEFAULT_TX_LED_PIN D1 // Transmit led pin (Green) #include <ESP8266WiFi.h> #include <MySensors.h> void setup() { } void presentation() { // Present locally attached sensors here } void loop() { // Send locally attached sensors data here }Be aware that if you use D4 for inclusion button the button can not be pushed at start of gateway. Then the gateway will not boot correct.
Also why does my Plugin in Vera say it is using plugin "Version 1.5" if I am using the latest software from the GitHub site, which I would say is to use the 2.2 library@mntlvr You are mistaking the plugin version with the library version. I am going to assume you are using UI7 and not UI5. Go to your devices list. On the MySensors plugin, click the right arrow icon:
Once there, click on Settings and you should see something like this:
Right under the plugin version you will see what library version you got from Github. Remember though that that is ONLY for your gateway and NOT NECESSARILY what library your nodes are running on. -
No I am using my Vera3 U15 and Library version is 1.4.1 . I am not going to keep this gw, just had to see if it was a problem with my Vera's or the library versions I am using so now I am uninstalling Arduino and all of the libraries and going to install Arduino IDE 1.6.4 and MYSensors Library 1.4.1 and go from their if that works I will install a later version of MYSensors.
Right under the plugin version you will see what library version you got from Github. Remember though that that is ONLY for your gateway and NOT NECESSARILY what library your nodes are running on.@dbemowsk said in π¬ Advanced Gateway Options:
Right under the plugin version you will see what library version you got from Github. Remember though that that is ONLY for your gateway and NOT NECESSARILY what library your nodes are running on.I am now using the library 2.2 with IDE 1.84 and now and the latest U17 files for Vera.
I can ot get my Vera Plus to create the device. So what can I do now? -
It creates the MySensor plugin but will not allow any inclusions, I have inclusions loaded into the gw but did not attach a button or leds to it but with inclusions loaded in gw Vera Plugin should allow me to "include" but the plugin button does nothing, so I do not have any nodes. Also I know the Vera is talking with the gateway because in advanced options the correct ip address is there and so is the proper port. I use a Port scanner to scan the ports available and report the ports that are open on each device on my network both of my controllers have port 80 and port 4380 open.
@mntlvr Sorry if I missed this, but how do you have the gateway connected to your Vera? I recall you mentioning about a serial connection earlier. So is it that you have a serial connection to your Vera from your ESP8266 to where the ESP is just acting as a bridge between the wireless side to the serial side connected to the Vera?
No I have a WIFI connection, not a serial gw. I had an Ethernet connection before but since they updated the libraries and the code I could never get my Ethernet gw working. So I built the WIFI gw and like I said the read outs on the serial monitor of the IDE shows the gw and the light sensor talking to one another but the plugin that is in Vera Plus does not allow "include" mode to operate at all, so I can not include any of my sensors into my Vera. Now I hope someone here who has built a gw with an ESP8266-E v3 LoLin can help , maybe it is not for Vera but perhaps they built it for another controller, but the principle is the same. I do know that a V2 of the same ESP8266 has a different pin out so I can't use that pin out from a V2 chip
I think you are miss-understanding me the Mysensors Plugin for Vera does all of the connecting to Vera. I have nothing connected to my Vera directly except the Vera address and the Ethernet Address which is applied to the plugin that you use to create the Icon for Mysensors. Whether I use the WiFi version or the Ethernet version the use the same plugin.Wireless except for the Address each unit has on the network
Yes the inclusion buttons are under properties no need of having button on gw.
How does you serial gw talk to your Vera ? Do you have a plugin that is used to create your Icon.See when the icon is created on my Vera Plus it shows the plugin version but not the library version so I know just by that issue the plugin is not configuring to any gw.
@mntlvr said in π¬ Advanced Gateway Options:
So what is the finial solution to using the Led's on a ESP 8266-E gateway are they of any use if using a Vera Controller?
I have had a lot of help with the leds. I have noticed that you get a lot of errors (in some positions it is impossible to communicate with the nodes at all) if not the radio is positioned to close to the ESP. It seems to me that the radio on the NodeMCU interferes with the NRF24L01+PA+LNA that i am using on my gateway. I found I thread on this forum about it but can't find it again.
So thanks to the leds I have been able to build a box where i have no transmission errors due to interference.
@strixx said in π¬ Advanced Gateway Options:
Strixx
You have a WiFi gw up and working , right? What version of the MYSensors are you using? Also what type of Vera are you using. I am using a Vera3 and a Vera Plus? Also which plugin are you using for your Vera. I have built both WiFi and Ethernet and the sensors talk wonderfully to the gw's no matter which I power up but neither of my Vera's will configure and use the plugin that are the latest available from git-hub. -
@mntlvr I believe the plugin is similar, if not the same for the serial gateway also. Did you enable the inclusion mode?
// Enable inclusion mode #define MY_INCLUSION_MODE_FEATUREIf you do a port scan of the IP address of the ESP8266, what ports does it show as open? Do you have this in you sketch?
// The port to keep open on node server mode #define MY_PORT 5003 -
With your input, this post could be even better π
