  2. Announcements
  3. πŸ’¬ Advanced Gateway Options
59 Posts 16 Posters 35.3k Views 13 Watching
  • mntlvrM
    mntlvrM
    mntlvr
    wrote on last edited by mntlvr
    #27
    You are very correct, and I thank you. One day I will learn to use this forum correctly, that could be when I can build a gw that actually works? LOL
    Also why does my Plugin in Vera say it is using plugin "Version 1.5" if I am using the latest software from the GitHub site, which I would say is to use the 2.2 library
    dbemowskD 1 Reply Last reply
    • mntlvrM mntlvr
      Okay we are on the same page,this is good Do you have a Vera Controller?
      I am using a Vera Plus and a Vera3.Now in the Plus the plugin says it is connected to my GW using port even thou my sketch says to use a different port.
      Here is latest pin mapping for my 88266 v3
      IO index ESP8266 pin IO index ESP8266 pin
      0 [*] GPIO16 7 GPIO13
      1 GPIO5 8 GPIO15
      2 GPIO4 9 GPIO3
      3 GPIO0 10 GPIO1
      4 GPIO2 11 GPIO9
      5 GPIO14 12 GPIO10
      6 GPIO12
      here is my sketch is yours the same (except for ip addresses) and if you use a Vera how is your plugin configured. Also I am using the latest U17 mysensors software
       * Version 1.0 - Henrik EKblad
       * Contribution by Ivo Pullens (ESP8266 support)
       * The EthernetGateway sends data received from sensors to the WiFi link.
       * VERA CONFIGURATION:
       * E.g. If you want to use the defualt values in this sketch enter: 192.168.254.66:5003
       * LED purposes:
       * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
       * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4 D2 // GPIO 4
       * CSN/CS     GPIO15 D8// GPIO 15
       * SCK        GPIO14 D5 //GPIO 14
       * MISO       GPIO12 D7 // GPIO 13
       * MOSI       GPIO13 D6// GPIO 12
       * GND        GND
       * Inclusion mode button:
       * - Connect GPIO2 via switch to GND ('inclusion switch') D4 GPIO 2
      #define MY_BAUD_RATE 115200
      #define MY_GATEWAY_ESP8266
      #define MY_ESP8266_SSID "name"
      #define MY_ESP8266_PASSWORD "password"
      // Enable UDP communication
       #define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
       #define MY_ESP8266_HOSTNAME "sensor-gateway"
      // #define MY_IP_ADDRESS 192.168.xxx.xxx
       //#define MY_IP_GATEWAY_ADDRESS 192.168.xxx.xxx
       #define MY_PORT 3480 // 5003
       #define MY_CONTROLLER_IP_ADDRESS 192, 168, 254, xxx // Vera Plus address 192.168.254.068 Vera3 Address
      // Enable inclusion mode
      // #define MY_INCLUSION_BUTTON_FEATURE
       #define MY_INCLUSION_MODE_BUTTON_PIN  2 //D4 also Builtin LED
      // Set blinking period
      // Flash leds on rx/tx/err
       #define MY_DEFAULT_ERR_LED_PIN 3  // Red Error led pin //D9_____________This does not work
      #define MY_DEFAULT_ERR_LED_PIN 10  // Red Error led pin //D12 ******* This works
       #define MY_DEFAULT_RX_LED_PIN  1  // Green Receive led pin // D10_____________ This does not work
      #define MY_DEFAULT_RX_LED_PIN  9  // Green Receive led pin // D11*******This works
       #define MY_DEFAULT_TX_LED_PIN  5  // Blue Transmit LED // D1
      #if defined(MY_USE_UDP)
      #include <WiFiUdp.h>
      #include <ESP8266WiFi.h>
      It will not work for me with this configuration.
      but if I use the ****** Configuration it works
      and here is output of working configuration:
      532 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1
      582 GWT:TIN:CONNECTING...
      584 GWT:TIN:IP=192.168.254.125
      587 MCO:BGN:STP
      588 MCO:BGN:INIT OK,TSP=1
      633 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      3441 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      3896 TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=3,l=2,sg=0:4424
      4121 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:0
      4556 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1
      5755 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      8763 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      9875 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0
      pm open,type:2 0
      10877 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      14047 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:0
      14086 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      14717 TSF:MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1574
      15999 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      19408 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      20422 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1
      21121 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      24732 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      25940 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:0
      29373 TSF:MSG:READ,1-1-0,s=1,c=1,t=23,pt=3,l=2,sg=0:736
      34999 TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=3,l=2,sg=0:4413
      42034 TSF:MSG:READ,24-24-0,s=24,c=1,t=16,pt=0,l=1,sg=0:0
      45115 TSF:MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1586
      59511 TSF:MSG:READ,1-1-0,s=1,c=1,t=23,pt=3,l=2,sg=0:739
      66107 TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=3,l=2,sg=0:4428
      75513 TSF:MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1604
      80151 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1
      80291 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0
      83273 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      87705 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      88597 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      89649 TSF:MSG:READ,1-1-0,s=1,c=1,t=23,pt=3,l=2,sg=0:740
      89684 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0
      92827 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      93918 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      94376 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0
      97207 TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=3,l=2,sg=0:4458
      97949 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      99071 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0
      99240 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      103071 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      103698 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:0
      103766 TSF:MSG:READ,27-27-0,s=27,c=1,t=16,pt=0,l=1,sg=0:0
      104129 TSF:MSG:READ,23-6-0,s=23,c=1,t=16,pt=0,l=1,sg=0:1
      104562 TSF:MSG:READ,22-22-0,s=22,c=1,t=16,pt=0,l=1,sg=0:0
      105911 TSF:MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1617
      108193 TSF:MSG:READ,21-21-0,s=21,c=1,t=16,pt=0,l=1,sg=0:0
      Now I do not know if the 0 (READ,9-6-0) means it is not sending it anywhere
      but you can see it is reading my sensors output (MSG:READ,9-6-0,s=9,c=1,t=23,pt=3,l=2,sg=0:1586) output message from my LUX sensor
      What firmware is in your 8266?
      I do not know if this helps but I can tell you the "inclusion" still does not work
      Waiting for your reply
      Strixx
      wrote on last edited by Strixx
      #28
      @mntlvr I use Domoticz, not Vera. So I can't answer any questions about that controller.
      But here is my code for the ESP8266 Gateway. I am using 2.2.0 library.
      #define MY_BAUD_RATE 9600
      // Set the frequency to channel 110 (2,510MHz), to prevent interference of WiFi channel 14 (-2,495MHz)
      #define MY_RF24_CHANNEL 110
      // ESP8266 Gateway
      // WiFi settings
      #define MY_ESP8266_SSID "wifi"
      #define MY_ESP8266_HOSTNAME "MySensor_GW"
      #define MY_PORT 5003
      #define MY_INCLUSION_MODE_BUTTON_PIN  D4
      // Set blinking period (in milliseconds)
      // Internal onboard LED is PIN 16
      #define MY_DEFAULT_ERR_LED_PIN D10  // Error led pin (Red)
      #define MY_DEFAULT_RX_LED_PIN  D9  // Receive led pin (Yellow)
      #define MY_DEFAULT_TX_LED_PIN  D1  // Transmit led pin (Green)
      Be aware that if you use D4 for inclusion button the button can not be pushed at start of gateway. Then the gateway will not boot correct.
      • mntlvrM mntlvr
        dbemowskD
        dbemowskD
        @mntlvr You are mistaking the plugin version with the library version. I am going to assume you are using UI7 and not UI5. Go to your devices list. On the MySensors plugin, click the right arrow icon:
        Once there, click on Settings and you should see something like this:
        Right under the plugin version you will see what library version you got from Github. Remember though that that is ONLY for your gateway and NOT NECESSARILY what library your nodes are running on.
        mntlvrM 1 Reply Last reply
        • mntlvrM
          mntlvrM
          mntlvr
          No I am using my Vera3 U15 and Library version is 1.4.1 . I am not going to keep this gw, just had to see if it was a problem with my Vera's or the library versions I am using so now I am uninstalling Arduino and all of the libraries and going to install Arduino IDE 1.6.4 and MYSensors Library 1.4.1 and go from their if that works I will install a later version of MYSensors.
          • dbemowskD dbemowsk
            mntlvrM
            mntlvrM
            mntlvr
            @dbemowsk said in πŸ’¬ Advanced Gateway Options:
            I am now using the library 2.2 with IDE 1.84 and now and the latest U17 files for Vera.
            I can ot get my Vera Plus to create the device. So what can I do now?
            • mntlvrM mntlvr
              dbemowskD
              dbemowskD
              @mntlvr Are you saying that it won't create the MySensors plugin itself, or one of your nodes under that?
              • mntlvrM
                mntlvrM
                mntlvr
                #33
                It creates the MySensor plugin but will not allow any inclusions, I have inclusions loaded into the gw but did not attach a button or leds to it but with inclusions loaded in gw Vera Plugin should allow me to "include" but the plugin button does nothing, so I do not have any nodes. Also I know the Vera is talking with the gateway because in advanced options the correct ip address is there and so is the proper port. I use a Port scanner to scan the ports available and report the ports that are open on each device on my network both of my controllers have port 80 and port 4380 open.
                • mntlvrM mntlvr
                  dbemowskD
                  dbemowskD
                  @mntlvr Sorry if I missed this, but how do you have the gateway connected to your Vera? I recall you mentioning about a serial connection earlier. So is it that you have a serial connection to your Vera from your ESP8266 to where the ESP is just acting as a bridge between the wireless side to the serial side connected to the Vera?
                  • mntlvrM
                    mntlvrM
                    mntlvr
                    No I have a WIFI connection, not a serial gw. I had an Ethernet connection before but since they updated the libraries and the code I could never get my Ethernet gw working. So I built the WIFI gw and like I said the read outs on the serial monitor of the IDE shows the gw and the light sensor talking to one another but the plugin that is in Vera Plus does not allow "include" mode to operate at all, so I can not include any of my sensors into my Vera. Now I hope someone here who has built a gw with an ESP8266-E v3 LoLin can help , maybe it is not for Vera but perhaps they built it for another controller, but the principle is the same. I do know that a V2 of the same ESP8266 has a different pin out so I can't use that pin out from a V2 chip
                    • mntlvrM mntlvr
                      dbemowskD
                      dbemowskD
                      @mntlvr How does your ESP8266 connect to your Vera?
                      • mntlvrM
                        mntlvrM
                        mntlvr
                        Thru the plugin just like mt Ethernet W5100 did.
                        • mntlvrM mntlvr
                          dbemowskD
                          dbemowskD
                          @mntlvr I think you're missing what I am asking. How does your ESP8266 PHYSICALLY connect to your vera, or doesn't it? In other words, is there a wire that connects your gateway to your vera?
                          • mntlvrM
                            mntlvrM
                            mntlvr
                            I think you are miss-understanding me the Mysensors Plugin for Vera does all of the connecting to Vera. I have nothing connected to my Vera directly except the Vera address and the Ethernet Address which is applied to the plugin that you use to create the Icon for Mysensors. Whether I use the WiFi version or the Ethernet version the use the same plugin.Wireless except for the Address each unit has on the network
                            • mntlvrM mntlvr
                              dbemowskD
                              dbemowskD
                              @mntlvr Sorry, I don't have ethernet or WiFi gateways, so I wasn't sure if or how they connected to the Vera. When you go to the properties on the MySensors plugin, is it that you have the start and stop buttons for inclusion, or do you not have the buttons?
                              • mntlvrM
                                mntlvrM
                                mntlvr
                                Yes the inclusion buttons are under properties no need of having button on gw.
                                How does you serial gw talk to your Vera ? Do you have a plugin that is used to create your Icon.
                                See when the icon is created on my Vera Plus it shows the plugin version but not the library version so I know just by that issue the plugin is not configuring to any gw.
                                • S Strixx
                                  @mntlvr said in πŸ’¬ Advanced Gateway Options:
                                  So what is the finial solution to using the Led's on a ESP 8266-E gateway are they of any use if using a Vera Controller?
                                  I have had a lot of help with the leds. I have noticed that you get a lot of errors (in some positions it is impossible to communicate with the nodes at all) if not the radio is positioned to close to the ESP. It seems to me that the radio on the NodeMCU interferes with the NRF24L01+PA+LNA that i am using on my gateway. I found I thread on this forum about it but can't find it again.
                                  So thanks to the leds I have been able to build a box where i have no transmission errors due to interference.
                                  mntlvrM
                                  mntlvrM
                                  mntlvr
                                  @strixx said in πŸ’¬ Advanced Gateway Options:
                                  Strixx
                                  You have a WiFi gw up and working , right? What version of the MYSensors are you using? Also what type of Vera are you using. I am using a Vera3 and a Vera Plus? Also which plugin are you using for your Vera. I have built both WiFi and Ethernet and the sensors talk wonderfully to the gw's no matter which I power up but neither of my Vera's will configure and use the plugin that are the latest available from git-hub.
                                  S 1 Reply Last reply
                                  • mntlvrM mntlvr
                                    dbemowskD
                                    dbemowskD
                                    @mntlvr I believe the plugin is similar, if not the same for the serial gateway also. Did you enable the inclusion mode?
                                    If you do a port scan of the IP address of the ESP8266, what ports does it show as open? Do you have this in you sketch?
                                    • mntlvrM
                                      mntlvrM
                                      mntlvr
                                      Oh yes I mentioned that several days ago.
                                      My vera's have port 3480 and 80 opened
                                      dbemowskD 2 Replies Last reply
                                      • mntlvrM mntlvr
                                        dbemowskD
                                        dbemowskD
                                        #45
                                        @mntlvr But do you have port 5003 defined in the gateway sketch that you have on the ESP8266? You should be seeing a port 5003 open. If not, you will need to check the sketch and find out why? What happens if you open your web browser to port 80 at that IP address? Does it bring you to a configuration page?
                                        • mntlvrM mntlvr
                                          dbemowskD
                                          dbemowskD
                                          @mntlvr Also, It's not the Vera's IP that you want to scan ports on. It would be the IP of the ESP8266.
                                          With your input, this post could be even better πŸ’—
