[ SOLVED ] MyS 2.2.0 - MY_DEBUG fails on certain bootloaders
I have started to update my nodes to 2.2.0. The gateway went smooth, and the first nodes were no problem either. These were simple sleeping nodes with a timer to send climate data.
The next batch were my dimmer nodes that failed to work properly because of a button that was not read anymore (actually, after pressing, the release was not detected. The solution was the PINMODE that was declared in the
before()was cleared afterPresentation()).When I tried to use
MY_DEBUG, the compilation failed. That was Arduino IDE 1.6.13, and after I updated to 1.8.5 it ran once. After that it only failed every time.When I changed the board definition to Moteino (I use that for my gateway and 1 sensor) it compiled normally. When I changed back to the bootloader I use on the dimmer board it failed again.
All my boards are basically the same (except for the two mentioned):
- ATmega328p; internal 8 MHz clock; 2,7V BOD
- RFM69 radio (some HW, some W)
- bootloader by GertSanders: 32p TQFP; 2,7V; 8MHz internal; LED D5; 38k4 upload speed
I tried to compile with other bootloaders, but a mismatch in baudrate prevented me from uploading the sketch.
Here is the error log from the IDE:
In file included from /Users/David/Documents/Arduino/libraries/MySensors/MySensors.h:49:0, from /var/folders/zw/bqygd0w11qd6rb620f1pjy_w0000gn/T/arduino_modified_sketch_112637/sketch_feb06a.ino:90: /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'void stInitUpdate()': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:124:45: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSM:INIT:STATID=%" PRIu8 "\n"),(uint8_t)MY_NODE_ID); ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:124:4: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSM:INIT:STATID=%" PRIu8 "\n"),(uint8_t)MY_NODE_ID); ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'void stUplinkUpdate()': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:265:44: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSM:UPL:DGWC,O=%" PRIu8 ",N=%" PRIu8 "\n"), _transportConfig.distanceGW, ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:265:4: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSM:UPL:DGWC,O=%" PRIu8 ",N=%" PRIu8 "\n"), _transportConfig.distanceGW, ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'void stReadyTransition()': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:292:40: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSM:READY:ID=%" PRIu8 ",PAR=%" PRIu8 ",DIS=%" PRIu8 "\n"), ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:292:2: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSM:READY:ID=%" PRIu8 ",PAR=%" PRIu8 ",DIS=%" PRIu8 "\n"), ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'void stFailureTransition()': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:342:40: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSM:FAIL:CNT=%" PRIu8 "\n"),_transportSM.failureCounter); ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:342:2: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSM:FAIL:CNT=%" PRIu8 "\n"),_transportSM.failureCounter); ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'bool transportWaitUntilReady(uint32_t)': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:449:38: error: expected ')' before 'PRIu32' TRANSPORT_DEBUG(PSTR("TSF:WUR:MS=%" PRIu32 "\n"), waitingMS); // timeout ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:449:2: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:WUR:MS=%" PRIu32 "\n"), waitingMS); // timeout ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'bool transportCheckUplink(bool)': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:485:44: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSF:CKU:DGWC,O=%" PRIu8 ",N=%" PRIu8 "\n"), _transportConfig.distanceGW, ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:485:4: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:CKU:DGWC,O=%" PRIu8 ",N=%" PRIu8 "\n"), _transportConfig.distanceGW, ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'bool transportAssignNodeID(uint8_t)': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:504:42: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSF:SID:OK,ID=%" PRIu8 "\n"),newNodeId); // Node ID assigned ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:504:3: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:SID:OK,ID=%" PRIu8 "\n"),newNodeId); // Node ID assigned ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:507:45: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("!TSF:SID:FAIL,ID=%" PRIu8 "\n"),newNodeId); // ID is invalid, cannot assign ID ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:507:3: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("!TSF:SID:FAIL,ID=%" PRIu8 "\n"),newNodeId); // ID is invalid, cannot assign ID ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'uint8_t transportPingNode(uint8_t)': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:612:44: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSF:PNG:SEND,TO=%" PRIu8 "\n"), targetId); ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:612:3: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:PNG:SEND,TO=%" PRIu8 "\n"), targetId); ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'void transportProcessMessage()': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:660:40: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSF:MSG:READ,%" PRIu8 "-%" PRIu8 "-%" PRIu8 ",s=%" PRIu8 ",c=%" PRIu8 ",t=%" ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:660:2: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:MSG:READ,%" PRIu8 "-%" PRIu8 "-%" PRIu8 ",s=%" PRIu8 ",c=%" PRIu8 ",t=%" ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:669:41: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("!TSF:MSG:LEN,%" PRIu8 "!=%" PRIu8 "\n"), payloadLength, ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:669:3: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("!TSF:MSG:LEN,%" PRIu8 "!=%" PRIu8 "\n"), payloadLength, ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:677:42: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("!TSF:MSG:PVER,%" PRIu8 "!=%" PRIu8 "\n"), mGetVersion(_msg), ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:677:3: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("!TSF:MSG:PVER,%" PRIu8 "!=%" PRIu8 "\n"), mGetVersion(_msg), ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:762:53: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSF:MSG:FPAR OK,ID=%" PRIu8 ",D=%" PRIu8 "\n"), _transportConfig.parentNodeId, ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:762:9: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:MSG:FPAR OK,ID=%" PRIu8 ",D=%" PRIu8 "\n"), _transportConfig.parentNodeId, ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:775:49: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSF:MSG:PINGED,ID=%" PRIu8 ",HP=%" PRIu8 "\n"), sender, ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:775:6: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:MSG:PINGED,ID=%" PRIu8 ",HP=%" PRIu8 "\n"), sender, ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:789:53: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSF:MSG:PONG RECV,HP=%" PRIu8 "\n"), ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:789:7: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:MSG:PONG RECV,HP=%" PRIu8 "\n"), ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'bool transportSendWrite(uint8_t, MyMessage&)': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:1001:42: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("%sTSF:MSG:SEND,%" PRIu8 "-%" PRIu8 "-%" PRIu8 "-%" PRIu8 ",s=%" PRIu8 ",c=%" ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:1001:2: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("%sTSF:MSG:SEND,%" PRIu8 "-%" PRIu8 "-%" PRIu8 "-%" PRIu8 ",s=%" PRIu8 ",c=%" ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'int16_t transportSignalReport(char)': /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:1174:39: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSF:SIR:CMD=%" PRIu8 ",VAL=%" PRIu16 "\n"), reportCommand, result); ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MyTransport.cpp:1174:2: note: in expansion of macro 'TRANSPORT_DEBUG' TRANSPORT_DEBUG(PSTR("TSF:SIR:CMD=%" PRIu8 ",VAL=%" PRIu16 "\n"), reportCommand, result); ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp: In function 'void _begin()': /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:171:42: error: expected ')' before 'PRIu8' CORE_DEBUG(PSTR("MCO:BGN:INIT OK,TSP=%" PRIu8 "\n"), isTransportReady()); ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:171:2: note: in expansion of macro 'CORE_DEBUG' CORE_DEBUG(PSTR("MCO:BGN:INIT OK,TSP=%" PRIu8 "\n"), isTransportReady()); ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp: In function 'bool _processInternalMessages()': /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:409:41: error: expected ')' before 'PRIu8' CORE_DEBUG(PSTR("MCO:PIM:NODE REG=%" PRIu8 "\n"), _coreConfig.nodeRegistered); // node registration ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:409:4: note: in expansion of macro 'CORE_DEBUG' CORE_DEBUG(PSTR("MCO:PIM:NODE REG=%" PRIu8 "\n"), _coreConfig.nodeRegistered); // node registration ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp: In function 'int8_t _sleep(uint32_t, bool, uint8_t, uint8_t, uint8_t, uint8_t)': /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:542:33: error: expected ')' before 'PRIu32' CORE_DEBUG(PSTR("MCO:SLP:MS=%" PRIu32 ",SMS=%" PRIu8 ",I1=%" PRIu8 ",M1=%" PRIu8 ",I2=%" PRIu8 ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:542:2: note: in expansion of macro 'CORE_DEBUG' CORE_DEBUG(PSTR("MCO:SLP:MS=%" PRIu32 ",SMS=%" PRIu8 ",I1=%" PRIu8 ",M1=%" PRIu8 ",I2=%" PRIu8 ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:572:35: error: expected ')' before 'PRIu32' CORE_DEBUG(PSTR("MCO:SLP:MS=%" PRIu32 "\n"), sleepingTimeMS); ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:572:4: note: in expansion of macro 'CORE_DEBUG' CORE_DEBUG(PSTR("MCO:SLP:MS=%" PRIu32 "\n"), sleepingTimeMS); ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:635:34: error: expected ')' before 'PRIi8' CORE_DEBUG(PSTR("MCO:SLP:WUP=%" PRIi8 "\n"), result); // sleep wake-up ^ /Users/David/Documents/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug ^ /Users/David/Documents/Arduino/libraries/MySensors/core/MySensorsCore.cpp:635:2: note: in expansion of macro 'CORE_DEBUG' CORE_DEBUG(PSTR("MCO:SLP:WUP=%" PRIi8 "\n"), result); // sleep wake-up ^I'm not sure why this only occurs with the GertSanders board definitions. I hope we can find a solution on this.
I have had a similar experience with different boards. The solution for me was to delete platform.txt in hardware/MySensors/avr - I think some parameters are outdated. What do you think @GertSanders ?
I can add to this: also the other bootloaders I use have a problem at the same point. The PSTR() expansion seems to fail. I have this same issue with the MightyCore bootloader and with Optiboot 6.x
The thing is, my atmega328p based nodes work fine without the MY_DEBUG flag.
So could this be related to the hardware definition ? Looks like it. I will test this further with the suggestion by Alex.
@DavidZH @alexsh1
The solution to removing the error was indeed to update the platform.txt file.
I copied the official platform.txt file from the Arduino application to the hardware folder in where my definitions and boot loader sit. The old platform.txt was renamed, and I added the official platform.txt instead.
That worked.
I'm assuming that by removing the platform.txt file, the Arduino IDE reverts to it's own platform.txt file, and as I can not see any parameters specific to the atmega328p or other processors, it was probably safe to remove this file.
I also tested this, and that also solved the error message problem. -
Thank you for calling back! I had the same "issue" my nodes were working so well, no debug was needed, only when I started on a new type I needed to debug some stuff.
And I had also tried Alex' solution with succes, but have had no time yet to report that.
I will mark this as solved.
Glad it has been sorted. This problem took me by surprise
@GertSanders you are tinkering with 1284p Mightyduino?
@alexsh1 hi Alex, yes.I was testing stuff with my first atmega1284p arduino clone (made back in 2015). The plan is now to make a smart clock with the mighty beast (lots of program memory, especially nice for extensive menu's).
But I'm a bit stuck on the fact that I can not get my node recognised on the Domoticz/gateway combo (on a raspi 2).
At least the compile error is now gone. Onto the next problem: no reply from parent ... -
At least the compile error is now gone. Onto the next problem: no reply from parent ...@gertsanders said in [ SOLVED ] MyS 2.2.0 - MY_DEBUG fails on certain bootloaders:
At least the compile error is now gone. Onto the next problem: no reply from parent ...Hi, Gert. Interesting. I assume you are talking about nrf24l01+ smd on both ends?
I am on the same latest beta Domoticz release, but cannot replicate this issue.
Cannot see anything been done recently to MySensors:
https://github.com/domoticz/domoticz/commits/developmentHow is your atmega1284 hooked up to the transceiver?
If you wiring is correct, you may want to try this in your sketch:#define MY_PASSIVE_NODE #define MY_PARENT_NODE_IS_STATIC #define MY_PARENT_NODE_ID 0 #define MY_NODE_ID [your number]Another thing - you may try to clear EEPROM and try again.
First, please forgive me for being such a NOOB when it comes to these things.
I use your atmega328p.rar found here for my atmega328p based 28 pin DIL boards.
Now I'm trying to compile in Arduino 1.8.5 (mysensors 2.2.0) I get a lot of compiler errors when
#define MY_DEBUGis set./home/XXX/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'void stInitUpdate()': /home/XXX/Arduino/libraries/MySensors/core/MyTransport.cpp:124:45: error: expected ')' before 'PRIu8' TRANSPORT_DEBUG(PSTR("TSM:INIT:STATID=%" PRIu8 "\n"),(uint8_t)MY_NODE_ID); ^ /home/XXX/Arduino/libraries/MySensors/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT' #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__) //!< debug etc etc...I understand that my boards definitions needs to be updated. Do you have a newer version of atmega328p.rar available or can you give me a hint about how to get them working?
Thanks a million times!
Cheers!
Cheers!
We found that in the following directory you can remove the platform.txt file:
/hardware/atmega328p/avr/platform.txt
The directory should only contain boards.txt and the subdirectories for boot loaders and variants
Thanks! Works great! I'm so happy!!! :relaxed: :smile:
